Updated on 2026-09-18 GMT+08:00
SQL Time Functions
Time functions can be used with __time. Any column stored as a millisecond timestamp can use the MILLIS_TO_TIMESTAMP function, or any column stored as a string timestamp can use the TIME_PARSE function. By default, the UTC time is used for time operations. You can change the time zone by setting the timezone parameter to the name of another time zone (for example, Asia/Shanghai) or to an offset (for example, +08:00).
Syntax
Statement
Format
CURRENT_DATE
Current date in the connected time zone.
SELECT CURRENT_DATE
CURRENT_TIMESTAMP
Current timestamp in the connected time zone.
SELECT CURRENT_TIMESTAMP
DATE_TRUNC(<unit>,<expr>)
Truncates the timestamp and returns it as a new timestamp.
SELECT DATE_TRUNC('minute',__time)
TIME_FORMAT(<expr>,<patten>,<timezone>))
Parses a character string into a timestamp using the specified pattern or ISO 8601 (for example, 2000-01-02T03:04:05Z). timezone (if specified) should be a time zone name (such as America/Los_Angeles) or an offset (such as +08:00), and will be used as the time zone of the string that does not include a time zone offset. The mode and time zone must be literal. If a character string cannot be parsed as a timestamp, null is returned.
SELECT TIME_FORMAT(__time,'yyyy-MM-dd HH:mm:ss','+08:00')
TIME_PARSE(<expr>,<pattern>,<timezone>)
SELECT TIME_PARSE("timestamp",'yyyy-MM-dd HH:mm:ss','+08:00')
MILLIS_TO_TIMESTAMP(expr)
Converts the timestamp to the time format.
SELECT MILLIS_TO_TIMESTAMP(expr)
TIMESTAMP_TO_MILLIS(expr)
Converts the time to the timestamp format.
SELECT TIMESTAMP_TO_MILLIS (expr)
EXTRACT(<extract_unit>FROM expr)
Extracts the time part from expr and returns it as a number.
SELECT
EXTRACT(MINUTE FROM __time)
TIMESTAMPDIFF(<unit>,<expr1>,<expr2>)
Returns the unit between expr1 and expr2.
SELECT
TIMESTAMPDIFF (minute, expr1, expr2)
TIME_SERIES
Completes the missing data in the query time window.
TIME_SERIES(__time, period, time_format, [padding_value],<timezone>)
TIME_FLOOR
Rounds down a timestamp and returns it as a new timestamp. The period can be any ISO 8601 period, such as P3M (three months) or PT12H (12 hours). If the time zone is provided, it should be the time zone name (for example, America/Los_Angeles) or offset (for example, -08:00).
TIME_FLOOR(<timestamp_expr>, <period>, [<origin>, [<timezone>]])
TIME_SERIES
The TIME_SERIES function is used to supplement the missing data in the query time window.
  • This function must be used together with ORDER BY and must be the first parameter of ORDER BY.
  • The OFFSET statement cannot be used in the query statement.
  • The TIME_SERIES function cannot be used as a subquery.
Syntax
time_series(__time, period, time_format, [padding_value], <timezone>)
Parameter description
Table 1
__time
Time sequence.
period
Time window size (ISO 8601 standard). For example, P1M (1 month), P1D (1 day), PT1H (1 hour), PT1M (1 minute), and PT1S (1 second).
time_format
Time format of the returned result. (For details, see Joda DateTimeFormat.)
padding_value
Supplemented content. Options:
  • 0 or zero: By default, the missing value is set to 0.
  • null: The missing value is set to null.
  • last: The missing value is set to the value corresponding to the previous time point.
  • next: The missing value is set to the value corresponding to the next time point.
  • avg: The missing value is set to the average value of two adjacent time points.
timezone
Time zone, for example, UTC+08:00 (Beijing).
Returned Data Type
The value is of the bigint type.
Example
Supplement data based on the time granularity of a day, set the missing value to 0, and add a time zone.
  • Query and analysis statement
    select time_series(__time, 'P1D', 'yyyy-MM-dd HH:mm:ss', '0', '+08:00') as t_time, count(*) as num group by t_time order by t_time
  • Query and analysis result
    t_time
    num
    2021-10-01 08:00:00
    5
    2021-10-02 08:00:00
    0
    2021-10-03 08:00:00
    0
    2021-10-04 08:00:00
    21
    2021-10-05 08:00:00
    17
    2021-10-06 08:00:00
    0
    2021-10-07 08:00:00
    34
CURRENT_DATE/CURRENT_TIMESTAMP
CURRENT_DATE returns the ISO 8601 time (UTC time) of 00:00 on the current day. This function can be used to calculate timestamps.
CURRENT_TIMESTAMP returns the ISO 8601 time (UTC time) of the current time. This function can be used to calculate timestamps.
