Overview
Updated on 2025-01-24 GMT+08:00
Structured Query Language (SQL) is a programming language used to control database access and manage data in databases. LTS SQL provides statements for querying structured data in log streams. In this document, SQL refers to LTS SQL.
SQL consists of commands and functions that are used to manage databases and database objects. When using this language, comply with the rules for using expressions and texts. In addition to SQL syntax reference, this document also provides information about expressions, functions, and operators. Basic SQL query statements are as follows.
Currently, this function is available to all users in regions CN South-Guangzhou, CN North-Beijing4, CN East-Shanghai1, CN East-Shanghai2, CN-Hong Kong, CN Southwest-Guiyang1, AP-Singapore, and CN North-Beijing1. It is also available to whitelisted users in regions CN South-Shenzhen, AP-Bangkok, ME-Riyadh, and AP-Jakarta.
Syntax
SELECT [ ALL | DISTINCT ] { * | exprs }
FROM { <subquery>}
[ WHERE where_condition ]
[ GROUP BY [ col_name_list ]
[ HAVING expr ]
[ ORDER BY expr [ ASC | DESC ], expr [ ASC | DESC ], ... ]
[ LIMIT limit ]
[ OFFSET offset ]
Data Types
Table 1 lists the data types supported by SQL query. If the data type of the current field needs to be changed, it will be converted. For example, a field of the string type is converted to the long type. After the data type of a field is converted, the default value is displayed. For example, if the data of the string type is converted to the data of the long type, the default value 0 of the long type is displayed. Similarly, when a null value is converted to a non-null value, the default value is used. For example, when a null value of the string type is converted to a number, the default value 0 is returned.
In the SQL syntax, characters must be enclosed in single quotation marks ('). Fields or table names are not enclosed or are enclosed with double quotation marks ("). For example, 'msg' indicates the character string msg, and msg or "msg" indicates the structured msg field.
Table 1 Data types supported in SQL queries
Native Data Type
Default Value
STRING
Native string type
FLOAT
0.0
Native float type
LONG
0
Native long type
Query Statements
Table 2 SQL query statements
Statement
Example
DISTINCT
Only distinct values are returned.
SELECT DISTINCT visitCount
FROM
Indicates the source data set of the queried data. It can be the structured data of the current log stream or a subset of this data.
If FROM is not specified, the structured data of the current log stream is queried by default. If the data source to be queried is a subset, you need to compile a subquery statement.
SELECT visitCount
WHERE
Specifies the filter criteria. Arithmetic operators, relational operators, and logical operators are supported. You can enter the filtering condition in where_condition.
SELECT visitCount
WHERE visitCount > 0
GROUP BY
Specifies the grouping field. Single-field grouping and multi-field grouping are supported. You can enter the structured field list in col_name_list.
SELECT host, count(*) AS pv
GROUP BY host
HAVING
Used only with GROUP BY. This statement specifies the structured field used to filter the GROUP BY results.
GROUP BY host
HAVING pv > 10
ORDER BY
Fields that follow must be used for GROUP BY. The query results of GROUP BY can be sorted by any structured field.
GROUP BY host
ORDER BY pv
ASC/DESC
ASC (default) sorts from the lowest value to the highest value. DESC sorts from the highest value to the lowest value.
GROUP BY host
ORDER BY pv DESC
LIMIT
Limits the number of structured logs returned in the query result. A maximum of 100,000 structured logs can be returned for each query.
If the LIMIT statement is not used, the latest 100 records in the query result are returned by default.
SELECT host
LIMIT 100
Examples
Table 3 Examples of common SQL query statements
Query Requirement
Query Statement
Standard query
SELECT "field" WHERE "field" = 'value'
Number of rows
SELECT count(*)
Column alias
SELECT count(*) AS "pv"
Deduplication
SELECT DISTINCT("field")
Pagination
SELECT "field" LIMIT 100
Sorting
SELECT "__time" ORDER BY "__time"
Grouping
SELECT "field" GROUP BY "field"
Statistics by group
SELECT "field",count(*) GROUP BY "field"
Fuzzy search
SELECT "field" LIKE 'value%'
Sum
SELECT sum("field")
Maximum value
SELECT max("field")
Minimum value
SELECT min("field")
Average value
SELECT avg("field")
SQL nested subquery
SELECT sum(pv) FROM (SELECT "field",count(*) AS "pv" GROUP BY "field")
HAVING clause filtering
SELECT "field",count(*) AS "pv" GROUP BY "field" HAVING "pv" > 10
Query containing GET and POST requests
SELECT * WHERE "request_method" IN ('GET', 'POST')
Query without GET and POST requests
SELECT * WHERE "request_method" NOT IN ('GET', 'POST')
Logs of non-GET requests
SELECT * WHERE "request_method" != 'GET'
Logs of successful GET request with the 200 status code and request time is less than 60 seconds
SELECT * WHERE "request_method" = 'GET' AND "request_time" < 60
Logs of requests whose time is greater than or equal to 60 seconds and less than 200 seconds
SELECT * WHERE "request_ time" >=60 and "request_time" < 200
Logs of GET or POST requests
SELECT * WHERE "request_method" = 'GET' OR "request_method" = 'POST'
The following reference statements contain all basic query syntax and are constructed based on structured logs of Elastic Load Balance (ELB).
SELECT url AS Url, host AS Host, failure_rate AS FailureRate,
CONCAT(CAST(access_count AS varchar), ' times') AS "All",
CONCAT(CAST(rsp_200_count AS varchar), ' times') AS "COUNT_200"
FROM ( SELECT
CONCAT(host, CASE WHEN STRPOS(router_request_uri, '?') = 0 THEN router_request_uri ELSE SUBSTR(router_request_uri, 1, 1) END) AS url,
host,count(1) AS access_count,
SUM(CASE WHEN status = 200 THEN 1 ELSE 0 END) AS "rsp_200_count",
(CASE WHEN COUNT(1) < 30 THEN 0 ELSE round(SUM(CASE WHEN status >= 400 THEN 1 ELSE 0 END) * 100.0 / COUNT(1), 2) END) AS failure_rate
WHERE host NOT IN ('monitor-new.olayc.cn')
GROUP BY host,router_request_uri
HAVING router_request_uri NOT IN ('/robots.txt', '/null', '/undefined')
ORDER BY FailureRate DESC
LIMIT 100
