Updated on 2026-09-10 GMT+08:00
Setting Image Effects
Setting the Brightness
You can use the GUI or code mode on OBS Console or make an API call to adjust the brightness of an image.
Table 1 describes the parameters.
This operation is represented by bright.
For details about how to use image styles, see Step 3: Creating an Image Style and Processing the Image.
Table 1 Brightness parameters
Value Description
Code Example
value
It adjusts the brightness of an image and ranges from -100 to 100.
The original brightness value is 0. A larger value means a higher level of brightness.
image/bright,50
Setting the Contrast
You can use the GUI or code mode on OBS Console or make an API call to adjust the contrast of an image.
Table 2 describes the parameters.
This operation is represented by contrast.
Table 2 Contrast parameters
Value Description
Code Example
value
It adjusts the contrast of an image and ranges from -100 to 100.
The original contrast value is 0. A larger value means a higher level of contrast.
image/contrast,-50
Setting the Sharpness
You can use the GUI or code mode on OBS Console or make an API call to adjust the sharpness of an image.
Table 3 describes the parameters.
This operation is represented by sharpen.
Table 3 Sharpness parameters
Value Description
Code Example
value
It adjusts the sharpness of an image and ranges from 50 to 399.
The recommended value is 100. Technically, a larger value means a clearer image, but a too large value will make the image grainy.
image/sharpen,100
Setting the Blur
You can use the GUI or code mode on OBS Console or make an API call to adjust the blur of an image.
Table 4 describes the parameters.
This operation is represented by blur.
Table 4 Blur parameters
Value Description
Code Example
r
It represents the blur radius. Its value ranges from 1 to 50.
A larger radius means a larger blurred area.
image/blur,r_3,s_2
s
It represents the standard deviation of normal distribution. Its value ranges from 1 to 50.
A large standard deviation significantly blurs, while a small standard deviation blurs less.
In GUI mode, the parameters r and s increase or decrease simultaneously.
Setting the Grayscale
You can edit code on OBS Console or make an API call to convert an image to grayscale.
Table 5 describes the parameters.
This operation is represented by colorspace.
Table 5 Grayscale parameters
Value Description
Code Example
value
It changes the color mode of an image. You can set the parameter to gray to convert the image to grayscale.
image/colorspace,gray
