Other SQL Functions
SQL functions also support some conversion types and logical operations such as CASE and WHEN. For details, see Table 1.
Syntax
SELECT CAST(fieldname1 AS VARCHAR) AS fieldname1_str
Other Function Statements
| Keyword | Description | Example |
CAST(value AS TYPE) | Converts the data type. Data types can be converted only to varchar or float. | SELECT fieldname1, CAST(fieldname1 AS VARCHAR) |
CASE WHEN boolean_expr1 THEN result1 \[ WHEN boolean_expr2 THEN result2 ... \] \[ ELSE resultN \] END | Simple CASE function. | SELECT CASE WHEN httpStatus = 200 THEN 1 ELSE 0 END |
NULLIF(value1, value2) | If value1 is equal to value2, null is returned. Otherwise, value1 is returned. | SELECT fieldname1, fieldname2, NULLIF(fieldname1, fieldname2) |
NVL(expr,expr-for-null) | If expr is null or an empty string, this function returns expr-for-null. | SELECT NVL(str1, 'expr-for-null') |
