Updated on 2024-08-27 GMT+08:00
Creating a Security Report
You can obtain security reports to learn about the security status of your assets in a timely manner. CFW sends log reports to you based on the time period and receiving mode you configured.
This section describes how to create a security report.
  • Up to 10 security reports can be created for a CFW instance.
  • A security report is retained for only three months. You are advised to periodically download security reports for audit.
  • A custom security report cannot be modified. If you need to modify a custom security report, delete it and create a new one.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, click and choose Security & Compliance > Cloud Firewall. The Dashboard page will be displayed.
  4. (Optional) Switch firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
  5. In the navigation tree on the left, choose System Management > Security Report. The Security Report page is displayed.
  6. Click Create Template. For details about the parameters, see Parameters of the security report template.
    Table 1 Parameters of the security report template
    Report Name
    Name of the custom security report
    Report Type
    • Daily
      Statistical period: 00:00:00 to 24:00:00 every day
      A report will be sent to the recipients the day after it is generated.
    • Weekly
      Statistical period: 00:00:00 on Monday to 24:00:00 on Sunday
      A report will be sent to the recipients at the specified time after it is generated.
    • Custom: Customize a time range.
      Statistical Period: Configure a statistical period for your report.
      A report will be sent to the specified recipients after it is generated.
    Statistical Period
    If Report Type is set to Custom, you need to set Statistical Period.
    Report Schedule
    When Report Type is set to Daily or Weekly, you need to set the report sending time. By default, the log report of the previous statistical period is sent.
    To ensure correctness, the report sending time may be delayed.
    Recipient Group
    Select a topic from the drop-down list to configure the endpoints for receiving the log report.
    If there are no topics, click View Topic and perform the following steps to create a topic:
    1. Create a topic. For details, see Creating a Topic.
    2. Add one or more subscriptions to the topic. You will need to provide a phone number, email address, function, platform application endpoint, DMS endpoint, or HTTP/HTTPS endpoint for receiving alarm notifications. For details, see Adding a Subscription.
    3. Confirm the subscription. After the subscription is added, confirm the subscription.
  7. Click OK. A security report is created.
