Using an Existing EVS Disk Through a Static PV
CCE allows you to create a PV using an existing EVS disk. After the PV is created, you can create a PVC and bind it to the PV. This method is suitable for scenarios where underlying storage is available.
- You have created a cluster and installed the CCE Container Storage (Everest) add-on in the cluster.
- You have created an EVS disk that meets the following requirements:
- The EVS disk cannot be a system disk, DSS disk, or shared disk.
- The EVS disk must be of the SCSI type. (The default disk type is VBD when you purchase an EVS disk.)
- The EVS disk must be available and not used by other resources.
- The AZ of the EVS disk must be the same as that of the cluster node. Otherwise, the EVS disk cannot be mounted and the pod cannot start.
- If the EVS disk is encrypted, the key must be available.
- EVS disks that have been partitioned are not supported.
- Only ext4 EVS disks are supported.
- To create a cluster using commands, ensure kubectl is used. For details, see Accessing a Cluster Using kubectl.
- EVS disks cannot be attached across AZs and cannot be used by multiple workloads, multiple pods of the same workload, or multiple tasks. Data sharing of a shared disk is not supported between nodes in a CCE cluster. If an EVS disk is attached to multiple nodes, I/O conflicts and data cache conflicts may occur. Therefore, select only one pod when creating a Deployment that uses EVS disks.
- For clusters earlier than v1.19.10, if an HPA policy is used to scale out a workload with EVS volumes mounted, the existing pods cannot be read from or written to when a new pod is scheduled to another node.
For clusters v1.19.10 and later, if an HPA policy is used to scale out a workload with EVS volumes mounted, a new pod cannot be started because EVS disks cannot be attached.
CCE allows you to create PVs and PVCs using existing EVS disks and mount the PVCs to workloads using the console or kubectl.
- Statically create a PVC and PV.
- Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click Create PVC in the upper right corner. On the slide-out panel, configure PVC parameters.
PVC Type
In this example, select EVS.
PVC Name
Enter the PVC name, which must be unique in a namespace.
Creation Method
- If the underlying storage is available, create a PV or use an existing PV to statically create a PVC.
- If no underlying storage is available, select Dynamically provision. For details, see Using an EVS Disk Through a Dynamic PV.
In this example, select Create new to create both a PV and PVC on the console.
PVa
Select an existing PV in the cluster. For details about how to create a PV, see "Creating a storage volume" in Related Operations.
You do not need to specify this parameter in this example.
EVSb
Click Select EVS. On the displayed page, select the EVS volume that meets your requirements and click OK.
PV Nameb
Enter the PV name, which must be unique in the same cluster.
Access Modeb
EVS volumes support only ReadWriteOnce, indicating that a storage volume can be mounted to one node in read/write mode. For details, see Volume Access Modes.
Reclaim Policyb
You can select Delete or Retain to specify the reclaim policy of the underlying storage when the PVC is deleted. For details, see PV Reclaim Policy.
a: The parameter is available when Creation Method is set to Use existing.
b: The parameter is available when Creation Method is set to Create new.
- Click Create to create a PVC and a PV.
You can choose Storage in the navigation pane and view the created PVC and PV on the PVCs and PVs tabs, respectively.
- Create an application.
- Choose Workloads in the navigation pane. In the right pane, click the StatefulSets tab.
- Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Information area under Container Settings and choose Add Volume > PVC. Mount and use storage volumes. For details about the parameters, see Table 1. For other parameters, see Workloads.
Table 1 Mounting a storage volume Parameter
PVC
Select an existing EVS volume.
An EVS volume can be mounted to only one workload.
Mount Path
Enter a mount path, for example, /tmp.
This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.NOTICE:If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
Subpath
Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path will be used by default.
Permission
- Read-only: You can only read the data in the mounted volumes.
- Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the EVS disk.
A non-shared EVS disk can be attached to only one workload pod. If there are multiple pods, extra pods cannot start properly. Ensure that the number of workload pods is 1 if an EVS disk is attached.
- After the configuration, click Create Workload.
After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence.
- Use kubectl to access the cluster.
