Node Swap
Check Items
Check whether swap has been enabled on CCE nodes.
By default, swap is disabled on CCE nodes. Check the necessity of enabling swap manually and determine the impact of disabling this function.
If there is no impact, run the swapoff -a command to disable swap and perform the check again.
