Managing Deployment Architectures
After a deployment architecture is created, you can modify, delete, view, copy, and export it. This meets your requirements for architecture design, iterative optimization, information retention, and cross-scenario reuse. Architecture management is more flexible, efficient, and adapts to dynamic changes during software development and O&M.
Modifying a Deployment Architecture
- Log in to COC.
- In the navigation pane, choose Resilience Center > Architecture Design. The Architecture Design page is displayed.
- On the displayed page, locate the target deployment architecture and click Modify in the Operation column.
- Modify related parameters as required. For details, see Table 1. Figure 1 Modifying a deployment architecture
Table 1 Basic information parameters Parameter
Architecture Name
Name of the deployment architecture
The name must be unique and can contain a maximum of 128 characters, including letters, digits, hyphens (-), underscores (_), and spaces. It cannot start or end with a space.
Architecture Description
Description of the deployment architecture.
Enterprise Project
Select the enterprise project to which the deployment architecture belongs.
- Click OK.
Copying a Deployment Architecture
- Log in to COC.
- On the displayed page, locate the target deployment architecture and choose More > Copy in the Operation column. Figure 2 Copying a deployment architecture
- (Optional) Set its parameters to the same as those of the replicated one. You can also adjust them as required. For details, see Table 2. Figure 3 Copying a deployment architecture
Table 2 Basic information parameters Parameter
Architecture Name
Application
Select the application to which the architecture belongs.
After the architecture is created, its associated applications cannot be modified.
Enterprise Project
- Click OK.
Exporting a Deployment Architecture
- Log in to COC.
- On the displayed page, locate the target deployment architecture and choose More > Export in the Operation column.
- In the displayed dialog box, select the format to be exported. Figure 4 Exporting a deployment architecture
- Click OK. The deployment architecture in the format selected in 4 is automatically exported.
You can view the exported deployment architecture file on the local PC or share it with related personnel.
Deleting a Deployment Architecture
- Log in to COC.
- On the displayed page, locate the target deployment architecture and click Delete in the Operation column.
- Enter DELETE and click OK. The deleted architecture information is no longer displayed in the deployment architecture list.Figure 5 Deleting a deployment architecture
