Updated on 2026-06-05 GMT+08:00
Container Runtimes
What Is a Container Runtime?
A container runtime, one of the most important components of Kubernetes, manages the lifecycle of images and containers. kubelet interacts with a container runtime through the Container Runtime Interface (CRI).
CCE supports Docker or containerd (only available for clusters v1.23 or later) as the container runtime. containerd offers a shorter call chain, fewer components, higher stability, and lower node resource consumption.
The Kubernetes community removed dockershim in v1.24, discontinuing support for the Docker container runtime. To align with the Kubernetes community roadmap and improve cluster stability and resource efficiency, CCE has updated its container runtime support policy:
  • New CCE clusters running Kubernetes v1.34 or later do not support Docker.
  • Existing CCE clusters upgraded to Kubernetes v1.34 or later will continue running Docker. However, use containerd when creating new nodes or node pools. Migration from Docker to containerd is required before upgrading to v1.35, as Docker support will be dropped.
Use containerd when creating new nodes because it is more lightweight and secure. Additionally, gradually migrate existing nodes to containerd. For details, see Changing the Container Runtime from Docker to containerd.
Table 1 Container runtime comparison
Item
containerd
Docker
Tracing
kubelet --> CRI plugin (in the containerd process) --> containerd
  • Docker (Kubernetes v1.23 and earlier versions):
    kubelet --> dockershim (in the kubelet process) --> docker --> containerd
  • Docker (community solution for Kubernetes v1.24 or later):
    kubelet --> cri-dockerd (kubelet uses CRI to connect to cri-dockerd) --> docker--> containerd
Command
crictl/ctr
docker
Kubernetes CRI
Native support
Support through dockershim or cri-dockerd
Delayed pod startup
Minor
High
kubelet CPU/memory usage
Minor
High
Runtime's CPU/memory usage
Minor
High
Mapping Between Node OSs and Container Runtimes
VPC network clusters v1.23 or later versions support containerd. Tunnel network clusters v1.23.2-r0 or later versions support containerd.
Table 2 Node OSs and container runtimes in CCE clusters
OS
Kernel Version
Upper-layer Container Runtime
Lower-layer Container Runtime
Container Storage rootfs
CentOS 7.6
3.x
Docker
Clusters v1.23 and later support containerd.
runC
Clusters v1.19.16 and earlier use Device Mapper.
Clusters v1.19.16 and later use OverlayFS.
EulerOS 2.3
3.x
Docker
runC
Device Mapper
EulerOS 2.5
3.x
Docker
runC
Device Mapper
EulerOS 2.9
4.x
Docker
runC
OverlayFS
Ubuntu 18.04
4.x
Docker
runC
OverlayFS
Ubuntu 22.04
5.x
Docker
runC
OverlayFS
Ubuntu 22.04.cgroup2
5.x
containerd
runC
OverlayFS
Huawei Cloud EulerOS 1.1
3.x
Docker
containerd
runC
OverlayFS
Huawei Cloud EulerOS 2.0
5.x
Docker
containerd
runC
OverlayFS
Table 3 Node OSs and container runtimes in CCE Turbo clusters
Node Type
OS
Kernel Version
ECS (VM)
CentOS 7.6
3.x
Docker
containerd
runC
OverlayFS
Ubuntu 18.04
4.x
Ubuntu 22.04
5.x
EulerOS 2.9
4.x
3.x
5.x
5.x
containerd
runC
OverlayFS
ECS (PM)
EulerOS 2.10
4.x
containerd
Kata
runC
Device Mapper
Table 4 Kunpeng Node OSs and container runtimes in CCE
OS
Kernel Version
5.x
Docker
containerd
runC
OverlayFS
EulerOS 2.9
4.x
Docker
containerd
runC
OverlayFS
EulerOS 2.8
4.x
Docker
runC
OverlayFS
Common Commands of containerd and Docker
containerd does not support Docker APIs and Docker CLI, but you can run crictl commands to implement similar functions.