- Create a PV. If a PV has been created in your cluster, skip this step. When using a YAML file to create a PV, do not use parameters that are not declared in the file, such as status, spec.claimRef, and annotation.everest.io/set-disk-metadata. Otherwise, the PV may be abnormal.
- Create the pv-evs.yaml file.
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner everest.io/reclaim-policy: retain-volume-only # (Optional) The underlying volume is retained when the PV is deleted. name: pv-evs # PV name labels: failure-domain.beta.kubernetes.io/region: <your_region> # Region of the node where the application is to be deployed failure-domain.beta.kubernetes.io/zone: <your_zone> # AZ of the node where the application is to be deployed spec: accessModes: - ReadWriteOnce # Access mode. The value must be ReadWriteOnce for EVS volumes. capacity: storage: 10Gi # EVS disk capacity, in the unit of Gi. The value ranges from 1 to 32768. csi: driver: disk.csi.everest.io # Dependent storage driver for the mounting fsType: ext4 # Must be the same as that of the original file system of the disk. volumeHandle: <your_volume_id> # EVS volume ID volumeAttributes: everest.io/disk-mode: SCSI # Device type of the EVS disk. Only SCSI is supported. everest.io/disk-volume-type: SAS # EVS disk type storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner everest.io/crypt-key-id: <your_key_id> # (Optional) Encryption key ID. Mandatory for an encrypted disk. everest.io/enterprise-project-id: <your_enterprise_project_id> # (Optional) Enterprise project ID of the EVS disk. Ensure that the enterprise project ID specified during PVC creation is the same as that in the PV. Otherwise, the PVC cannot be bound to the PV. everest.io/disk-iops: '3000' # (Optional) IOPS of only a GPSSD2 EVS disk everest.io/disk-throughput: '125' # (Optional) Throughput of only a GPSSD2 EVS disk everest.io/csi.charging-mode: prePaid # Mandatory if the billing mode is set to Yearly/Monthly everest.io/csi.period-type: month # Mandatory if the billing mode is set to Yearly/Monthly. month indicates that resources will be billed on a monthly basis. everest.io/csi.period-num: '1' # Mandatory if the billing mode is set to Yearly/Monthly. '1' indicates that the required duration is one month. persistentVolumeReclaimPolicy: Delete # Reclaim policy storageClassName: csi-disk # StorageClass name. The value must be csi-disk for EVS disks. mountOptions: [] # Mount optionsTable 2 Key parameters Parameter
Mandatory
No
Only retain-volume-only is supported.
This parameter is valid only when the Everest version is 1.2.9 or later and the reclaim policy is Delete. If the reclaim policy is Delete and the current value is retain-volume-only, the associated PV is deleted while the underlying storage volume is retained, when a PVC is deleted.
Yes
Region where the cluster is located.
For details about its value, see Regions and Endpoints.
Yes
AZ where the EVS volume is created. It must be the same as the AZ planned for the workload.
fsType
Yes
File system type, which defaults to ext4.
volumeHandle
Yes
Volume ID of the EVS disk.
To obtain a volume ID, log in to the Cloud Server Console. In the navigation pane, choose Elastic Volume Service > Disks. Click the name of the target EVS disk to go to its details page. On the Summary tab, click the copy button after ID.
Yes
EVS disk type. All letters are in uppercase.- SAS: High I/O
- SSD: Ultra-high I/O
- GPSSD: General Purpose SSD
- ESSD: Extreme SSD
- GPSSD2: General Purpose SSD v2, which is supported when the Everest version is 2.4.4 or later and the everest.io/disk-iops and everest.io/disk-throughput annotations are configured
No
Preconfigured IOPS, which is supported only by General Purpose SSD v2 EVS disks.- The IOPS of General Purpose SSD v2 disks ranges from 3000 to 128000, and the maximum value is 500 times the capacity (GiB).
If the IOPS of General Purpose SSD v2 disks is greater than 3000, extra IOPS will be billed. For details, see Price Calculator.
No
Preconfigured throughput, which is supported only by General Purpose SSD v2 EVS disks.
The value ranges from 125 MiB/s to 1,000 MiB/s. The maximum value is a quarter of the IOPS.
If the throughput is greater than 125 MiB/s, extra throughput will be billed. For details, see Price Calculator.
