Pipeline Contexts
Contexts are a way to access information about pipeline runs, sources, variables, and jobs. Each context is an object that contains various attributes.
- Reference format
${{ <context>.<attribute_name> }}
- Pipeline contexts
Context Name
Type
pipeline
object
Information about the pipeline run.
sources
object
Information about the pipeline sources in each pipeline run.
env
object
Information about the custom parameters in each pipeline run.
jobs
object
Information about jobs that have reached the final states in each pipeline run.
Most contexts can be used in any job and step of a pipeline.
- You can use contexts to specify the execution condition of a job.
- You can use contexts when configuring parameters to query information.
The following expression shows how to obtain all pipeline run information.
${{ pipeline }}
The following expression shows how to obtain the triggering mode of a pipeline.${{ pipeline.trigger_type }}
pipeline Context
The pipeline context contains pipeline run information.
Name |
Type |
Description |
pipeline |
object |
Information about the pipeline run. This object contains the following attributes: project_id, pipeline_id, run_number, timestamp, trigger_type, and run_id. |
pipeline.project_id |
string |
ID of the project to which the current pipeline belongs. This string is the same as the predefined parameter PROJECT_ID. |
pipeline.pipeline_id |
string |
Current pipeline ID. This string is the same as the predefined parameter PIPELINE_ID. |
pipeline.run_number |
string |
Pipeline execution number. This string is the same as the predefined parameter PIPELINE_NUMBER. |
pipeline.timestamp |
string |
Pipeline execution timestamp. This string is the same as the predefined parameter TIMESTAMP. For example, 20211222124301. |
pipeline.trigger_type |
string |
Pipeline triggering type. This string is the same as the predefined parameter PIPELINE_TRIGGER_TYPE. |
pipeline.run_id |
string |
Pipeline execution ID. This string is the same as the predefined parameter PIPELINE_RUN_ID. |
- Content example
The following example shows the pipeline context information contained in a manually executed pipeline.
{ "project_id": "6428c2e2b4b64affa14ec80896695c49", "pipeline_id": "f9981060660249a3856f46c2c402f244", "run_number": "168", "timestamp": "20231016000004", "trigger_type": "Manual", "run_id": "c2f507f93510459190b543e47f6c9bec" }
- Usage example
To obtain the triggering mode of the current pipeline, you can use the following syntax:
sources Context
The sources context contains information about the pipeline sources.
Name |
Type |
Description |
sources |
object |
Information about the pipeline sources in each pipeline run. This object contains the following attributes: alias, repo_name, commit_id, commit_id_short, commit_message, repo_url, repo_type, repo_name, ssh_repo_url, tag, merge_id, source_branch, and target_branch. |
sources.<alias> |
object |
Information about the pipeline source which has an alias. |
sources.<repo_name> |
object |
Information about the pipeline source which does not have an alias but only a repository name. It contains the same information as that in sources.<alias> |
sources.<alias>.commit_id |
string |
The last commit ID before execution. This string is the same as the predefined parameter COMMIT_ID. |
sources.<alias>.commit_id_short |
string |
The last commit short ID before execution. This string is the same as the predefined parameter COMMIT_ID_SHORT. |
sources.<alias>.commit_message |
string |
The last commit message before execution. |
sources.<alias>.repo_url |
string |
Code repository address (HTTPS). This string is the same as the predefined parameter REPO_URL. |
sources.<alias>.repo_type |
string |
Type of the code repository. |
sources.<alias>.repo_name |
string |
Name of the code repository. |
sources.<alias>.ssh_repo_url |
string |
Code repository address (SSH). |
sources.<alias>.tag |
string |
Tag name when the tag is triggered. |
sources.<alias>.merge_id |
string |
Merge request ID when the merge request is triggered. |
sources.<alias>.source_branch |
string |
Source branch name when the merge request is triggered. |
sources.<alias>.target_branch |
string |
If the merge request is triggered, this string indicates the name of the target branch. Otherwise, this string indicates the name of the running branch. |
- Content example
The following example shows the sources context information contained in a manually executed pipeline with a single code source. The alias of pipeline source is my_repo.
{ "my_repo": { "commit_id": "dedb73bb9abfdaab7d810f2616bae9d2b6632ecc", "commit_id_short": "dedb73bb", "commit_message": "maven0529 update pipeline0615.yml", "repo_url": "https://example.com/clsyz00001/maven0529.git", "repo_type": "codehub", "repo_name": "maven0529", "ssh_repo_url": "git@example.com:clsyz00001/maven0529.git", "target_branch": "master" } }
- Usage example
To obtain the running branch of the pipeline, you can use the following syntax:
${{ sources.my_repo.target_branch }}
env Context
The env context contains information about the custom parameters in each pipeline run.
Name |
Type |
Description |
name |
string |
Name of a custom parameter. |
value |
string |
Value of a custom parameter. |
jobs Context
The jobs context contains information about jobs that have reached the final states in each pipeline run.
Name |
Type |
Description |
jobs |
object |
Information about jobs in a pipeline. This object contains the following attributes: job_id, status, outputs, output_name, metrics, and metric_name. |
jobs.<job_id> |
object |
Information about the job with a specified ID. |
jobs.<job_id>.status |
string |
Execution result of a job. The value can be INIT, QUEUED, RUNNING, CANCELED, COMPLETED, FAILED, PAUSED, IGNORED, or UNSELECTED. |
jobs.<job_id>.outputs |
object |
General output of an executed job. |
jobs.<job_id>.outputs.<output_name> |
string |
The value of output_name of an executed job. |
jobs.<job_id>.metrics |
object |
The running metric of a job. |
jobs.<job_id>.metrics.<metric_name> |
string |
The value of metric_name of an executed job. |
- Content example
The following example shows the jobs context information in a run. There are two successfully executed jobs. The output of the check_job job is two metrics, and the output of the demo_job job is two general outputs.
{ "check_job": { "status": "COMPLETED", "metrics": { "critical": "0", "major": "0" } }, "demo_job": { "status": "COMPLETED", "outputs": { "output1": "val1", "output2": "val2" } } }
- Usage example
To obtain the value of output1 of demo_job, you can use the following syntax:
${{ jobs.demo_job.outputs.output1 }}
