Updated on 2026-09-21 GMT+08:00
Node Restrictions
Check Items
Check the following items:
  • Check whether the node is available.
  • Check whether the node OS supports the upgrade.
  • Check whether the node is marked with unexpected node pool labels.
  • Check whether the Kubernetes node name is the same as the ECS name.
  • The node is unavailable. Preferentially recover the node.
    If a node is unavailable, log in to the CCE console and click the cluster name to access the cluster console. Then, choose Nodes in the navigation pane. In the right pane, click the Nodes tab. Ensure that the node is in the Running state. A node in the Installing or Deleting state cannot be upgraded.
    If a node is unavailable, recover the node and retry the check task. For details, see What Should I Do If a Cluster Is Available But Some Nodes in It Are Unavailable?
    Figure 1 Checking node statuses
  • The node OS does not support the upgrade.
    The following table lists the node OSs that support the upgrade. You can reset the node OS to an available OS in the list.
    Table 1 OSs that support the upgrade
    OS
    Constraint
    EulerOS 2.x
    If the target version is earlier than v1.27, there are no constraints.
    If the target version is v1.27 or later, only EulerOS 2.9 and EulerOS 2.10 support the upgrade.
    CentOS 7.x
    There are no constraints.
    Ubuntu
    If the target version is v1.27 or later, only Ubuntu 22.04 supports the upgrade.
    Huawei Cloud EulerOS 1.1
    Huawei Cloud EulerOS 2.0
    None
  • The affected node belongs to the default node pool but it is configured with a non-default node pool label, which will affect the upgrade.
    If a node is migrated from a common node pool to the default node pool, the cce.cloud.com/cce-nodepool label will affect the cluster upgrade. Check whether load scheduling on the node depends on the label.
    • If no, delete the label.
    • If yes, modify the load balancing policy, remove the dependency, and then delete the label.
  • The node is marked with a CNIProblem taint. Preferentially recover the node.
    The node contains a taint whose key is node.cloudprovider.kubernetes.io/cni-problem, and the effect is NoSchedule. The taint is added by the CCE Node Problem Detector add-on. Upgrade this add-on to the latest version and check again. If the problem persists, contact technical support.
  • The resources for the affected node in Kubernetes are not available. It is possible that the node is being deleted. Try again later.
    Recheck after the node is deleted.
  • The OS running on the master node is EulerOS 2.5, which does not support the cluster to be upgraded to v1.27.5-r0.
    You can upgrade the version to 1.25 or 1.28. If you choose to upgrade the version to 1.28, EulerOS 2.5 will be rolling upgraded to Huawei Cloud EulerOS 2.0 during the upgrade. If you have other requirements, submit a service ticket.
  • The Snt3NPU node is running EulerOS 2.8 Arm and does not support cluster upgrades to v1.28 or later.
    CCE standard and Turbo clusters v1.28 or later do not support EulerOS 2.8 Arm, which has reached EOS. However, the Snt3 Arm model supports EulerOS 2.8 Arm as the highest version. As a result, the cluster cannot upgrade the node OS, leading to a failed upgrade. To proceed with the upgrade, follow these steps:
    1. To continue to use NPUs, select the proper NPU model and OS by referring to Mappings Between Cluster Versions and OS Versions and Software Versions Required by Different Models. For details about the purchase process, see Using Lite Cluster.
    2. Migrate the services on the faulty node to the node purchased in 1. For details, see Draining a Node.
    3. Delete the faulty node and upgrade the cluster again.