No
Mandatory when the EVS disk is encrypted. Enter the encryption key ID selected during EVS disk creation.
To obtain an encryption key ID, log in to the Cloud Server Console. In the navigation pane, choose Elastic Volume Service > Disks. Click the name of the target EVS disk to go to its details page. On the Summary tab, copy the value of KMS Key ID in the Configuration Information area.
No
Enter the ID of the enterprise project where the EVS disk is created. It is applicable only to enterprise accounts with enterprise projects enabled. For more details, see Enterprise Center Overview.
If an enterprise project ID is specified, you must specify the same enterprise project ID when creating a PVC. Otherwise, the PVC cannot bind to a PV.
To obtain an enterprise project ID, log in to the Cloud Server Console. In the navigation pane, choose Elastic Volume Service > Disks. Click the name of the target EVS disk to go to its details page. On the Summary tab, click the enterprise project in Management Information to access the enterprise project console. Copy the corresponding ID to obtain the ID of the enterprise project to which the EVS disk belongs.
No
This parameter is mandatory when the yearly/monthly billing mode is used. If this parameter is not specified, the pay-per-use billing mode will be used by default. This parameter is available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest v2.4.16 or later is installed in the cluster.
Options:
- prePaid: EVS disks are billed on a yearly/monthly basis.
- postPaid: EVS disks are billed on a pay-per-use basis.
NOTE:- Before creating an EVS disk billed on a yearly/monthly basis, you need to grant the payment permission (bss:order:pay) to cce_cluster_agency. Use your tenant account on the CCE console to perform this operation for the first time. After confirmation, CCE will automatically authorize the agency.
- When creating yearly/monthly EVS disks in batches, limit the number of disks to 300 or fewer per batch if there are requirements on overall provisioning time. Creating more than 300 EVS disks per batch may lead to a significant increase in total provisioning time.
No
Billing cycle, which is mandatory only when the yearly/monthly billing mode is used. Options:
- month: Resources are billed on a monthly basis.
- year: Resources are billed on a yearly basis.
No
Required duration, which is mandatory only when the yearly/monthly billing mode is used. Options:
- For monthly billing, the value of this parameter ranges from 1 to 9.
- For yearly billing, the value of this parameter ranges from 1 to 5.
Yes
A reclaim policy is supported when the cluster version is 1.19.10 or later and the Everest version is 1.2.9 or later.
The Delete and Retain reclaim policies are supported. For details, see PV Reclaim Policy. If high data security is required, select Retain to prevent data from being deleted by mistake.
Delete:
- If everest.io/reclaim-policy is not specified, both the PV and EVS disk will be deleted when a PVC is deleted.
- If everest.io/reclaim-policy is set to retain-volume-only, when a PVC is deleted, the PV will be deleted but the EVS disk will be retained.
Retain: When a PVC is deleted, both the PV and underlying storage resources will be retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again. If you want to continue using the underlying storage resources, delete the PV first. Then, create a new PV and PVC and associate them with the underlying storage resources.
storageClassName
Yes
StorageClass name, which is csi-disk for an EVS disk.
mountOptions
No
Mount options. For details, see Configuring EVS Mount Options.
- Run the following command to create a PV:
kubectl apply -f pv-evs.yaml
- Create a PVC.
- Create the pvc-evs.yaml file.
apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-evs namespace: default annotations: everest.io/disk-volume-type: SAS # EVS disk type everest.io/crypt-key-id: <your_key_id> # (Optional) Encryption key ID. Mandatory for an encrypted disk. everest.io/enterprise-project-id: <your_enterprise_project_id> # (Optional) Enterprise project ID of the EVS disk. Ensure that the enterprise project ID specified during PVC creation is the same as that in the PV. Otherwise, the PVC cannot be bound to the PV. everest.io/csi.charging-mode: prePaid # Mandatory if the billing mode is set to Yearly/Monthly everest.io/csi.period-type: month # Mandatory if the billing mode is set to Yearly/Monthly. month indicates that resources will be billed on a monthly basis. everest.io/csi.period-num: '1' # Mandatory if the billing mode is set to Yearly/Monthly. '1' indicates that the required duration is one month. labels: failure-domain.beta.kubernetes.io/region: <your_region> # Region of the node where the application is to be deployed failure-domain.beta.kubernetes.io/zone: <your_zone> # AZ of the node where the application is to be deployed spec: accessModes: - ReadWriteOnce # The value must be ReadWriteOnce for EVS disks. resources: requests: storage: 10Gi # EVS disk capacity, ranging from 1 to 32768. The value must be the same as the storage size of the existing PV. storageClassName: csi-disk # The StorageClass is EVS. volumeName: pv-evs # PV name
Table 3 Key parameters Parameter
Mandatory
Yes
Yes
No
Options:
No
No
storage
Yes
Requested capacity in the PVC, in Gi.
