Updated on 2026-08-13 GMT+08:00
CCE Events
CCE can report a range of events to AOM when a cluster is running. You can add event alarms as required to monitor the health of cluster data plane and control plane components. This helps you quickly identify and resolve problems, ensuring cluster stability and reliability.
Data Plane Events
Table 1 Workload events
Category Event Name Severity Description
Pod
PodOOMKilling
Major
Check whether the pod exits due to OOM.
This event is reported by CCE Node Problem Detector (1.18.41 or later) and Cloud Native Log Collection (1.3.2 or later).
Pod
FailedStart
Major
Check whether the pod is started.
Pod
FailedPullImage
Major
Check whether the pod has pulled an image.
Pod
BackOffStart
Major
Check whether the pod fails to restart.
Pod
FailedScheduling
Major
Check whether the pod has been scheduled.
Pod
BackOffPullImage
Major
Check whether the pod has pulled an image after a retry.
Pod
FailedCreate
Major
Check whether the pod is created.
Pod
Unhealthy
Minor
Check whether the pod health check is successful.
Pod
FailedDelete
Minor
Check whether the workload is deleted.
Pod
ErrImageNeverPull
Minor
Check whether the workload has pulled an image.
Pod
FailedScaleOut
Minor
Check whether replicas can be increased for scaling the workload.
Pod
FailedStandBy
Minor
Check whether the pod enters the standby state.
Pod
FailedReconfig
Minor
Check whether the pod configuration is updated.
Pod
FailedActive
Minor
Check whether the pod is activated.
Pod
FailedRollback
Minor
Check whether the pod is rolled back.
Pod
FailedUpdate
Minor
Check whether the pod is updated.
Pod
FailedScaleIn
Minor
Check whether the pod scale-in fails.
Pod
FailedRestart
Minor
Check whether the pod is restarted.
Deployment
SelectorOverlap
Minor
Check whether label selectors in the cluster conflict.
Deployment
ReplicaSetCreateError
Minor
Check whether a workload ReplicaSet can be created.
Deployment
DeploymentRollbackRevisionNotFound
Minor
Check whether the Deployment rollback version is available.
DaemonSet
SelectingAll
Minor
Check whether the workload label selector is correctly configured.
Job
TooManyActivePods
Minor
Check whether there are still active pods after the number of pods in a job reaches the preset value.
Job
TooManySucceededPods
Minor
Check whether there are extra running pods after the number of pods in a job reaches the preset value.
CronJob
FailedGet
Minor
Check whether the CronJob can be obtained.
CronJob
FailedList
Minor
Check whether the list of pods can be obtained.
CronJob
UnexpectedJob
Minor
Check whether there are any unknown jobs.
Table 2 Network events
Service
CreatingLoadBalancerFailed
Minor
Check whether the load balancer is created.
Service
DeletingLoadBalancerFailed
Minor
Check whether the load balancer is deleted.
Service
UpdateLoadBalancerFailed
Minor
Check whether the load balancer is updated.
Table 3 Node events
Node
Rebooted
Major
Check whether the node is restarted.
Node
NodeNotSchedulable
Major
Check whether the node is schedulable.
Node
NodeNotReady
Major
Check whether the node is running normally.
Node
NodeCreateFailed
Major
Check whether the node is created.
Node
FailedToAttachDetach
Major
Check whether there are disks that fail to be attached or detached on the node.
Node
KUBELETIsDown
Minor
Check whether kubelet is running normally on the node.
Node
NodeHasInsufficientMemory
Minor
Check whether the node memory is sufficient.
Node
UnregisterNetDevice
Minor
Check whether the node is associated with any unregistered network device.
Node
NetworkCardNotFound
Minor
Check the node network interface status.
Node
KUBEPROXYIsDown
Minor
Check whether kube-proxy is running normally on the node.
Node
NodeOutOfDisk
Minor
Check whether the node disk space is normal.
Node
TaskHung
Minor
Check whether there are any suspended tasks on the node.
Node
CIDRNotAvailable
Minor
Check whether the node CIDR block is available.
