Adding a Protected VPC
After configuring a VPC border firewall, you need to configure routes to forward traffic to CFW.
This section describes how to quickly configure and modify routes.
You have configured the VPC border firewall. For details, see Enterprise Router Mode (New).
Step 1: Add VPC Attachments
For details, see Adding VPC Attachments to an Enterprise Router.
To use the enterprise router of account A to protect VPCs under account B, share the router with account B. For details, see Creating a Sharing. After the sharing is successful, add attachment to account B. Subsequent configurations are still performed under account A.
Step 2: Configure Associations and Propagations
- In the upper left corner, click
and choose Networking > Enterprise Router. Click Manage Route Table. - Configure associations. On the route table configuration page, select the association table, click the Associations tab. On the displayed page, click Create Association. Set the parameters and click OK.
Create at least two associations. An association is required for each protected VPC you add.
For example, select attachment vpc-1 for VPC1 and vpc-2 for VPC2. To add VPC3 for protection, add an association and select attachment vpc-3.
Figure 1 Creating an association
Table 1 Association parameters Parameter
Attachment Type
Select VPC.
Select an item from the Attachment drop-down list.
- Configure propagations. Select the propagation route table, click the Propagations tab, and click Create Propagation. For more information, see Table 2. Figure 2 Creating a propagation
Table 2 Propagation parameters Parameter
Attachment Type
Select VPC.
- Add at least two propagations. A propagation is required for each protected VPC you add.
For example, select attachment vpc-1 for VPC1 and vpc-2 for VPC2. To add VPC3 for protection, add a propagation and select attachment vpc-3.
- After a propagation is created, its route information will be extracted to the route table of the enterprise router, and a propagation route will be generated. In the same route table, the destinations of different propagation routes may be the same, and cannot be modified or deleted.
- You can add static routes for the attachments in a route table. The destinations of static routes in a table must be unique, and can be modified or deleted.
- If a static route and a propagation route in the same route table happen to use the same destination, the static route takes effect first.
Step 3: Modify VPC Route Tables
- In the navigation pane, choose Network Console > Virtual Private Cloud > Route Tables.
- In the Name/ID column, click the route table name of a VPC. The Summary page is displayed.
- Click Add Route. In the displayed dialog box, configure the parameters.
You need to add routes for at least two VPCs. Each time a protected VPC is added, you need to add a route for that VPC.
Table 3 Route parameters Parameter
Destination Address Type
Select IP address.
Destination
Enter the CIDR block that the traffic is sent to.
For example, for inter-VPC protection, enter the CIDR block of VPC 2 in the Destination of the route of VPC 1.
Next Hop Type
Select Enterprise Router from the drop-down list.
Next Hop
Select a resource for the next hop.
The enterprise routers you created are displayed in the drop-down list.
(Optional) Description of a route.
Enter up to 255 characters. Angle brackets (< or >) are not allowed.
- Click OK.
Related Operations
- For details about VPC border firewalls, see VPC Border Firewall Overview.
- For details about how to configure a VPC border firewall, see Enterprise Router Mode (New).