  1. Example field
    __time: 2023-02-14T02:35:56.706Z
  2. Query and analysis statement
    select __time,CURRENT_DATE, CURRENT_TIMESTAMP,CURRENT_TIMESTAMP
  3. Query and analysis result
    Table 2 Query and analysis result
    __time
    CURRENT_DATE
    CURRENT_TIMESTAMP
    2023-02-14T00:00:00.000Z
    2023-02-14T14:35:57.000Z
DATE_TRUNC(<unit>, <timestamp_expr>)
Truncates <timestamp_expr> to the precision specified in <unit>, fills in 0, and returns the value as a new timestamp. The unit is case-insensitive, and can be milliseconds, second, minute, hour, day, week, month, quarter, year, decade, century, or millennium.
  1. Example field
    SELECT __time,DATE_TRUNC('minute', __time),DATE_TRUNC('day', __time),DATE_TRUNC('year', __time)
    Table 3 Query and analysis result
    __time
    EXPR$1
    EXPR$2
    EXPR$3
    2023-02-15T08:50:00.000Z
    2023-02-15T00:00:00.000Z
    2023-01-01T00:00:00.000Z
TIME_PARSE(<string_expr>, [<pattern>, [<timezone>]])/TIME_FORMAT(<timestamp_expr>, [<pattern>, [<timezone>]])
TIME_PARSE parses the given string <timestamp_expr> into a timestamp according to the custom <pattern> parameter and Joda DateTimeFormat. If <pattern> is not specified, the character string is parsed according to ISO 8601 by default. <timezone> is optional.
TIME_FORMAT parses the given timestamp <timestamp_expr> into a string according to the custom <pattern> parameter and Joda DateTimeFormat. If <pattern> is not specified, the timestamp is parsed according to ISO 8601 by default. <timezone> is optional.
  1. Example field
    __time: 2023-02-16T07:38:25.306Z
    start_time:2023-02-14 02:35:56
    SELECT __time,TIME_PARSE(start_time,'yyyy-MM-dd HH:mm:ss'),TIME_FORMAT(__time,'yyyy-MM-dd HH:mm:ss')
    Table 4 Query and analysis result
    __time
    EXPR$1
    EXPR$2
    2023-02-14T02:35:56.000Z
    2023-02-16 07:38:25
MILLIS_TO_TIMESTAMP(millis_expr)/TIMESTAMP_TO_MILLIS(timestamp_expr)
MILLIS_TO_TIMESTAMP converts a number of milliseconds into a timestamp in ISO 8601 format. The converted parameter can be used to calculate timestamps. TIMESTAMP_TO_MILLIS converts a timestamp to a number of milliseconds.
  1. Example field
    __time: 2023-02-16T07:54:15.106Z,start_time: 1676534055106
    SELECT __time,MILLIS_TO_TIMESTAMP(start_time),TIMESTAMP_TO_MILLIS(__time)
    Table 5 Query and analysis result
    __time
    EXPR$1
    EXPR$2
    2023-02-16T07:54:05.000Z
    1676534055106
TIME_EXTRACT(<timestamp_expr>,[<unit>,[<timezone>]])/EXTRACT(<unit> FROM timestamp_expr)
TIME_EXTRACT extracts time from timestamp_expr and returns it as a number. The unit can be EPOCH (Unix time in seconds since the epoch), SECOND (second of the current minute), MINUTE (minute of the current hour), HOUR (hour of the current day), DAY (day of the current month), DOW (day of the current week), DOY (day of the current year), WEEK (week of the current year), MONTH (month of the current year), QUARTER (quarter of the current year), or YEAR (current year). <timezone> is optional. EXTRACT is short for TIME_EXTRACT.
  1. Example field
    Table 6 Query and analysis result
    __time
    EXPR$1
    EXPR$2
    1676534055106
TIME_FLOOR rounds down a timestamp and returns it as a new timestamp. The period can be any ISO 8601 period, such as P3M (three months) or PT12H (12 hours). If the time zone is provided, it should be the time zone name (for example, America/Los_Angeles) or offset (for example, -08:00).
  1. Example field
    __time 2025-03-05T16:53:21.689+08:00
    SELECT  __time,TIME_FLOOR(__time,'PT1M') AS t
    Table 7 Query and analysis result
    __time
    t
    2025-03-05T16:53:21.687+08:00
    2025-03-05T16:53:00.000+08:00
Reference Information
  • Unit
    unit
    second
    Second
    minute
    Minute
    hour
    Hour
    day
    Day
    week
    Week
    month
    Month
    quarter
    Quarter
    year
    Year
  • extract_unit
    extract_unit
    SECOND
    Second
    MINUTE
    Minute
    HOUR
    Hour
    DAY
    Day of a month
    DOW
    Day of a week
    DOY
    Day of a year
    WEEK
    Week of a year
    MONTH
    Month
    QUARTER
    Quarter
    YEAR
    Year