Node
ConntrackFull
Minor
Check whether the connection tracking table on the node is full.
Node
NodeHasDiskPressure
Minor
Check whether the node disk space is sufficient.
Node
NodeInstallFailed
Minor
Check whether the node is managed in the cluster.
Node
KernelOops
Minor
Check whether the OS kernel of the node becomes faulty.
Node
OOMKilling
Minor
  • The memory used by pods on the node exceeds the limit. As a result, the process is terminated.
  • The memory used by pods on the node does not exceed the limit, but the available memory of the node is insufficient. As a result, OOM occurs.
Node
DOCKERIsDown
Minor
Check whether the container runtime of the node is normal.
Node
CIDRAssignmentFailed
Minor
Check whether a CIDR block is allocated to the node.
Node
DockerHung
Minor
Check whether the Docker process on the node is suspended.
Node
FilesystemIsReadOnly
Minor
Check whether the file system of the node is read-only.
Node
NTPIsDown
Minor
Check whether NTP is running normally on the node.
Node
NodeUninstallFailed
Minor
Check whether the node is uninstalled.
Node
AUFSUmountHung
Minor
Check whether detaching the node disk is suspended.
Node
CNIIsDown
Minor
Check whether the CNI add-on on the node becomes faulty.
Namespace
DeleteNodeWithNoServer
Minor
Check whether the discarded node is cleared.
Table 4 Storage events
PV
DetachVolumeFailed
Minor
Check whether the block storage is detached.
PV
VolumeUnknownReclaimPolicy
Minor
Check whether a volume reclaim policy is specified.
PV
SetUpAtVolumeFailed
Minor
Check whether the volume is mounted.
PV
VolumeFailedRecycle
Minor
Check whether the volume is reclaimed.
PV
WaitForAttachVolumeFailed
Minor
Check whether the block storage is attached to the node.
PV
VolumeFailedDelete
Minor
Check whether the volume is deleted.
PV
MountDeviceFailed
Minor
Check whether the device is mounted.
PV
TearDownAtVolumeFailed
Minor
Check whether the volume is unmounted.
PV
UnmountDeviceFailed
Minor
Check whether the device is unmounted.
PV
AttachVolumeFailed
Minor
Check whether block storage is detached from the node.
PVC
VolumeResizeFailed
Minor
Check whether the volume capacity is expanded.
PVC
ClaimLost
Minor
Check whether the PVC is normal.
PVC
ProvisioningFailed
Minor
Check whether the volume is created.
PVC
ProvisioningCleanupFailed
Minor
Check whether the volume has been cleared.
PVC
ClaimMisbound
Minor
Check whether the PVC is bound to an incorrect volume.
Table 5 Auto scaling events
Autoscaler
ScaleUpTimedOut
Major
Check whether scaling out nodes in the node pool timed out.
Autoscaler
NodePoolAvailable
Major
Check whether the node pool resources are sufficient.
Autoscaler
ScaleDown
Major
Nodes in the cluster are being scaled in.
Autoscaler
NotTriggerScaleUp
Major
Check whether node scale-out is triggered.
Autoscaler
DeleteUnregistered
Major
Check whether unregistered nodes are deleted.
Autoscaler
ScaleDownEmpty
Major
Check whether idle nodes are scaled in.
Autoscaler
ScaleDownFailed
Major
Check whether nodes are scaled in.
Autoscaler
FailedToScaleUpGroup
Major
Check whether an error occurs during node scale-out in the node pool.
Autoscaler
ScaledUpGroup
Major
Check whether the node pool is scaled out.
Autoscaler
ScaleUpFailed
Major
Check whether the node is scaled out.
Autoscaler
FixNodeGroupSizeDone
Major
Check whether the number of nodes in the node pool is restored.
Autoscaler
NodeGroupInBackOff
Major
Check whether there are any rollback retries during node pool scaling.
Autoscaler
FixNodeGroupSizeError
Major
Autoscaler
NodePoolSoldOut
Major
Autoscaler
TriggeredScaleUp
Major
Autoscaler
StartScaledUpGroup
Major
Check whether node pool scale-out is started.
