Configuring Cross-Origin Access for LoadBalancer Ingresses
The same-origin policy of browsers prevents a web page loaded by one origin from directly requesting resources from another origin in web development. Cross-origin resource sharing (CORS) is a secure solution that allows cross-origin requests.
CORS can be used in the following scenarios:
- Separated frontend and backend: In web development, frontend applications are often deployed under a domain name (for example, app.example.com), while the backend API service uses a different domain name (for example, api.example.com). This can cause cross-origin resource sharing to be blocked, but CORS can help resolve this issue by allowing the frontend to obtain data from the API service.
- Third-party service integration: If your website needs to call third-party APIs (for example, the APIs of a map service or social media login platform), configure CORS to enable cross-origin resource sharing.
- CDN: If your website is using a CDN to provide static resources from a domain name that differs from the primary domain, you can use CORS to load these resources.
- ELB is necessary for accessing ingresses across different origins. To use cross-origin access, submit a service ticket to request the enabling of ELB cross-origin access.
- If you enable cross-origin access for a LoadBalancer ingress, you will not be able to enable URL redirection, URL rewriting, or HTTP to HTTPS redirection.
- A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
- v1.23: v1.23.18-r10 or later
- v1.25: v1.25.16-r0 or later
- v1.27: v1.27.16-r0 or later
- v1.28: v1.28.13-r0 or later
- v1.29: v1.29.8-r0 or later
- v1.30: v1.30.4-r0 or later
- Other clusters of later versions
- The cluster can be accessed using kubectl. For details, see Accessing a Cluster Using kubectl.
Notes and Constraints
- This feature is only available when dedicated load balancers are used.
- This feature relies on the ELB advanced forwarding policies. Once enabled, the priority is not determined by the domain name or path matching. You can customize the forwarding policy priority as needed. For details about the forwarding policy priority, see Forwarding Policy Priorities of LoadBalancer Ingresses.
Using kubectl
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
An example YAML file of an ingress created using an existing load balancer is as follows:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/elb.class: performance # Only dedicated load balancers are supported. kubernetes.io/elb.cors-allow-origin: 'http://example.com' # The origin that can be accessed kubernetes.io/elb.cors-allow-headers: 'fake-header-1' # The allowed request header kubernetes.io/elb.cors-expose-headers: 'fake-header-2' # The response header to be exposed kubernetes.io/elb.cors-allow-methods: 'GET,POST' # The allowed HTTP request methods kubernetes.io/elb.cors-allow-credentials: 'true' # Credentials can be sent. kubernetes.io/elb.cors-max-age: '3600' # The cache duration of a pre-check request kubernetes.io/elb.port: '80' kubernetes.io/elb.id: 3f5906fb-2b07-4e33-b3fe-b095f03d86a6 spec: rules: - host: example.com http: paths: - path: / backend: service: name: nginx-03657 port: number: 80 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cceTable 1 Annotations for cross-origin access Parameter
Type
Example Value
Array[string]
Specify Access-Control-Allow-Origin for the origin that can be accessed.
Options:
- Wildcard (*): indicates that all domain names can be accessed.
- Domain names: start with http:// or https://. Level-1 wildcard domain names are supported. The format is http(s)://example.com or http(s)://example.com:port, where the port number ranges from 1 to 65535.
A maximum of 32 values can be set. Use commas (,) to separate them.
Array[string]
Specify Access-Control-Allow-Headers for allowed request headers.
A value can contain a maximum of 32 characters and cannot start or end with an underscore (_) or hyphen (-). Only uppercase letters, lowercase letters, digits, underscores (_), and hyphens (-) are allowed. A maximum of 32 values can be set. Use commas (,) to separate them.
Array[string]
Specify Access-Control-Expose-Headers for custom response headers that can be accessed by a cross-origin request. This allows you to retrieve non-standard response headers using client-side JavaScript code.
Array[string]
Specify Access-Control-Allow-Methods for allowed HTTP request methods.
You can enter multiple values by separating them with commas (,). The supported methods include GET, POST, PUT, DELETE, HEAD, OPTIONS and PATCH.
String
Specify Access-Control-Allow-Credentials to control the sending of credentials (such as cookies).
Options:
- true: Credentials can be sent.
- false: Credentials cannot be sent.
Once configured, the settings cannot be deleted. To remove the configuration, use kubernetes.io/elb.cors-disabled to delete all cross-origin settings.
String
Specify Access-Control-Max-Age for the cache duration of a CORS pre-check request. Unit: second. Value range: -1 to 172800
Properly configure this parameter based on service requirements. If the value is too low, pre-check requests may happen frequently. If the value is too high, the CORS policy may not take effect immediately.
String
Disable all cross-origin settings. Options:
- true: disables all cross-origin settings. The parameter values in the YAML file will not be deleted, but all cross-origin settings will not take effect.
- false: default value, indicating that the cross-origin settings take effect based on your settings.
kubernetes.io/elb.cors-disabled: 'true'
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress/ingress-test created
- Check the created ingress.
kubectl get ingress
If information similar to the following is displayed, the ingress has been created:NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce example.com **.**.**.** 80 10s
Verifying Cross-Origin Access
- Log in to the ELB console, locate the load balancer used by the ingress, and check whether the forwarding policy of the listener contains cross-origin configurations.
- Use curl to send a cross-origin request and check the response header.
curl -X OPTIONS -H 'Origin: {Origin}' {Accessed ingress URL} -I
For example, if the origin is example.com and the accessed ingress URL is 121.**.**.**:80, run the following command:
curl -X OPTIONS -H 'Origin: example.com' 121.**.**.**:80 -I
The Access-Control-** request header will be added to the original backend response.
HTTP/1.1 200 OK Access-Control-Allow-Headers: fake-header-1 Access-Control-Expose-Headers: fake-header-2 Access-Control-Allow-Methods: GET, POST Access-Control-Allow-Credentials: true Access-Control-Max-Age: 3600
