Configuring URL Validation to Prevent Unauthorized Access to Your Data
OBS blocks access requests from blacklisted URLs and allows those from whitelisted URLs.
Some malicious websites hotlink resources from other websites to expand their content without incurring additional costs. This not only infringes on the interests of the original websites but also increases their server load. URL validation is designed to address this issue.
In HTTP, the Referer header field allows websites to identify the source webpage of a request. By checking the Referer value, websites can determine whether a request comes from an authorized source and block unauthorized requests or redirect them to a specified page. URL validation works by matching the Referer field against a whitelist or blacklist.
To prevent unauthorized hotlinking of data stored in OBS, OBS supports Referer-based URL validation with configurable whitelists and blacklists.
How It Works
When a browser sends a request to OBS, the Referer field in the HTTP request header records the URL of the page from which the request originated. OBS verifies the value of the Referer field to determine whether the request source is trusted. By configuring a Referer whitelist or Referer blacklist, you can allow or deny requests from specific sources.
After URL validation is configured, OBS performs access control according to the following rules:
- Check whether the Referer field is empty. OBS first determines whether the Referer field in the request is empty.
- If the Referer field is empty, the following rules apply:
- If Null referer is allowed is enabled, the request is allowed.
- If Null referer is allowed is disabled and Whitelisted Referers is empty, the request is allowed.
- If Null referer is allowed is disabled and Whitelisted Referers is not empty, the request is denied.
- If the Referer field is not empty, the following rules apply:
- If the Referer field is not empty, OBS checks the value of the Referer field against the configured whitelist or blacklist in URL validation.
- If Whitelisted Referers and Blacklisted Referers are both empty, all requests are allowed by default.
- If Whitelisted Referers is not empty and Blacklisted Referers is empty, the request is allowed if the Referer value matches an entry in the whitelist. Otherwise, the request is denied.
- If Whitelisted Referers is empty and Blacklisted Referers is not empty, the request is denied if the Referer value matches an entry in the blacklist. Otherwise, the request is allowed.
- If Whitelisted Referers and Blacklisted Referers are not empty, the request is denied if the Referer value matches an entry in the blacklist. If the Referer value matches an entry in the whitelist and does not match any entry in the blacklist, the request is allowed.
- Effective scope of URL validation: URL validation rules are configured and applied at the bucket level. They cannot be applied to specific objects.
Important Notes
Before determining whether a user has the four types of permissions (read, write, ACL read, and ACL write) for a bucket and its objects, check whether this user complies with the URL validation rules defined in the Referer field.
Because HTTP Referer headers can be easily spoofed, URL validation is only a supplementary defense. If you have strict data security requirements, use other OBS data protection features, such as server-side encryption and WORM. For details, see OBS Data Security Features.
Ways to Configure URL Validation
You can configure URL validation using OBS Console or APIs, but not using SDKs, OBS Browser+, or obsutil.
Example Scenarios
The following are common application scenarios of URL validation:
Allowing Only Trusted Websites to Access OBS
Use the Referer whitelist of URL validation to allow access to OBS only from trusted Referers that frequently access OBS buckets.
- View the bucket logs and find the value of the Referer field in the bucket log file. For details about bucket logging, see Log Management Overview.
If the value of the Referer field in the bucket log file is -, the Referer is null.
- Configure URL validation rules for the bucket.
For details about the configuration procedure, see Using OBS Console. Table 2 describes the parameters.
Table 2 URL validation whitelist rules Parameter
Value
https://www.example.com http://www.example.com https://console.huaweicloud.com/*
- Add the domain names of trusted websites that frequently access OBS buckets.
- You are advised to add both HTTPS and HTTP domain names.
- Add the console domain name and use a wildcard (*) to ensure that previews work properly in consoles across different regions.
Toggle it on.
Ensure that both direct access and console preview functions work properly.
No configuration is required.
You do not need to block specific sources.
- Verify the configuration.
- Simulate a request with a whitelisted Referer to OBS. The request is expected to be successful.
curl -e "https://www.example.com" https://test-bucket.obs.cn-north-4.myhuaweicloud.com/test.txt
- Simulate a request with a non-whitelisted Referer to OBS. The request is expected to fail, and AccessDenied is returned.
curl -e "https://www.example01.com" https://test-bucket.obs.cn-north-4.myhuaweicloud.com/test.txt
- Simulate a request with a null Referer to OBS. The request is expected to be successful.
curl https://test-bucket.obs.cn-north-4.myhuaweicloud.com/test.txt
Preventing Malicious Websites from Stealing OBS Data
Access from all sources is allowed, but some malicious websites must be prohibited from stealing OBS data. You can blacklist specific Referers to precisely block malicious access sources.
- View logs about abnormal traffic of the OBS bucket and find the value of the Referer field in the bucket log file. For details about bucket logging, see Log Management Overview.
