Updated on 2025-11-24 GMT+08:00
Creating a Pipeline
Using the GUI simplifies pipeline creation and configuration, making it beginner-friendly and efficient. Use YAML to create pipelines to manage their configurations by version. This allows easy rollback to earlier versions and access to historical records. The method also ensures reusable configuration, minimizing errors.
YAML pipelines are easy to iterate and optimize. They facilitate team collaboration and make complex projects easier to manage, thus boosting development and deployment efficiency.
Notes and Constraints
  • In the initial state, you can create a pipeline if you are any of the following roles:
    • Project administrator
    • Project manager
    • Developer
    • System engineer
    • Committer
  • Project administrators can modify the permissions of other roles. For details, see Authorizing CodeArts Pipeline.
