Kubernetes 1.29 Release Notes
CCE has passed the Certified Kubernetes Conformance Program and is a certified Kubernetes offering. CCE now supports Kubernetes 1.29 cluster features. This section describes the changes in Kubernetes 1.29.
Indexes
New and Enhanced Features
- The load balancer IP mode for Services is in the alpha state.
The load balancer IP mode for Services is promoted to alpha. Kubernetes 1.29 adds the ipMode field to the Services' status field for configuring traffic forwarding from Services within a cluster to pods. If ipMode is set to VIP, traffic delivered to a node with the destination set to the load balancer's IP address and port will be redirected to the target node by kube-proxy. If it is set to Proxy, traffic delivered to a node will be sent to the load balancer and then redirected to the target node by the load balancer. This feature addresses the issue of load balancer functions being missed due to traffic bypassing it. For details, see Load Balancer IP Mode for Services.
- The nftables proxy mode is in the alpha state.
The nftables proxy mode is promoted to alpha. This feature allows kube-proxy to run in nftables mode. In this mode, kube-proxy configures packet forwarding rules using the nftables API of the kernel netfilter subsystem. For details, see nftables proxy mode.
- Garbage collection for unused container images is in the alpha state.
The garbage collection for unused container images is promoted to alpha. This feature allows you to specify the maximum time a local image can be unused for each node. If the time expires, the image will be garbage collected. To configure the setting, specify the ImageMaximumGCAge field for kubelet. For details, see Garbage collection for unused container images.
- PodLifecycleSleepAction is in the alpha state.
PodLifecycleSleepAction is promoted to alpha. This feature introduces the sleep hook to the container lifecycle hooks. You can pause a container for a specified duration after it starts or before it is stopped by enabling this feature. For details, see Hook handler implementations.
- KubeletSeparateDiskGC is in the alpha state.
KubeletSeparateDiskGC is promoted to alpha. With this feature enabled, container images and containers can be garbage collected even if they are on separate file systems.
- matchLabelKeys and mismatchLabelKeys are in the alpha state.
matchLabelKeys and mismatchLabelKeys are promoted to alpha. With these features enabled, the matchLabelKeys and mismatchLabelKeys fields are added to the pod affinity and anti-affinity configurations. This allows for configurations of more affinity and anti-affinity policies between pods. For details, see matchLabelKeys and mismatchLabelKeys.
- The clusterTrustBundle projected volumes are in the alpha state.
The clusterTrustBundle projected volumes are promoted to alpha. With this feature enabled, the clusterTrustBundle projected volume source injects the contents of one or more ClusterTrustBundle objects as an automatically-updating file. For details, see clusterTrustBundle projected volumes.
- Pulling images based on runtime classes of pods is in the alpha state.
Pulling images based on runtime classes is promoted to alpha. With this feature enabled, the kubelet references container images by a tuple (of image name or runtime handler) rather than just the image name or digest. Your container runtime may adapt its behavior based on the selected runtime handler. Pulling images based on runtime classes will be helpful for VM based containers. For details, see Image pull per runtime class.
- The PodReadyToStartContainers condition is in the beta state.
The PodReadyToStartContainers condition is promoted to beta. Kubernetes 1.29 introduces the PodReadyToStartContainers condition to the pods' status field. If it is set to true, the sandbox of a pod is ready and service containers can be created. This feature enables cluster administrators to gain a clearer and more comprehensive view of pod sandbox creation completion and container readiness. This enhanced visibility allows them to make better-informed decisions and troubleshoot issues more effectively. For details, see PodReadyToStartContainers Condition Moves to Beta.
- Two job-related features are in the beta state.
- Pod replacement policy (beta)
The pod replacement policy feature moves to beta. This feature ensures that a pod is replaced only when it reaches the Failed state, which means that status.phase becomes Failed. It does not recreate a pod when the deletion timestamp is not empty and the pod is still being deleted. This prevents two pods from occupying index and node resources concurrently.
