Updated on 2026-04-23 GMT+08:00
Bucket Inventories
A bucket inventory can list objects in a bucket, save object information in CSV files, and deliver the CSV files to the bucket specified for storing bucket inventory files. In this manner, you can easily manage objects in a bucket. A source bucket can also be the destination bucket.
  • A bucket inventory file can contain the following object related information: versions, sizes, storage classes, tags, encryption statuses, and last modification time.
  • You can encrypt bucket inventory files in SSE-KMS mode.
  • You can set the frequency (daily or weekly) for generating bucket inventory files.
  • You can also specify a bucket to store the generated bucket inventory files.
Table 1 Constraints on bucket inventories
Item
Bucket version
Inventories can be generated only for OBS 3.0 buckets, but the bucket that stores the inventory files can be any OBS version.
Maximum number of bucket inventories
A bucket can have a maximum of 10 inventories.
Source and destination buckets
  • The source bucket (for which a bucket inventory rule is configured) and the destination bucket (where the generated inventory files are stored) must belong to the same account.
  • The source and destination buckets must be in the same region.
  • The destination bucket cannot have server-side encryption enabled.
Functions
  • Inventory files must be in the CSV format.
  • Inventories can apply to all objects in a bucket or to a set of objects with the same name prefix.
  • The filter criteria of multiple inventory rules within the same bucket must not overlap.
    • If there is already an inventory rule for all objects in the bucket, any other inventory rule with an object name prefix specified cannot be created. To create a rule for only a set of objects, delete the inventory rule that applies to all objects first.
    • If there is already an inventory rule for a set of objects, a rule for all objects in the bucket cannot be created. To create a rule for all objects, delete all inventory rules that use a prefix filter.
    • Assume there is an inventory rule that uses the ab prefix as a filter. Any new inventory rule whose prefix overlaps with ab, such as a or abc, cannot be created. To create a rule with prefix a or abc, delete the overlapping rule first.
  • Only SSE-KMS can be used to encrypt bucket inventories.
Permissions
OBS must be authorized to upload inventory files to the destination bucket. The destination bucket needs a policy that grants OBS write permissions, with the Principal set to {"Service": "obs"}. For details, see Adding a Bucket Policy for the Destination Bucket.
  • The bucket inventory feature itself is free. You are billed only for the storage used by the generated inventory files.
  • The bucket inventory feature is not available to federated users.
Configuring a Bucket Inventory
Before the configuration, you need to understand what are source and destination buckets.
  • Source bucket: A source bucket is the bucket for which an inventory is configured. The inventory lists objects stored in the source bucket.
  • Destination bucket: A destination bucket is where generated inventory files are stored. A source bucket can also be the destination bucket. You can specify a name prefix for an inventory. Then generated inventory files will be named with the prefix and saved in the directory with the prefix. If you do not specify any name prefix for the inventory, the generated inventory files are stored in the root directory of the bucket.
    • Constraints on the destination bucket
      • The destination bucket must belong to the same account as the source bucket.
      • The destination bucket must be in the same region as the source bucket.
      • A bucket policy must be configured to grant OBS the permission to write objects to the destination bucket. For details, see Add a bucket policy for the destination bucket.
    • The destination bucket contains the following files:
      • A list of inventory files
      • The Manifest file that contains the list of all inventory files under a certain inventory configuration. For details about the Manifest file, see Manifest File.
You can use OBS Console or make a REST API call to configure a bucket inventory. If you use the OBS Console, a bucket policy is automatically generated for the destination bucket. If you call the REST API, you need to manually configure the bucket policy for the destination bucket.
  1. Add a bucket policy for the destination bucket.
    A bucket policy must be configured for the destination bucket, to grant the OBS system users the permission to write objects to the destination bucket. The following lists an example bucket policy. Replace destbucket with the actual name of the destination bucket.
    	"Statement": [
    			"Effect": "Allow",
    			"Sid": "1",
    			"Principal": {"Service": "obs"},
                            "Resource": ["destbucket/*"],
    			"Action": ["PutObject"]
  1. Configure a bucket inventory.
    For details, see Using OBS Console.
Content in an Inventory File
You can configure the content in an inventory file when creating the inventory. For details about all possible fields, see Table 2.
Table 2 Object metadata listed in an inventory file
Metadata
Bucket
The name of the source bucket
Key
The name of an object. Each object in a bucket has a unique key. (Object names in the inventory file are URL-encoded using UTF-8 character set and can be used only after being decoded.)
