If you are familiar with the JSON syntax and OBS bucket policies, you can code a bucket policy in the JSON view. There is no limit on the number of bucket policies (statements) for a bucket, but the JSON descriptions of all bucket policies in a bucket cannot exceed 20 KB in total.
Ways to Create a Custom Bucket Policy
You can use OBS Console, APIs, SDKs, OBS Browser+, or obsutil to create a bucket policy.
Using OBS Console
- In the navigation pane of OBS Console, choose Buckets.
- In the bucket list, click the bucket you want to operate. The Objects page is displayed.
- In the navigation pane, choose Permissions > Bucket Policies.
- In the upper right corner of the page, click JSON and then Edit.
- Edit the bucket policy. Below gives a bucket policy example in JSON:
In the following example, configure the actual values for the parameters:
test-obs-policy (the bucket policy name),
account ID (the account ID),
User ID (the IAM user ID), and
test-bucket/test.txt (object
test.txt in the
test-bucket bucket). To obtain the account ID and IAM user ID, see
Obtaining Account, IAM User, Project, User Group, Region, and Agency Information.
"Statement":[
"Sid":"test-obs-policy",
"Effect":"Allow",
"Principal":{
"ID":[
"domain/account ID",
"domain/account ID:user/User ID"
"Action":[
"PutObject",
"GetObject"
"Resource":[
"test-bucket/test.txt"
"Condition":{
"IpAddress":{
"SourceIp": [
"114.115.1.0/24"
Table 1 Parameters for creating a bucket policy in JSON
Parameter |
Description |
Sid |
Bucket policy name |
Effect |
Effect of the bucket policy. For details, see Bucket Policy Parameters. |
Principal |
Users the bucket policy is applied to. You can obtain the user ID on the My Credentials page by logging in to the console as the user to be authorized. Principals should be configured as follows:
Action |
Actions the bucket policy applies to. For details, see Bucket Policy Parameters. |
Resource |
Resources the bucket policy is applied to. For details, see Bucket Policy Parameters. |
Condition |
Conditions under which the bucket policy takes effect. For details, see Bucket Policy Parameters. |
- Click Save.
Using the GUI Tool - OBS Browser+
- Log in to OBS Browser+.
- Select the bucket you want and choose More > Bucket Policy. The window shown in Figure 1 is displayed.
Figure 1 Configuring a bucket policy
- Enter a bucket policy in the following format.
- Grant permissions to an account. In the following example, the account with ID 783fc6652cf246c096ea836694f71855 is granted permission to obtain log management information for bucket logging.bucket3.
"Statement": [
"Sid": "testing",
"Effect": "Allow",
"Principal": {
"ID": [
"domain/783fc6652cf246c096ea836694f71855:user/*"
"Action": [
"GetBucketLogging"
"Resource": [
"logging.bucket3"
Table 2 describes the parameters that you need to manually modify in the example above:
Table 2 Parameter changes
Item to Modify |
Description |
GetBucketLogging |
Value of the Action field that indicates all OBS-supported actions in the policy. The value is a case-insensitive string. The value can contain a wildcard character (*), for example, "Action":["List*", "Get*"], to apply all actions to the resources. You need to change the value as needed. For the actions supported by OBS, see Bucket Actions. |
Allow |
Value of the Effect field that indicates whether the permission in the policy is allowed or denied. The value must be Allow or Deny. |
logging.bucket3 |
The bucket on which the policy works. You can change the bucket name as needed. |
783fc6652cf246c096ea836694f71855 |
ID of an account. You can change it as needed. You can obtain the account ID on the bucket's Basic Information page. |
- Grant permissions to an IAM user. In the following example, the user (whose ID is 71f3901173514e6988115ea2c26d1999) under the account (whose ID is 219d520ceac84c5a98b237431a2cf4c2) is assigned the permission required to set log management for bucket logging.bucket3.
"Statement": [
"Sid": "testing",
"Effect": "Allow",
"Principal": {
"ID": [
"domain/219d520ceac84c5a98b237431a2cf4c2:user/71f3901173514e6988115ea2c26d1999"
"Action": [
"PutBucketLogging"
"Resource": [
"logging.bucket3"
Table 3 describes the parameters that you need to manually modify in the example above:
Table 3 Parameter changes
Item to Modify |
Description |
PutBucketLogging |
Allow |
logging.bucket3 |
219d520ceac84c5a98b237431a2cf4c2 |
You can click next to the target bucket to obtain the Account ID on the Basic Information page. |
71f3901173514e6988115ea2c26d1999 |
ID of a user under the account. You can change it as needed.
You can choose My Credentials from the username in the upper right corner of OBS Console to obtain the IAM User ID. |
For details about bucket policy parameters, see Bucket Policy Parameters.
Using the CLI Tool - obsutil
Command Line Structure
- In Windows
obsutil bucketpolicy obs://bucket -method=put -localfile=xxx [-config=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
- In Linux or macOS
./obsutil bucketpolicy obs://bucket -method=put -localfile=xxx [-config=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
Examples
Parameter Description
Parameter |
Optional or Mandatory |
Description |
bucket |
Mandatory |
The bucket name |
method |
Mandatory |
The method. Set this parameter to put when configuring a bucket policy. |
localfile |
Mandatory |
The path of the local policy file to import |
bucket-cname |
Optional (additional parameter) |
The user-defined domain name bound to the bucket
This parameter is only supported by obsutil 5.7.9 and later.
config |
The user-defined configuration file for executing the current command. For details about parameters that can be configured, see Configuration Parameters. |
e |
The endpoint |
i |
The user's AK |
k |
The user's SK |
t |
The user's security token |