Autoscaler
DeleteUnregisteredFailed
Major
HPA
InvalidTargetRange
Major
  • Invalid extendedhpa.metrics is configured in annotations of HPA.
  • The metric type in spec of HPA is incorrect.
HPA
FailedGetScale
Major
HPA failed to obtain the resource object to be scaled.
HPA
FailedComputeMetricsReplicas
Major
An error occurs when the number of replicas to be adjusted for resources is calculated. For example, metric-server is unavailable, resource metric collection fails, or the CPU usage is incorrectly set.
You can run the following command to view details:
kubectl describe horizontalpodautoscaler <hpa-name>
HPA
FailedGetObjectMetric
Major
Failed to obtain the metrics of the specified object (such as PVC and ConfigMaps).
HPA
FailedGetPodsMetric
Major
Failed to obtain pod resource metrics (resource usages of a pod).
HPA
FailedGetResourceMetric
Major
Failed to obtain cluster resource metrics (resource usages of a cluster).
HPA
FailedGetContainerResourceMetric
Major
Failed to obtain the resource metrics of a container.
HPA
FailedGetExternalMetric
Major
Failed to obtain external metrics.
HPA
FailedRescale
Major
Failed to update the desired number of replicas of the resource object to be scaled.
HPA
SuccessfulRescale
Minor
The desired number of replicas of the resource object to be scaled has been updated.
CronHPA
ScaleFailed
Major
CronHPA failed to update the desired number of replicas of the resource object to be scaled.
CronHPA
FailedGetHorizontalPodAutoscaler
Major
CronHPA failed to query the associated HPA object. (Generally, kube-apiserver cannot respond.)
CronHPA
FailedGetHpaScale
Major
CronHPA failed to obtain the resource object to be scaled.
CronHPA
UpdateHPAFailed
Major
CronHPA failed to update the associated HPA object.
CronHPA
UpdateHPASuccess
Minor
CronHPA has updated the associated HPA object.
CronHPA
SkipUpdateHPA
Minor
CronHPA skips updating the associated HPA object.
CronHPA
SkipUpdateTarget
Minor
CronHPA skips updating the number of replicas of the resource object to be scaled.
CronHPA
UpdateTargetSuccess
Minor
CronHPA has updated the number of replicas of the resource object to be scaled.
CustomedHPA
FailedSetPolicySettings
Major
Failed to parse the cooldown period of CustomedHPA.
CustomedHPA
FailedSubmitRule
Major
CustomedHPA failed to process schedule rules or metric rules.
CustomedHPA
FailedComputeReplicas
Major
CustomedHPA failed to trigger resource scaling based on the compute metrics.
CustomedHPA
FailedScale
Major
CustomedHPA failed to update the desired number of replicas of the resource object to be scaled. (Generally, kube-apiserver cannot respond).
CustomedHPA
MetricScaleSuccess
Minor
CustomedHPA triggers resource scaling based on the metric rule.
CustomedHPA
CronScaleSuccess
Minor
CustomedHPA triggers resource scaling based on the periodic rule.
Control Plane Events
Table 6 Control plane events
Event ID Severity Description
Internal error
Major
Check whether an internal error occurs in the cluster.
External dependency error
Major
Check whether an error occurs in cluster external dependencies.
Failed to initialize process thread
Major
Check whether a cluster initialization thread is executed.
Failed to update database
Major
Check whether the database for the cluster is updated.
Failed to create node by nodepool
Major
Check whether nodes are created in the node pool.
Failed to delete node by nodepool
Major
Check whether nodes are deleted from the node pool.
Failed to create yearly/monthly subscription node
Major
Check whether the yearly/monthly node is created in the cluster.
Failed to cancel the authorization of accessing the image of the master.
Major
When creating a cluster, check whether the authorization for the resource tenant to access the master node image is canceled.
Failed to create the virtual IP for the master
Major
When creating a cluster, check whether the virtual IP address is allocated.
