- What's New
- Function Overview
- Getting Started
User Guide
- CodeArts Pipeline Usage
- Enabling and Authorizing CodeArts Pipeline
- Accessing CodeArts Pipeline
- Creating a Pipeline
- Configuring a Pipeline
- Grouping Pipelines
- Executing a Pipeline
- Checking a Pipeline
- Configuring a Change-triggered Pipeline
- Managing Pipeline Extensions
- Creating Service Endpoints
- Checking Audit Logs
- Reference
- CodeArts Release User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Template Management
Pipeline Management
- Starting a Pipeline
- Obtaining Pipeline Statuses in Batches
- Obtaining Pipeline Status/Obtaining Pipeline Execution Details
- Obtaining Pipeline List/Pipeline Execution Status in a Project
- Deleting a Pipeline
- Querying Pipeline Details
- Editing a Pipeline
- Stopping a Pipeline
- Obtaining Pipeline Execution Records
- Creating a Pipeline With a Template
- Retrying a Pipeline
- Passing Manual Review
- Rejecting Manual Review
- Querying Pipeline Logs
- Obtaining the Pipeline Step Execution Output
- Querying Build Products on a Pipeline
- Group Management
- Rule Management
- Tenant-level Policy Management
- Project-level Policy Management
Extension Management
- Creating an Extension Version
- Creating an Extension Draft Version
- Creating a Publisher
- Updating an Extension Draft
- Publishing an Extension Draft
- Updating Basic Information of an Extension
- Binding an Extension to a Publisher
- Updating the Extension Icon
- Updating the Publisher Icon
- Deleting an Extension Draft
- Querying the Publisher List
- Querying the Available Publisher
- Querying the Available Extension List
- Querying the Basic Extension List
- Querying the Available Extensions by Page
- Querying the Extension List
- Querying Extension Indicator Configuration
- Query Extension Input Configuration
- Query Extension Output Configuration
- Querying All Versions of an Extension
- Querying Extension Version Details
- Querying the Extension Version
- Deleting a Publisher
- Querying Publisher Details
- Creating a Basic Extension
- Updating a Basic Extension
- Deleting a Basic Extension
- Uploading a Basic Extension
- Querying the Basic Extension Details
- Template Management (Old Version, Unavailable Soon)
Pipeline Management (Old Version, Unavailable Soon)
- Quickly Creating a Pipeline and Jobs with a Template
- Checking the Pipeline Creation Status
- Obtaining the Pipeline List
- Obtaining the Pipeline Status
- Obtaining the Pipeline Execution Status in a Project
- Application Examples
- Appendixes
- Change History
- Functions
Troubleshooting
- Pipeline Fails to Run Because Repository Not Found
- Pipeline Fails to Run Because the Test Suite Is Already in Progress
- Pipeline Fails to Run Because Job Not Found
- Pipeline Is Not Triggered at a Specified Time
- Execution Button Is Unavailable
- Inappropriate Reviewer Configured for the Manual Review Job
- Subpipeline Not Found
- Change-triggered Pipeline Fails to Run and an Error Message Is Returned: "authentication required"
- Pipeline Fails to Run Because Deployment Policy Not Found
- Videos
Show all
Configuring Expressions
You can reference pipeline contexts with expressions to specify the execution condition of a job. An expression can be any combination of contexts, operators, functions, or literals. Contexts can be accessed programmatically with expressions, so information such as pipeline runs, variables, and jobs can be transferred within a pipeline.
- Create a pipeline.
- Add stage jobs or edit existing jobs.
- Click Job Configuration and select With expression to configure the expression for job execution.
For a new stage and job, add an extension first and then click Job Configuration.
Figure 1 ExpressionsExample:
The following expression shows that a job runs only when the running branch of the specified code source is master.
${{ sources.my_repo.target_branch == 'master' }}
References
- Operator
The following table lists the operators that can be used in expressions.
Table 1 Operators Operator
Attribute reference. For example, the ${{ pipeline.trigger_type }} expression can be used to obtain the trigger type.
False. For example, the ${{ !startsWith(sources.my_repo.target_branch, 'release') }} can be used to check whether the branch of the pipeline's code source does not start with "release".
Equal. For example, the ${{ pipeline.trigger_type == 'Manual' }} expression can be used to check whether a pipeline is triggered manually.
Not equal. For example, the ${{ pipeline.trigger_type != 'Manual' }} expression can be used to check whether a pipeline is not triggered manually.
And. For example, the ${{ pipeline.trigger_type == 'Manual' && sources.my_repo.target_branch == 'master' }} expression can be used to check whether a pipeline is triggered manually and the branch of the pipeline code source is master.
Or. For example, the ${{ pipeline.trigger_type == 'Manual' || sources.my_repo.target_branch == 'master' }} expression can be used to check whether a pipeline is triggered manually or the branch of the pipeline code source is master.
- Function
The following table lists the functions that can be used in expressions.
Table 2 Built-in functions Function
contains
startsWith
endsWith
Object filter
You can use the * syntax to apply a filter and select matching items in a collection.
The following is the context of a job execution.
{ "check_job": { "status": "COMPLETED", "metrics": { "critical": "0", "major": "0" } }, "demo_job": { "status": "FAILED" } }
- jobs.*.status indicates the status of all jobs. Therefore, ['COMPLETED', 'FAILED'] is returned.
- Filters can be used together with the contains function. For example, contains(jobs.*.status, 'FAILED') will return true because jobs.*.status contains FAILED.
