- User Guide
- Best Practices
- FAQs
On this page
Show all
Help Center/
Managed Threat Detection/
User Guide/
Log Detection Management/
Viewing Log Detection Information
This section describes how to view the log detection information.
You have purchased MTD and created a detector in the current region.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the navigation pane on the left and choose Security & Compliance > Managed Threat Detection.
Figure 1 Home page of MTD - Choose Settings > Detection Settings in the left navigation pane.
- In the Log Data Sources pane, you can view the services for which the log data source detection function is enabled or disabled.
Figure 2 Log data sources
Table 1 Log detection options Options
Switch status
Whether to enable log detection for the service
: Enabled
: Disabled
Accumulated traffic
Size of detected logs since the log detection is enabled
Parent topic: Log Detection Management