For details about the configuration procedure, see Using OBS Console. Table 3 describes the parameters.
Table 3 URL validation blacklist rules Parameter
Value
Allow access from any source to OBS.
Toggle it on.
Ensure that both direct access to OBS and access via normal clients are allowed.
https://badmail.example.com http://badmail.example.com *badsite.example
Block access from malicious website domain names. The wildcard (*) indicates that the entire domain name and its subdomains are blocked.
- Simulate a request from a trusted website to OBS. The request is expected to be successful.
- Simulate a request with a blacklisted Referer to OBS. The request is expected to fail, and AccessDenied is returned.
curl -e "https://badmail.example.com" https://test-bucket.obs.cn-north-4.myhuaweicloud.com/test.txt
Accessing OBS Using Mini Programs
The URL validation whitelist allows access to OBS exclusively from a specific mini program (for example, https://appexample.com/{appid}/{version}/page-example.html). You can whitelist specific Referers to allow access to OBS from the mini program.
- Obtain the domain name of the mini program and use the wildcard (*) to match all subdomains of the mini program.
You can view the logs about the mini program's access to the OBS bucket and find the value of the Referer field in the bucket log file. For details about bucket logging, see Log Management Overview.
For details about the configuration procedure, see Using OBS Console. Table 4 describes the parameters.
Table 4 URL validation whitelist rules Parameter
Value
*appexample.com https://console.huaweicloud.com/*
- Use the wildcard (*) to match all subdomains of the mini program.
Toggle it on.
In some cases, the mini program may not send a Referer. Enabling this function ensures compatibility.
Leave it blank.
- Use the mini program to access OBS. The access is expected to be successful.
curl -e "https://appexample.com/kbaS3wM/page.html" https://test-bucket.obs.cn-north-4.myhuaweicloud.com/test.txt
- Use the mini program to access OBS (without a Referer). The access is expected to be successful.
Allowing Object Preview and Download on the OBS Console
With the URL validation whitelist, you can add the OBS console domain name to the whitelisted Referers to ensure normal management functions.
For details about the configuration procedure, see Using OBS Console. Table 5 describes the parameters.
Table 5 URL validation whitelist rules Parameter
Value
Add the console domain name and use a wildcard (*) to support all subdomains, ensuring that previews work properly in consoles across different regions.
Toggle it on.
Leave it blank.
Simulate access to the console. The access is expected to be successful. You can also preview and download files on the OBS console for verification.
curl -e "https://console.huaweicloud.com" https://test-bucket.obs.cn-north-4.myhuaweicloud.com/test.txt
Prohibiting Direct Access to OBS Via URLs
All access to OBS must come from specified websites. Direct access via URLs is prohibited.
This configuration will block null Referers, indicating that all direct access requests are prohibited. Since bookmarks, email links, and some browser plug-ins, download tools, or video players typically do not include Referers in their requests, these components may not function properly.
- Determine the Referer of a specified website.
Identify all possible combinations of domain names and protocols for the website to ensure that all legitimate access scenarios are covered.
For details about the configuration procedure, see Using OBS Console. Table 6 describes the parameters.
Table 6 URL validation whitelist rules Parameter
Value
- Identify all possible combinations of domain names and protocols for the website to ensure that all legitimate access scenarios are covered.
- Add the console domain and use a wildcard (*) to ensure that objects can be previewed properly in consoles across different regions.
Toggle it off.
Disabling this function can prevent direct access to OBS resources through URLs in the address bar.
Leave it blank.
- Simulate a request from a specified website to access OBS. The request is expected to be successful.
- Simulate a request to access OBS directly through a URL in the address bar. The request is expected to fail, and AccessDenied is returned.
- Simulate a request from another website to OBS. The request is expected to fail, and AccessDenied is returned.
curl -e "https://other.example.com" https://test-bucket.obs.cn-north-4.myhuaweicloud.com/test.txt
Best Practices
- Risk of bypassing URL validation via CDN caching: If both URL validation and CDN acceleration domain names are configured for an OBS bucket, an unauthorized request to OBS may directly hit the CDN cache node and obtain the cached content without triggering OBS validation. To ensure complete and effective protection, you must also configure URL validation rules on CDN. For details, see Filtering Requests from Specific Referers.
- Impact of browser Referrer-Policy: Modern browsers support the Referrer-Policy response header, which allows websites to control how the Referer header is sent in cross-domain requests. Under certain policies, such as no-referrer, the browser suppresses the Referer header, and OBS processes it as a null Referer. When configuring URL validation, you need to take this behavior into consideration (for example, when configuring whitelisted Referers, enable Null referer is allowed).
- Video playback compatibility: When a browser uses the native <video> tag to play videos, it sends requests to the video server to obtain media data. The Referers of these requests may be null or point to other pages. Therefore, OBS must allow access from null Referers (when configuring whitelisted Referers, enable Null referer is allowed). Otherwise, video playback will fail.
References
