Updated on 2026-05-26 GMT+08:00
Deleting the Route for an Enhanced Datasource Connection
Delete a route that is no longer used.
Notes and Constraints
A custom route table cannot be deleted if it is associated with a subnet.
  1. Log in to the DLI management console.
  2. In the navigation pane, choose Datasource Connections.
  3. On the displayed Enhanced tab, locate the enhanced datasource connection where you want to delete a route and then delete a route.
    • Method 1:
      1. On the Enhanced tab, locate the enhanced datasource connection where you want to delete a route and click Manage Route in its Operation column.
      2. Locate the route to be deleted and click Delete in the Operation column.
      3. In the dialog box displayed, click OK.
    • Method 2:
      1. On the Enhanced tab page displayed, locate the enhanced connection from which the route needs to be deleted, click More in the Operation column, and select Delete Route.
      2. In the Delete Route dialog box displayed, confirm the route information.
      3. Click Yes.
