- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Before You Start
- Permissions Management
Exclusive ServiceComb Engine
- Creating a ServiceComb Engine
Managing ServiceComb Engines
- Viewing ServiceComb Engine Information
- Obtaining the Service Center Address of a ServiceComb Engine
- Obtaining the Configuration Center Address of a ServiceComb Engine
- Viewing the Instance Quota of a ServiceComb Engine
- Viewing the Configuration Item Quota of a ServiceComb Engine
- Configuring Backup and Restoration of a ServiceComb Engine
- Managing Public Network Access for a ServiceComb Engine
- Viewing ServiceComb Engine Operation Logs
- Upgrading a ServiceComb Engine Version
- Deleting a ServiceComb Engine
- Changing ServiceComb Engine Specifications
- Managing Security Authentication for a ServiceComb Engine
- Managing Tags
- Using ServiceComb Engines
- Registry/Configuration Center
- Key Operations Recorded by CTS
Best Practices
- CSE Best Practices
ServiceComb Engines
ServiceComb Engine Application Hosting
- Hosting Spring Cloud Applications Using Spring Cloud Huawei SDK
- Hosting a Java Chassis Application
- Registry/Configuration Centers
Developer Guide
- Overview
- Developing Microservice Applications
- Preparing the Environment
- Connecting Microservice Applications
- Deploying Microservice Applications
- Using ServiceComb Engine Functions
- Appendix
API Reference
- Before You Start
- API Overview
- Calling APIs
- Examples
CSE API
- API Calling
- Dynamic Configuration
Engine Management
- Querying the Flavor List of a Microservice Engine
- Querying the Microservice Engine List
- Creating a Microservice Engine
- Querying Microservice Engine Details
- Querying Details About a Microservice Engine Job
- Querying Details About the Microservice Engine Quota
- Deleting a Microservice Engine
- Upgrading a Microservice Engine
- Updating Microservice Engine Configurations
- Changing Microservice Engine Specifications
- Retrying an Exclusive ServiceComb Engine Job
- Updating Microservice Engine Details
- Querying the Engine Job List
- Querying an RBAC Token
Microservice Governance
- Querying the Governance Policy List
- Creating a Dark Launch Policy
- Querying a Dark Launch Policy
- Deleting a Dark Launch Policy
- Changing a Governance Policy
- Deleting a Governance Policy
- Querying Governance Policy Details
- Creating a Governance Policy
- Querying the Governance Policy List of a Specified Kind
- Querying Microservice Thresholds in Batches
- Querying Microservice Reporting Information
- Querying the Reported Information List
- Nacos API
ServiceComb API
- API Calling
- Authentication
Microservice
- Querying Information About a Microservice
- Deleting Definition Information About a Microservice
- Querying Information About All Microservices
- Creating Static Information for a Microservice
- Deleting Static Information About Microservices in Batches
- Modifying Extended Attributes of a Microservice
- Querying the Unique Service or Schema ID of a Microservice
- Schema
Microservice Instance
- Registering a Microservice Instance
- Querying a Microservice Instance Based on service_id
- Deregistering a Microservice Instance
- Querying Details About a Microservice Instance
- Modifying the Extended Information About a Microservice Instance
- Modifying Status of a Microservice Instance
- Sending Heartbeat Information
- Querying a Microservice Instance by Filter Criteria
- Querying Microservice Instances in Batches
- Dependency
- Configuration Management
- Appendixes
- Change History
- SDK Reference
- Precautions When Using Huawei Cloud CSE
- Nacos Engines
ServiceComb Engines
- How Do I Perform Local Development and Testing?
- How Can I Handle a Certificate Loading Error?
- What If the Header Name Is Invalid?
- What Is the Performance Loss of Mesher?
- Why Is "Version validate failed" Displayed When I Attempt to Connect to the Service Center?
- Why Is "Not enough quota" Displayed When I Attempt to Connect to the Service Center?
- What Should I Do If the Service Registration Fails After IPv6 Is Enabled for the Exclusive ServiceComb Engine with Security Authentication Enabled?
- What Is Service Name Duplication Check?
- Why Do I Have to Define Service Contracts?
- Why Are Microservice Development Framework and Netty Versions Unmatched?
- What Do I Need to Know Before Upgrading an Exclusive ServiceComb Engine?
- What Must I Check Before Migrating Services from the Professional to the Exclusive Microservice Engine?
- Why Is "Duplicate cluster name" Displayed?
- Error Message "the subnet could not be found" Is Displayed When the Access Address Fails to Be Processed During Engine Creation
- Why Is Error "does not match rule: {Max: 100, Regexp: ^[a-zA-Z0-9]{1,160}$|^[a-zA-Z0-9][a-zA-Z0-9_\-.]{0,158}[a-zA-Z0-9]$}"}" Reported?
- What Should I Do If SpringCloud Applications Fail to Connect to the Configuration Center of ServiceComb Engine 2.x?
- Why Could My the Global Configuration Not Be Modified?
- Obtain Configurations Failed
- Videos
On this page
Help Center/
Cloud Service Engine/
User Guide/
Exclusive ServiceComb Engine/
Managing ServiceComb Engines/
This section describes how to view the instance quota and quota usage of a ServiceComb engine.
- Log in to CSE.
- Choose Exclusive ServiceComb Engines.
- Click the target engine.
- In the Service Discovery and Configuration area, view the instance quota and quota usage of the microservice engine.
Parent topic: Managing ServiceComb Engines
