Configuring SFS Turbo Mount Options
This section describes how to configure SFS Turbo mount options. For SFS Turbo, you can only set mount options in a PV and bind the PV by creating a PVC.
The CCE Container Storage (Everest) version must be 1.2.8 or later. This add-on identifies the mount options and transfers them to the underlying storage resources. The parameter settings take effect only if the underlying storage resources support the specified options.
- Mount options cannot be configured for secure containers.
- Due to the restrictions of the NFS protocol, if an SFS volume is mounted to a node for multiple times, link-related mounting parameters (such as timeo) take effect only when the SFS volume is mounted for the first time by default. For example, if the same SFS file system is mounted to multiple pods running on a node, the mounting parameter set later does not overwrite the existing parameter value. If you want to configure different mounting parameters in the preceding scenario, additionally configure the nosharecache parameter.
The Everest add-on in CCE presets the options described in Table 1 for mounting SFS Turbo volumes.
Parameter |
Value |
Description |
vers |
3 |
File system version. Currently, only NFSv3 is supported. Value: 3 |
nolock |
Blank |
Whether to lock files on the server using the NLM protocol. If nolock is selected, the lock is valid for applications on one host. For applications on another host, the lock is invalid. |
timeo |
600 |
Waiting time before the NFS client retransmits a request. The unit is 0.1 seconds. Recommended value: 600 |
hard/soft |
Blank |
Mount mode.
The default value is hard. |
sharecache/nosharecache |
Blank |
How the data cache and attribute cache are shared when one file system is concurrently mounted to different clients. If this parameter is set to sharecache, the caches are shared between the mountings. If this parameter is set to nosharecache, the caches are not shared, and one cache is configured for each client mounting. The default value is sharecache.
The nosharecache setting will affect the performance. The mounting information must be obtained for each mounting, which increases the communication overhead with the NFS server and the memory consumption of the NFS clients. In addition, the nosharecache setting on the NFS clients may lead to inconsistent caches. Determine whether to use nosharecache based on site requirements. |
You can configure other mount options if needed. For details, see Mounting an SFS Turbo File System to Linux ECSs.
Configuring Mount Options in a PV
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in SFS Turbo Mount Options.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Configure mount options in a PV. Example:
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner name: pv-sfsturbo # PV name spec: accessModes: - ReadWriteMany # Access mode. The value must be ReadWriteMany for SFS Turbo. capacity: storage: 500Gi # Storage capacity. This parameter is only for verification. It must not be empty or 0, but the specified size will not take effect. csi: driver: sfsturbo.csi.everest.io # Dependent storage driver for the mounting fsType: nfs volumeHandle: {your_volume_id} # SFS Turbo volume ID volumeAttributes: everest.io/share-export-location: {your_location} # Shared path of the SFS Turbo volume everest.io/enterprise-project-id: {your_enterprise_project_id} # Enterprise project ID of the SFS Turbo volume storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner persistentVolumeReclaimPolicy: Retain # Reclaim policy storageClassName: csi-sfsturbo # StorageClass name of the SFS Turbo file system mountOptions: # Mount options - vers=3 - nolock - timeo=600 - hard - After creating a PV, you can create a PVC, bind it to the PV, and mount the PV to the containers in the workload. For details, see Using an Existing SFS Turbo File System Through a Static PV.
- Check whether the mount options are effective.
In this example, the PVC is mounted to the workload that uses the nginx:latest image. You can run the mount -l command to check whether the mount options take effect.
- View the pod to which the SFS Turbo volume has been mounted. In this example, the workload name is web-sfsturbo. Replace it with the actual workload name.
kubectl get pod -n <namespace> | grep web-sfsturbo
Command output:
web-sfsturbo-*** 1/1 Running 0 23m
- Run the following command to check the mount options (web-sfsturbo-*** is an example pod):
kubectl exec -it web-sfsturbo-*** -n <namespace> -- mount -l | grep nfsIf the mounting information in the command output is consistent with the configured mount options, the mount options have been configured.
<Your mount path> on /data type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,noresvport,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=**.**.**.**,mountvers=3,mountport=20048,mountproto=tcp,local_lock=all,addr=**.**.**.**)
