Node Clock Synchronization Server
Check Items
Check whether the node clock synchronization service (ntpd or chronyd) is running properly.
Solution
- Scenario 1: ntpd is running abnormally.
Log in to the node and run the systemctl status ntpd command to obtain the running status of ntpd. If the command output is abnormal, run the systemctl restart ntpd command and obtain the status again.
The normal command output is as follows:
Figure 1 Running status of ntpd
If the problem persists after ntpd is restarted, contact technical support.
- Scenario 2: chronyd is running abnormally.
Log in to the node and run the systemctl status chronyd command to obtain the running status of chronyd. If the command output is abnormal, run the systemctl restart chronyd command and obtain the status again.
Figure 2 Running status of chronyd
If the problem persists after chronyd is restarted, contact technical support.