- Backoff limit per index (beta)
The backoff limit per index moves to beta. By default, pod failures for indexed jobs are counted and restricted by the global limit of retries, specified by .spec.backoffLimit. This means that if there is a consistently failing index in a job, pods specified by the job will be restarted repeatedly until pod failures exhaust the limit. Once the limit is reached, the job is marked as failed, and pods for other indexes in the job may never start. The feature allows you to complete execution of all indexes, despite some indexes failing, and to better use the compute resources by avoiding unnecessary retries of consistently failing indexes.
- Native sidecar containers are in the beta state.
Native sidecar containers are promoted to beta. The restartPolicy field is added to initContainers. When this field is set to Always, the sidecar container is enabled. The sidecar container and service container are deployed in the same pod. This cannot prolong the pod lifecycle. Sidecar containers are commonly used in scenarios such as network proxy and log collection. For details, see Sidecar Containers.
- The legacy ServiceAccount token cleaner is in the beta state.
Legacy ServiceAccount token cleaner is promoted to beta. It runs as part of kube-controller-manager and checks every 24 hours to see if any auto-generated legacy ServiceAccount token has not been used in a specific amount of time (one year by default, specified by --legacy-service-account-token-clean-up-period). If so, the cleaner marks those tokens as invalid and adds the kubernetes.io/legacy-token-invalid-since label whose value is the current date. If an invalid token is not used for a specific period of time (one year by default, specified by --legacy-service-account-token-clean-up-period), the cleaner deletes it. For details, see Legacy ServiceAccount token cleaner.
- DevicePluginCDIDevices is in the beta state.
DevicePluginCDIDevices moves to beta. With this feature enabled, plugin developers can use the CDIDevices field added to DeviceRunContainerOptions to pass CDI device names directly to CDI enabled runtimes.
- PodHostIPs is in the beta state.
The PodHostIPs feature moves to beta. With this feature enabled, Kubernetes adds the hostIPs field to Status of pods and downward API to expose node IP addresses to workloads. This field specifies the dual-stack protocol version of the host IP address. The first IP address is always the same as the host IP address.
- The API Priority and Fairness (APF) feature is in the GA state.
APF moves to GA. APF classifies and isolates requests in a more fine-grained way. It improves max-inflight limitations. It also introduces a limited amount of queuing, so that the API server does not reject any request in cases of very brief bursts. Requests are dispatched from queues using a fair queuing technique so that, for example, a poorly-behaved controller does not cause others (even at the same priority level) to become abnormal. For details, see API Priority and Fairness.
- APIListChunking is in the GA state.
The APIListChunking feature moves to GA. This feature allows clients to perform pagination in List requests to avoid performance problems caused by returning too much data at a time.
- ServiceNodePortStaticSubrange is in the GA state.
The ServiceNodePortStaticSubrange feature moves to GA. With this feature enabled, kubelet calculates the size of reserved IP addresses based on the ranges of the NodePort Services and divides node ports into static band and dynamic band. During automatic node port assignment, dynamic band is preferentially assigned, which helps avoid port conflicts during static band assignment. For details, see ServiceNodePortStaticSubrange.
- The phase transition timestamp of PersistentVolume (PV) is in the beta state.
The PV phase transition timestamp moves to beta. With this feature enabled, Kubernetes adds the lastPhaseTransitionTime field to the status field of a PV to indicate the time when the PV phase changes last time. Cluster administrators are now able to track the last time a PV transitioned to a different phase, allowing for more efficient and informed resource management. For details, see PersistentVolume Last Phase Transition Time in Kubernetes.
- ReadWriteOncePod is in the GA state.
The ReadWriteOncePod feature moves to GA. With this feature enabled, you can set the access mode to ReadWriteOncePod in a PersistentVolumeClaim (PVC) to ensure that only one pod can modify data in the volume at a time. This can prevent data conflicts or damage. For details, see ReadWriteOncePod.
- CSINodeExpandSecret is in the GA state.
The CSINodeExpandSecret feature moves to GA. This feature allows secret authentication data to be passed to a CSI driver for use when a node is added.
- The CEL-based CRD verification capability is in the GA state.
The CEL-based CRD verification capability moves to GA. With this feature enabled, you are allowed to use the CEL to define validation rules in CRDs, which are more efficient than webhook. For details, see CRD verification rules.
