Enhanced CPU Policies
Check Items
Check whether the current cluster version and the target version support enhanced CPU policy.
Scenario: Only the current cluster version supports the enhanced CPU policy function. The target version does not support the enhanced CPU policy function.
Upgrade to a cluster version that supports the enhanced CPU policy function. The following table lists the cluster versions that support the enhanced CPU policy function.
| Cluster Version | Enhanced CPU Policy |
| Clusters of v1.17 or earlier | Not supported |
| Clusters of v1.19 | Not supported |
| Clusters of v1.21 | Not supported |
| Clusters of v1.23 or later | Supported |