Failed to delete the node VM
Major
Check whether the node (VM) is deleted from the cluster.
Failed to delete the security group of node
Major
Check whether the node security group is deleted.
Failed to delete the security group of master
Major
Check whether the master node security group is deleted.
Failed to delete the security group of port
Major
Check whether the security group for the network interface of the master node is deleted from the cluster.
Failed to delete the security group of eni or subeni
Major
Check whether the security group for the network interface or supplementary network interface is deleted from the cluster.
Failed to detach the port of master
Major
Check whether the network interface is detached from the master node in the cluster.
Failed to delete the port of master
Major
Check whether the network interface of the master node is deleted from the cluster.
Failed to delete the master VM
Major
Check whether the master node (VM) is deleted from the cluster.
Failed to delete the key pair of master
Major
Check whether the key pair of the master node is deleted from the cluster.
Failed to delete the subnet of master
Major
Check whether the subnet of the master node is deleted from the cluster.
Failed to delete the VPC of master
Major
Check whether the VPC of the master node is deleted from the cluster.
Failed to delete certificate of cluster
Major
Check whether the certificate is deleted from the cluster.
Failed to delete the server group of master
Major
Check whether the master node (ECS) is deleted from the cluster.
Failed to delete the virtual IP for the master
Major
Check whether the virtual IP address is deleted from the cluster.
Failed to get floating IP of the master
Major
Check whether the floating IP address of the master node is obtained.
Failed to get cluster flavor
Major
Check whether the cluster flavor is obtained.
Failed to get cluster endpoint
Major
Check whether the cluster endpoint is obtained.
Failed to get kubernetes connection
Major
Check whether the Kubernetes cluster connection is obtained.
Failed to update secret
Major
Check whether the cluster secret is updated.
Operation timed out
Major
Check whether the user operation timed out.
Connecting to Kubernetes cluster timed out
Major
Check whether connecting to the Kubernetes cluster timed out.
Failed to check component status or components are abnormal
Major
Check whether the statuses of cluster components can be obtained or whether the components malfunction.
The node is not found in kubernetes cluster
Major
Check whether the node can be found in the Kubernetes cluster.
The status of node is not ready in kubernetes cluster
Major
Check whether the node is running normally in the Kubernetes cluster.
Can't find corresponding vm of this node in ECS
Major
Check whether the node can be found on the ECS console.
Failed to upgrade the master
Major
Check whether the master node has been upgraded.
Failed to upgrade the node
Major
Check whether the node has been upgraded.
Failed to change flavor of the master
Major
Check whether the master node flavor has been changed.
Change flavor of the master timeout
Major
Check whether changing the master node flavor timed out.
Failed to pass verification while creating yearly/monthly subscription node
Major
Check whether creating a yearly/monthly node has been verified.
Failed to install the node
Major
Check whether the node is installed in the cluster.
Failed to clean routes of cluster container network in VPC
Major
Check whether the routes of the cluster container network in the VPC are cleared.
Cluster status is Unavailable
Major
Check whether the cluster is available.
Cluster status is Error
Major
Check whether the cluster becomes faulty.
Cluster status is not updated for a long time
Major
Check whether the cluster remains in a state for a long time.
Failed to update master status after upgrading cluster timeout
Major
Check whether the status of the master node is updated after the cluster upgrade timed out.
Failed to update running jobs after upgrading cluster timeout
Major
Check whether running tasks are updated after the cluster upgrade timed out.
Failed to update cluster status
Major
Check whether the cluster status is updated.
Failed to update node status
Major
Check whether the node status is updated.
Failed to remove the static node from database
Major
Check whether nodes are removed from the database after accepting nodes timed out.
Failed to update node status to abnormal after node processing timeout
Major
Check whether the node status is updated to abnormal after processing the node timed out.
Failed to update the cluster endpoint
Major
Check whether the cluster endpoint is updated.
Failed to delete the unavailable connection of the Kubernetes cluster
Major
Check whether unavailable Kubernetes connections are deleted.
Failed to sync the cluster cert
Major
Check whether the cluster certificate is synchronized.