Table 5 Image-related commands
Operation
Docker Command
containerd Command
docker
crictl
ctr
List local images.
docker images
crictl images
ctr -n k8s.io i ls
Pull images.
docker pull
crictl pull
ctr -n k8s.io i pull
Push images.
docker push
None
ctr -n k8s.io i push
Delete local images.
docker rmi
crictl rmi
ctr -n k8s.io i rm
Check images.
docker inspect
crictl inspect
None
Table 6 Container-related commands
Operation
Docker Command
containerd Command
docker
crictl
ctr
List containers.
docker ps
crictl ps
ctr -n k8s.io c ls
Create a container.
docker create
crictl create
ctr -n k8s.io c create
Start a container.
docker start
crictl start
ctr -n k8s.io run
Stop a container.
docker stop
crictl stop
None
Delete a container.
docker rm
crictl rm
ctr -n k8s.io c del
Connect to a container.
docker attach
crictl attach
None
Access the container.
docker exec
crictl exec
None
Query container details.
docker inspect
crictl inspect
ctr -n k8s.io c info
View container logs.
docker logs
crictl logs
None
Check the resource usage of the container.
docker stats
crictl stats
None
Update container resource limits.
docker update
crictl update
None
Table 7 Pod-related commands
Operation
Docker Command
containerd Command
docker
crictl
ctr
List pods.
None
crictl pods
None
Query pod details.
None
crictl inspectp
None
Start a pod.
None
crictl start
None
Run a pod.
None
crictl runp
None
Stop a pod.
None
crictl stopp
None
Delete a pod.
None
crictl rmp
None
Containers created and started by containerd are immediately deleted by kubelet. containerd does not support suspending, resuming, restarting, renaming, and waiting for containers, nor Docker image build, import, export, comparison, push, search, and labeling. containerd does not support file copy. You can log in to the image repository by modifying the configuration file of containerd.
Differences in Tracing
  • containerd:
Although Docker has added functions such as swarm cluster, docker build, and Docker APIs, it introduces bugs. Also, Docker offers a longer call chain than containerd. Therefore, containerd is more resource-saving and secure.
Container Runtime Versions
Table 8 lists only the runtime versions for the OSs in the latest cluster versions. For historical cluster versions, log in to the target node and check their runtime versions.
  • Docker
    # Huawei Cloud EulerOS, EulerOS, and CentOS
    rpm -q docker-engine
    # Ubuntu
    dpkg -s docker-ce
  • containerd
    rpm -q containerd
    # Ubuntu
    dpkg -s containerd
Table 8 Latest runtime versions for each OS
Cluster Version
Architecture
OS
Latest Docker Version
Latest containerd Version
v1.36
x86
containerd-2.2.1-26.04.130941168.gitb72de14b.x86_64
Ubuntu 22.04
2.2.1-26.04.130941156.gitb72de14b
Arm
containerd-2.2.1-26.04.130941168.gitb72de14b.aarch64
v1.35
x86
containerd-2.2.1-26.03.129169267.git9985da87.x86_64
Ubuntu 22.04
Arm
containerd-2.2.1-26.03.129169267.git9985da87.aarch64
v1.34
x86
New Kubernetes clusters of v1.34 or later do not support Docker. For details, see Updates to Docker Support Policy for CCE Clusters.
containerd-1.7.29-25.11.121763183.git9859417d.x86_64
EulerOS 2.9
CentOS 7.6
Ubuntu 22.04
1.7.29-25.11.121763188.git9859417d
Arm
containerd-1.7.29-25.11.121763183.git9859417d.aarch64
EulerOS 2.9
v1.28-v1.33
x86
docker-engine-18.09.0-311.r62.48.46.hce2.x86_64
EulerOS 2.9
docker-engine-18.09.0.129-1.h94.43.29.eulerosv2r9.x86_64
docker-engine-18.09.0.101-1.h70.28.24.eulerosv2r7.x86_64
CentOS 7.6
Ubuntu 22.04
27.5.1-25.11.121586247.git4c9b3b011a
Arm
docker-engine-18.09.0-311.r62.48.46.hce2.aarch64
EulerOS 2.9
docker-engine-18.09.0.129-1.h94.43.29.eulerosv2r9.aarch64
v1.27
x86
docker-engine-18.09.0-311.r50.46.43.hce2.x86_64
containerd-1.6.14-25.08.114880342.gita270719c.x86_64
EulerOS 2.9
docker-engine-18.09.0.129-1.h91.43.27.eulerosv2r9.x86_64
CentOS 7.6
Ubuntu 22.04
27.5.1-25.05.108320057.git4c9b3b011a
1.6.14-25.05.109434323.gite7077850
Arm
docker-engine-18.09.0-311.r50.46.43.hce2.aarch64
containerd-1.6.14-25.08.114880342.gita270719c.aarch64
EulerOS 2.9
docker-engine-18.09.0.129-1.h91.43.27.eulerosv2r9.aarch64
v1.25
x86
EulerOS 2.9
CentOS 7.6
Ubuntu 22.04
Ubuntu 18.04
5:18.09.9~3-0~ubuntu-bionic
Arm
EulerOS 2.9
EulerOS 2.8
docker-engine-18.09.0.101-1.h69.28.24.eulerosv2r8.aarch64
