Updated on 2026-09-21 GMT+08:00
Custom Agencies for Add-ons
Some CCE add-ons rely on cloud service resources such as compute, storage, networking, and monitoring. These add-ons require authorization to perform operations on these cloud resources. To improve cluster security, CCE has significantly enhanced the credential sources used by add-ons.
  • PoLP: You can assign a dedicated agency to each add-on and grant only the IAM permissions required for its operation. This ensures that each add-on can access only the resources and services it needs.
  • Eliminating static credentials: Add-ons no longer store credentials statically in secrets. Instead, they use pod identities to associate temporary, automatically rotated credentials with pods.
    • Static credentials can be removed only from clusters v1.28.15-r80, v1.29.15-r40, v1.30.14-r40, v1.31.14-r0, v1.32.9-r0, v1.33.7-r0, v1.34.2-r0, or later.
If you do not configure a custom agency when installing the add-ons listed below, CCE will automatically create and use a default add-on agency. This default agency contains all permissions required by the target add-on. Do not modify its authorization settings. The default agency and its corresponding authorization settings are listed below.
Add-on
Add-on Version
Module/Component
Default Agency
Authorization Content
CCE Container Storage (Everest)
2.5.1 or later
everest-csi-controller (the everest-csi-controller component)
CCECSIAgency
  • CCEClusterCSIEVSPolicy
  • CCEClusterCSIOBSPolicy
  • CCEClusterCSISFSGeneralPolicy
  • CCEClusterCSISFSTurboPolicy
  • CCEClusterResourceOrderPolicy
  • CCEClusterCSIOBSEncryptionPolicy
everest-csi-driver (the everest-csi-driver component)
CCECSIDriverAgency
  • CCEClusterCSIEVSAttachPolicy
  • CCEClusterCSIOBSMountPolicy
CCE Cluster Autoscaler
1.28.227, 1.29.189, 1.30.155, 1.31.117, 1.32.93, 1.33.86, 1.34.22, or later
cluster-autoscaler (the autoscaler component)
CCENodeScaleAgency
CCEClusterNodeAutoscalingPolicy
CCE Secrets Manager for DEW
1.1.106 or later
dew-provider (the dew-provider component)
CCESecretEncryptAgency
CCEClusterKMSPolicy
Cloud Native Log Collection
1.7.9 or later
log-manager (the log-operator, otel-collector, and otel-collector-event components)
CCELogManageAgency
CCEClusterLogPolicy
log-reporter (the fluent-bit component)
CCELogReportAgency
None
Volcano Scheduler
(An agency is required only when colocation of online and offline services is enabled.)
1.21.4 or later
volcano (the volcano-agent component)
CCEEnhanceSchedulerAgency
CCEClusterHybridDeployPolicy
CCE Cloud Bursting Engine for CCI
1.5.82 or later
virtual-kubelet (virtual-kubelet, bursting-virtual-kubelet, resource-syncer, bursting-resource-syncer, and resource-gc-jobs)
CCEBurstingAgency
CCEClusterVirtualKubeletPolicy
Velero
All
velero
CCEClusterBackupAgency
Do not delete the agency used by an add-on, and ensure that the agency has not expired. Otherwise, the add-on may fail to function properly.
Configuring an Agency for an Add-on
You can use the default agency or a custom agency.
To create a default agency for an add-on, ensure that your account has the following IAM permissions:
  • iam:agencies:createAgency for creating an agency
  • iam:permissions:grantRoleToAgency: for granting permissions to an agency
  • iam:roles:listRoles for listing permissions
  • iam:agencies:listAgencies for querying agencies based on specified conditions
When installing an add-on, select Create automatically in the Agency Settings area. CCE will automatically create and use the default agency for the add-on. If the default agency already exists, it will not be created.
If you need to customize the permissions used by an add-on, you can use a custom agency. Ensure that the created agency has been assigned the required permissions. Otherwise, the add-on functions may not function properly.
  • Create a custom agency of the cloud service type on the Agencies page of the IAM console and authorize it for CCE. For details, see Creating an Agency and Assigning Permissions.
  • You need to authorize the created custom agency. CCE has preset the permissions required for using add-ons as system policies. You can use the system policies for authorization or use custom policies.
When installing an add-on, select Use existing in the Agency Settings area and select one from the drop-down list.
System Policies
System Policy
Permissions for automatically subscribing to yearly/monthly resources in a CCE cluster
Permissions for using EVS volumes in a CCE cluster
Permissions for using OBS volumes in a CCE cluster
Permissions for using encrypted OBS volumes in a CCE cluster, which are used only for CCE agency authorization
Permissions for using SFS 3.0 volumes in a CCE cluster
Permissions for using SFS Turbo volumes in a CCE cluster
Permissions for mounting EVS volumes in a CCE cluster, which are used only for CCE agency authorization
Permissions for mounting OBS volumes in a CCE cluster, which are used only for CCE agency authorization
CCEClusterKMSPolicy
Permissions for mounting encrypted credentials located outside the cluster to containers
CCEClusterLogPolicy
Permissions for using log collection in a CCE cluster
Permissions for using node auto scaling in a CCE cluster
Permissions for using CCE Cloud Bursting Engine for CCI in a CCE cluster
Required for colocation of online and offline services and only used for CCE agency authorization
