Updated on 2025-11-06 GMT+08:00
Recommended GPU Driver Versions for CCE
This section describes the recommended driver versions for CCE clusters. If you use a non-recommended GPU driver version, make sure to check its compatibility with the model and OS. Select a proper NVIDIA driver version by checking the compatibility list for CUDA Toolkit and NVIDIA drivers based on the version used by your application.
Supported GPU Drivers
  • The list of supported GPU drivers applies only to CCE AI Suite (NVIDIA GPU) of v1.2.28 or later.
  • To use the latest GPU driver, upgrade your CCE AI Suite (NVIDIA GPU) to the latest version.
  • The compatibility of the OSs, GPU drivers, and GPU models listed in Table 3 Supported GPU drivers has been tested and verified. To ensure excellent performance and stability, use these GPU drivers. If the deployment is performed in an unverified environment, perform full tests based on the environment to ensure the compatibility and stability.
  • NVIDIA no longer provides updates or security patches for GPU drivers that have reached their end of life (EOL). For details, see Driver Lifecycle. For example, a Production Branch (PB) provides one-year support from the date of release, and a Long-Term Support Branch (LTSB) provides three-year support.
    According to this policy, CCE does not provide technical support for GPU drivers that have reached EOL, including driver installation and updates. The following drivers have reached EOL: 510.47.03, 470.141.03, and 470.57.02.
  • When installing a GPU driver on Ubuntu and CentOS, pay attention to the OS version. For details, see Table 3. For more information, see NVIDIA Driver Documentation.
Table 1 Supported GPU drivers
GPU Model
Supported Cluster Type
Specification
OS
Huawei Cloud EulerOS 2.0 (GPU Virtualization Supported)
Ubuntu 22.04
CentOS Linux release 7.6
EulerOS release 2.9
EulerOS release 2.5
Ubuntu 18.04 (EOM)
EulerOS release 2.3 (EOM)
Tesla T4
CCE Turbo cluster
CCE standard cluster
g6
pi2
570.86.15
535.216.03
535.161.08
535.54.03
510.47.03
470.57.02
570.86.15
535.216.03
535.161.08
535.54.03
535.216.03
535.161.08
535.54.03
510.47.03
470.141.03
470.57.02
535.54.03
470.141.03
535.54.03
470.141.03
470.141.03
470.141.03
Tesla V100
CCE Turbo cluster
p2s
p2vs
p2v
570.86.15
535.216.03
535.161.08
535.54.03
510.47.03
470.57.02
570.86.15
535.216.03
535.161.08
535.54.03
535.216.03
535.161.08
535.54.03
510.47.03
470.141.03
470.57.02
535.54.03
470.141.03
535.54.03
470.141.03
470.141.03
470.141.03
