Configuring a Static IP Address for a Pod in a CCE Turbo Cluster
Applications
In Cloud Native Network 2.0, each pod is assigned a VPC network interface with a static IP address. This is particularly applicable to StatefulSet pods. This practice is commonly used for access control, service registration, service discovery, and log auditing.
For example, if a StatefulSet needs to access a cloud database with strict access controls, you can assign static IP addresses to its pods. Then, configure the database's security group to allow access only from those specific pod IP addresses. This ensures that only the StatefulSet can access the database.
- You can configure a static IP address for a pod only in CCE Turbo clusters of the following versions:
- v1.23: v1.23.7-r0 or later
- v1.25: v1.25.3-r0 or later
- Versions later than v1.25
- Currently, only StatefulSet pods or pods without ownerReferences can be configured with static IP addresses. Deployments, DaemonSets, and other types of workloads cannot be configured with static IP addresses. In addition, pods with hostNetwork configured cannot be configured with static IP addresses.
If the pod name remains unchanged, CCE Turbo clusters of v1.19.16-r80, v1.21.12-r0, v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, v1.28.1-r0, or later support static IP addresses for non-StatefulSet pods. For details, see Table 1.
- Do not configure static IP addresses for services that do not have specific requirements on pod IP addresses. Otherwise, the pod rebuilding takes a longer time and the IP address usage decreases.
- The annotations of the static IP address of the pod object cannot be directly modified. Otherwise, the modification does not take effect in the background. To modify the annotations, modify the annotations configuration in the spec.template field of the corresponding StatefulSet workload.
- If there are no available network interfaces left on the node where the rebuilt pod with a static IP address is scheduled (due to pre-bound network interfaces occupying the quota), the network interfaces with static IP addresses will preempt the pre-bound network interfaces. This can cause the pod to start slightly slower. If a node uses a static IP address, properly configure the dynamic pre-binding policy for the node to ensure that not all network interfaces are pre-bound.
Using kubectl
You can add annotations to a StatefulSet to enable or disable the static IP address function of the pod.
apiVersion: apps/v1
kind: StatefulSet
serviceName: nginx
replicas: 3
selector:
matchLabels:
app: nginx
template:
labels:
app: nginx
annotations:
pod.alpha.kubernetes.io/initialized: 'true'
yangtse.io/static-ip: 'true'
yangtse.io/static-ip-expire-no-cascading: 'false'
yangtse.io/static-ip-expire-duration: 5m
containers:
- name: container-0
image: nginx:alpine
resources:
limits:
cpu: 100m
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
imagePullSecrets:
- name: default-secret | Annotation | Default Value | Description | Value Range |
| yangtse.io/static-ip | false | Whether to enable a static IP address for a pod. This function is available only for StatefulSet pods or pods without ownerReferences. This function is disabled by default. | false or true |
| yangtse.io/static-ip-skip-check | false | Whether to skip pod type verification. If your pod ownerReferences is not StatefulSet and the pod name remains unchanged, you can configure this parameter to support static IP addresses for non-StatefulSet pods. If the pod name changes, the static IP address will become invalid. Clusters of v1.19.16-r80, v1.21.12-r0, v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, v1.28.1-r0, or later support this parameter. | false or true |
| yangtse.io/static-ip-expire-duration | 5m | Specifies the interval for reclaiming the expired network interface with the static IP address after the pod with a static IP address is deleted. | The time format is Go time type, for example, 1h30m and 5m. For details, see Go time type. |
| yangtse.io/static-ip-expire-no-cascading | false | Specifies whether to disable cascading reclamation of StatefulSet workloads. The default value is false, indicating that the network interface with a static IP address will be deleted with the StatefulSet. If you want to retain the static IP address for a new StatefulSet with the same name during the interval for reclaiming the expired network interface, set the value to true. | false or true |