volumeName
Yes
PV name, which must be the same as the PV name in 1.
storageClassName
Yes
StorageClass name, which must be the same as the StorageClass of the PV in 1.
The StorageClass name for EVS volumes is csi-disk.
- Run the following command to create a PVC:
kubectl apply -f pvc-evs.yaml
- Create a file named web-evs.yaml. In this example, the EVS volume is mounted to the /data path.
apiVersion: apps/v1 kind: StatefulSet metadata: name: web-evs namespace: default spec: replicas: 1 # The number of workload replicas that use the EVS volume must be 1. selector: matchLabels: app: web-evs serviceName: web-evs # Headless Service name template: metadata: labels: app: web-evs spec: containers: - name: container-1 image: nginx:latest # Replace it with the correct image path for your application. volumeMounts: - name: pvc-disk # Volume name, which must be the same as the volume name in the volumes field mountPath: /data # Location where the storage volume is mounted imagePullSecrets: - name: default-secret volumes: - name: pvc-disk # Volume name, which is user-defined persistentVolumeClaim: claimName: pvc-evs # Name of the created PVC --- apiVersion: v1 kind: Service metadata: name: web-evs # Headless Service name namespace: default labels: app: web-evs spec: selector: app: web-evs clusterIP: None ports: - name: web-evs targetPort: 80 nodePort: 0 port: 80 protocol: TCP type: ClusterIP - Run the following command to create a workload to which the EVS volume is mounted:
kubectl apply -f web-evs.yaml
- View the deployed application and EVS volume files.
- Run the following command to view the created pod:
kubectl get pod | grep web-evs
Expected output:web-evs-0 1/1 Running 0 38s
- Run the following command to check whether the EVS volume has been mounted to the /data path:
kubectl exec web-evs-0 -- df | grep data
Expected output:
/dev/sdc 10255636 36888 10202364 0% /data
- Run the following command to check the files in the /data path:
kubectl exec web-evs-0 -- ls /data
Expected output:
lost+found
- Run the following command to create a file named static in the /data path:
kubectl exec web-evs-0 -- touch /data/static
Expected output:
lost+found static
- Run the following command to delete the pod named web-evs-0:
kubectl delete pod web-evs-0
Expected output:
pod "web-evs-0" deleted
- After the deletion, the StatefulSet controller automatically creates a replica with the same name. Run the following command to check whether the files in the /data path have been modified:
Expected output:
lost+found static
The static file is retained, indicating that the data in the EVS volume can be stored persistently.
Related Operations
| Operation | Description | Procedure |
| Creating a storage volume (PV) | Create a PV on the CCE console. |
| Expanding the capacity of an EVS disk | Quickly expand the capacity of a mounted EVS volume on the CCE console. Only the capacity of pay-per-use EVS disks can be expanded on the CCE console. To expand the capacity of yearly/monthly EVS disks, click the volume name to go to the EVS console. |
| Viewing events | View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV. |
| Viewing a YAML file | View, copy, or download the YAML file of a PVC or PV. |
| Editing Reclaim Policy | Modify the reclaim policy of a PV. |
| Synchronizing PVC capacity | When the underlying storage outgrows the PVC, resize the PVC capacity on the CCE console to match the new size. |
Helpful Links
If a storage volume fails to mount to a workload, rectify the fault by referring to What Should I Do If a Storage Volume Cannot Be Mounted or the Mounting Times Out?