VersionId
The version ID of an object. If the value of IncludedObjectVersions in the inventory configuration is Current, this field is not included in the inventory file.
IsLatest
Whether the object version is the latest. If it is, the value of this field is True. This field is not included in the inventory file if IncludedObjectVersions in the inventory configuration is set to Current.
IsDeleteMarker
Whether versioning is enabled for the source bucket. If it is, deleting an object will create a new piece of object metadata and set IsDeleteMarker of the metadata to true. This field is not included in the inventory file if IncludedObjectVersions in the inventory configuration is set to Current.
Size
The object size, in bytes
LastModifiedDate
When an object was created or last modified.
ETag
Hexadecimal digest of the object MD5. ETag is the unique identifier of the object content. It can be used to identify whether the object content is changed. For example, if the ETag value is A when an object is uploaded but changes to B when the object is downloaded, it means that the object content has been changed.
StorageClass
The storage class of an object
  • STANDARD: the Standard storage class
  • STANDARD_IA (also WARM): the Infrequent Access storage class
  • COLD: the Archive storage class
  • DEEP_ARCHIVE: the Deep Archive storage class
IsMultipartUploaded
Whether an object is uploaded in the multipart mode.
ReplicationStatus
The cross-region replication status of an object
EncryptionStatus
The encryption status of an object
BucketKeyEnabled
The OBS bucket key status
Inventory File Name
The name of an inventory file is in the following format:
destinationPrefix/sourceBucketName/inventoryId/yyyy-MM-dd'T'HH-mm'Z'/files/UUID_index.csv
  • destinationPrefix indicates the prefix specified in the inventory configuration, which can be used to group inventory files. If no prefix is specified, the default prefix is BucketInventory.
  • sourceBucketName indicates the source bucket for which the inventory is configured. This field can prevent conflicts when inventory files of different source buckets are saved to the same destination bucket.
  • inventoryId can prevent conflicts when multiple inventory files of the same source bucket are sent to the same destination bucket.
  • yyyy-MM-dd'T'HH-mm'Z' indicates the start time and date when the inventory generation begins scanning the bucket. Objects uploaded to the source bucket after this time may not be listed in the inventory file.
  • UUID_index.csv indicates one of the inventory files.
Manifest File
If there are a large number of objects in a bucket, multiple inventory files may be generated for a single inventory configuration. It takes some time to generate these files. For example, if there are 200,000 objects in a bucket, it will take about 1.5 minutes to generate all inventory files. One or two hours after all inventory files are generated, a manifest.json file will be generated. The manifest.json file contains information about all inventory files generated this time, including:
  • sourceBucket: name of the source bucket
  • destinationBucket: name of the destination bucket
  • version: version of the inventory
  • fileFormat: format of inventory files
  • fileSchema: object metadata fields contained in the inventory files
  • files: list of all inventory files
  • key: inventory file name
  • size: size of an inventory file, in bytes
  • inventoriedRecord: number of records contained in an inventory file
The following is an example of a simple manifest.json file.
        "sourceBucket":"user001",
        "destinationBucket":"bucket001",
        "version":"2019-01-03",
        "fileFormat":"CSV",
        "fileSchema":"Bucket,Key,Size,LastModifiedDate,ETag,StorageClass,IsMultipartUploaded,ReplicationStatus,EncryptionStatus",
        "files":[
                        "key":"inventory/user001/test_id/2019-01-03T12-28Z/files/0000016813AF58E66806C1E2D7F15155_1.csv",
                        "size":6705647390,
                        "inventoriedRecord":70585762,
The name of a manifest file is as follows (for details about each field, see Inventory File Name):
destinationPrefix/sourceBucketName/inventoryId/yyyy-MM-dd'T'HH-mm'Z'/manifest.json
symlink.txt File
The symlink.txt file records the path of an inventory file. It helps quickly find all inventory files in big data scenarios. The symlink.txt file is Apache Hive-compatible. Hive can automatically discover the symlink.txt file and the inventory files listed within it. symlink.txt files are sorted by object name in lexicographical order.
The name of the symlink.txt file is as follows (for details about each field, see Inventory File Name):
destinationPrefix/sourceBucketName/inventoryId/hive/dt=YYYY-MM-DD-00-00/symlink.txt
Ways to Configure a Bucket Inventory
You can use OBS Console, APIs, or SDKs to configure a bucket inventory.