API Changes and Removals
- The time zone of a newly created CronJob cannot be configured using TZ or CRON_TZ in .spec.schedule. Use .spec.timeZone instead. Cron jobs that have been created are not affected by this change.
- The alpha API ClusterCIDR is removed.
- The startup parameter --authentication-config is added to kube-apiserver to specify the address of the AuthenticationConfiguration file. This startup parameter is mutually exclusive with the --oidc-* startup parameter.
- The API version kubescheduler.config.k8s.io/v1beta3 of KubeSchedulerConfiguration is removed. Migrate kube-scheduler configuration files to kubescheduler.config.k8s.io/v1.
- The CEL expressions are added to v1alpha1 AuthenticationConfiguration.
- The ServiceCIDR type is added. It allows you to dynamically configure the IP address range used by a cluster to allocate the Service ClusterIPs.
- The startup parameters --conntrack-udp-timeout and --conntrack-udp-timeout-stream are added to kube-proxy. They are options for configuring the kernel parameters nf_conntrack_udp_timeout and nf_conntrack_udp_timeout_stream.
- Support for CEL expressions is added to WebhookMatchCondition of v1alpha1 AuthenticationConfiguration.
- The type of PVC.spec.Resource is changed from ResourceRequirements to VolumeResourceRequirements.
- onPodConditions in PodFailurePolicyRule is marked as optional.
- The API version flowcontrol.apiserver.k8s.io/v1beta3 of FlowSchema and PriorityLevelConfiguration has been promoted to flowcontrol.apiserver.k8s.io/v1, and the following changes have been made:
- PriorityLevelConfiguration: The .spec.limited.nominalConcurrencyShares field defaults to 30 if the field is omitted. To ensure compatibility with 1.28 API servers, specifying an explicit 0 value is not allowed in the v1 version in 1.29. In 1.30, explicit 0 values will be allowed in this field in the v1 API. The flowcontrol.apiserver.k8s.io/v1beta3 APIs are deprecated and will no longer be served in 1.32.
- The kube-proxy command line document is updated. kube-proxy does not bind any socket to the IP address specified by --bind-address.
- The selectorSpread scheduler plugin is replaced by podTopologySpread.
- If CSI-Node-Driver is not running, NodeStageVolume calls will be retried.
- ValidatingAdmissionPolicy type checking now supports CRDs. To use this feature, the ValidatingAdmissionPolicy feature gate must be enabled.
- The startup parameter --nf-conntrack-tcp-be-liberal is added to kube-proxy. You can configure it by setting the kernel parameter nf_conntrack_tcp_be_liberal.
- The startup parameter --init-only is added to kube-proxy. Setting the flag makes kube-proxy init container run in the privileged mode, perform its initial configuration, and then exit.
- The fileSystem field of container is added to the response body of CRI. It specifies the file system usage of a container. Originally, the fileSystem field contains only the file system of the container images.
- All built-in cloud providers are disabled by default. If you still need to use them, you can configure the DisableCloudProviders and DisableKubeletCloudCredentialProvider feature gates to disable or enable cloud providers.
- --node-ips can be used in kubelet to configure IPv4/IPv6 dual-stack. If --cloud-provider is set to external, you are allowed to use --node-ips to configure IPv4/IPv6 dual-stack for node IP addresses. To use --node-ips, you need to enable the CloudDualStackNodeIPs feature gate.
Incompatible Changes
In Kubernetes 1.29, the startup behavior of kube-proxy has been modified. This update allows kube-proxy to use a value smaller than the node sysctl setting. For example, if the kernel value of nf_conntrack_max on a node is set to 1000000, but kube-proxy calculates a value of 131072, the value 131072 calculated by kube-proxy will be used.
Community PR: https://github.com/kubernetes/kubernetes/pull/120448
Enhanced Kubernetes 1.29 on CCE
During a version maintenance period, CCE periodically updates Kubernetes 1.29 and provides enhanced functions.
For details about cluster version updates, see Patch Versions.
References
For more details about the performance comparison and functional evolution between Kubernetes 1.29 and other versions, see Kubernetes v1.29 Release Notes.
