Creating a Packet Capture Task to Check the Network Status
You can create network packet capture tasks to locate network faults and attacks.
Specification Limitations
Only the professional edition instances can capture network packets.
- Only one packet capture task can be executed at a time.
- A maximum of 20 packet capture tasks can be created every day.
- A maximum of 1 million packets can be captured.
- Click in the upper left corner of the management console and select a region or project.
- In the navigation pane on the left, click and choose . The Dashboard page will be displayed.
- (Optional) Switch firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation tree on the left, choose System Management > Packet Capture.
- Click Create Capture Task and configure parameters.
Table 1 Packet capture task parameters Parameter Name
Example Value
Task Name
Task name.
It must meet the following requirements:- Only uppercase letters (A to Z), lowercase letters (a to z), numbers (0 to 9), and the following special characters are allowed: -_
- Enter up to 30 characters.
cfw
Max. Packets Captured
Maximum number of captured packets. Enter an integer in the range 1 to 1,000,000.
100000
Capture Duration (min)
Maximum duration for capturing packets. Enter an integer in the range 1 to 10.
3
IP Type
IP address type for packet capture. The value is IPv4 by default.
IPv4
Protocol Type
Protocol type of captured packets. It can be:
- Any
- TCP
- UDP
- ICMP
Any
Source Address
It can be:- A single IP address, for example, 192.168.10.5
- Consecutive IP addresses, for example, 192.168.0.2-192.168.0.10
- Address segment, for example, 192.168.2.0/24
192.168.10.5
Source Port
(Optional) Source port.
The input rules are as follows:- If this parameter is left blank, it indicates all port numbers (1 to 65535).
- Enter a single port number in the range 1 to 65535.
80
Destination Address
192.168.10.6
Destination Port
(Optional) Destination port.
- Click OK.
Related Operations
- To copy a task, click Copy in its Operation column. In the displayed dialog box, enter the task name and click OK.
- To stop a packet capture task, click Stop in its Operation column.
- To delete packet capture tasks, select them and click Delete above the list.
- Viewing a Packet Capture Task
- Downloading Packet Capture Results
