Help Center/ Data Lake Insight/ User Guide/ Configuring DLI to Read and Write Data from and to External Data Sources/ Managing Enhanced Datasource Connections/ Deleting an Enhanced Datasource Connection
Updated on 2025-08-15 GMT+08:00
Delete an enhanced datasource connection that is no longer used on the console.
- Log in to the DLI management console.
- In the navigation pane on the left, choose Datasource Connections.
- On the Enhanced tab page displayed, locate the enhanced datasource connection to be deleted and click Delete in the Operation column.
- In the dialog box displayed, click Yes.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
