Help Center/
Cloud Container Engine/
User Guide/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
Number of Node Images
Updated on 2026-01-04 GMT+08:00
Check Items
Check the number of images on your node. If there are more than 1000 images, it takes a long time for Docker to start, affecting the standard Docker output and functions such as Nginx.
- If there are too many images on a node, you can delete unnecessary images from the node.
Delete dangling (<none>) images. Such images are typically left from builds or updates.
- Docker nodes
docker image prune
- containerd nodes
- Check all dangling images.
crictl images | grep "<none>"
- Delete all dangling images in batches. Use awk to extract the image IDs and pipe them to xargs for deletion.
crictl images | grep "<none>" | awk '{print $3}' | xargs -r crictl rmi
- Docker nodes
- Too many images slow Docker or containerd startup on your nodes. This delays containers that burst stdout logs for just a few seconds typically. Skip this check if services are not affected.
