Creating a SQL Job Template
DLI allows you to create custom templates or save currently used SQL statements as templates for quick and convenient SQL operations. Once a template is saved, you can execute SQL operations directly through the template without the need to write SQL statements.
SQL templates include sample templates and custom templates. The default sample template contains 22 standard TPC-H query statements, which can meet most TPC-H test requirements. For details, see TPC-H Sample Data in the SQL Templates Preset on DLI.
In the navigation pane on the left, choose Job Templates > SQL Templates. In the upper right corner of the displayed page, click Settings. In the displayed Settings dialog box, choose whether to display templates by group.
If you enable Display by Group, the display options are Expand the first group, Expand all, and Collapse all.
You can create a template on either the Job Templates or the SQL Editor page.
- To create a template on the Job Templates page:
- On the left of the management console, choose Job Templates > SQL Templates.
- On the SQL Templates page, click Create Template to create a template.
Enter the template name, SQL statement, and description information. For details, see Table 1.
Figure 1 Creating a template
Table 1 Parameter descriptions Parameter
Name
Indicates the template name.
- A template name can contain only digits, letters, and underscores (_), but cannot start with an underscore (_) or contain only digits. It cannot be left empty.
- The template name can contain a maximum of 50 characters.
Statement
SQL statement to be saved as a template.
Description of the template you create.
Group
- Use existing
- Use new
- Do not use
Group Name
If you select Use existing or Use new, you need to enter the group name.
- Click OK.
- To create a template on the SQL Editor page:
- On the left of the management console, click SQL Editor.
- In the SQL job editing area of the displayed SQL Editor page, click More in the upper right corner and choose Save as Template.
- Click OK.
Submitting a SQL Job Using a Template
- On the SQL Templates page, select a template and click Execute in the Operation column. The SQL Editor page is displayed, and the corresponding SQL statement is automatically entered in the SQL job editing window.
- In the upper right corner of the SQL job editing window, Click Execute to run the SQL statement. After the execution is complete, you can view the execution result below the current SQL job editing window.
Searching for a SQL Job Template
On the SQL Templates page, you can enter the template name keyword in the search box on the upper right corner to search for the desired template.
Modifying a SQL Job Template
Only custom templates can be modified. To modify a template, perform the following steps:
- On the SQL Templates page, locate the target template and click Modify in the Operation column.
- In the displayed Modify Template dialog box, modify the template name, statement, and description as required.
- Click OK.
Deleting a Template
On the SQL Templates page, select one or more templates to be deleted and click Delete to delete the selected templates.
