Updated on 2026-06-16 GMT+08:00
Dynamic Resource Oversubscription
Many services see surges in traffic. To ensure performance and stability, resources are often requested at the maximum needed. However, the surges may ebb very shortly and resources, if not released, are wasted in non-peak hours. Especially for online jobs that request a large quantity of resources to ensure SLA, resource utilization can be as low as it gets.
Resource oversubscription is the process of using idle requested resources. Oversubscribed resources are suitable for deploying offline jobs, which focus on throughput but have low SLA requirements and can tolerate certain failures.
Hybrid deployment of online and offline jobs in a cluster can better utilize cluster resources.
Figure 1 Resource oversubscription
Features
After dynamic resource oversubscription and elastic scaling are enabled in a node pool, oversubscribed resources change rapidly because the resource usage of high-priority applications changes in real time. To prevent frequent node scale-ins and scale-outs, do not consider oversubscribed resources when evaluating node scale-ins.
Hybrid deployment is supported, and CPU and memory resources can be oversubscribed. The key features are as follows:
  • Offline jobs preferentially run on oversubscribed nodes.
    If both oversubscribed and non-oversubscribed nodes exist, the former will score higher than the latter and offline jobs are preferentially scheduled to oversubscribed nodes.
  • Online jobs can use only non-oversubscribed resources if scheduled to an oversubscribed node.
    Offline jobs can use both oversubscribed and non-oversubscribed resources of an oversubscribed node.
  • In the same scheduling period, online jobs take precedence over offline jobs.
    If both online and offline jobs exist, online jobs are scheduled first. When the node resource usage exceeds the upper limit and the node requests exceed 100%, offline jobs will be evicted.
  • CPU/Memory resources can be isolated by kernel.
    CPU isolation: Online jobs can quickly preempt CPU resources of offline jobs and suppress the CPU usage of the offline jobs.
    Memory isolation: When system memory resources are used up and OOM Kill is triggered, the kernel evicts offline jobs first.
  • kubelet offline jobs obey the following admission rules:
    After a pod is scheduled to a node, kubelet starts the pod only when the node resources can meet the pod request (predicateAdmitHandler.Admit). kubelet starts the pod when both of the following conditions are met:
    • The sum of resources requested by the pod to be started and by online running jobs is less than the node's allocatable resources.
    • The sum of resources requested by the pod to be started and by online/offline running jobs is less than the sum of the node's allocatable resources and oversubscribed resources.
  • Resource oversubscription and hybrid deployment can be configured separately.
    Enabling hybrid deployment of a node pool also enables oversubscription by default. Nodes are then labeled with both volcano.sh/colocation="true" and volcano.sh/oversubscription="true". To use hybrid deployment for both online and offline jobs without oversubscription, simply disable oversubscription in hybrid deployment settings. This will remove the volcano.sh/oversubscription="true" label.
    The following table lists the features that can be used after hybrid deployment or oversubscription is enabled.
    Hybrid Deployment
    Oversubscription
    Oversubscription Resource
    Scenario for Evicting Offline Pods
    No
    No
    No
    No
    Yes
    No
    No
    The actual resource usage of a node exceeds the upper limit.
    No
    Yes
    Yes
    The actual resource usage of a node exceeds the upper limit and the pod requests on the node exceed 100%.
    Yes
    Yes
    Yes
Scenario constraints: Hybrid task deployment and resource oversubscription enable clusters to use compute resources more efficiently and balance resource allocation during peak and off-peak hours. This improves overall resource utilization and reduces O&M costs. With intelligent resource scheduling, CCE can handle burst resource surges, such as online service surges. For example, with a CPU QoS policy, CCE prioritizes compute resources for online tasks to ensure the stable running of key services. When memory usage temporarily increases, the underlying OS automatically reclaims memory, prioritizing the memory used by inactive data such as page cache of offline services. This may cause slight node performance fluctuations. CCE dynamically adjusts task running statuses based on resource pressure, quickly restoring overall services to a stable state. This achieves a balance between service continuity and resource efficiency.
How to Use
Consider the cluster version when determining how to make use of resource oversubscription. For details, see Table 1.
Oversubscription mode and compatibility mode cannot be used concurrently. Select either of them. If the cluster version does not support cloud native hybrid deployment, hybrid deployment resource oversubscription and parameter settings do not take effect. To use resource oversubscription, use kubelet oversubscription.
Table 1 Mapping between cluster versions and resource oversubscription
Cluster Version
Specific Version
Later than v1.25
None
Resource Oversubscription in Cloud Native Hybrid Deployment
None
v1.25
v1.25.4-r0 or later
None
Earlier than v.1.25.4-r0 (kubelet oversubscription is used in cluster versions earlier than v.1.25.4-r0. Upgrade the cluster versions to v1.25.4-r0 or later.)
Existing node pools: kubelet oversubscription
New node pools: resource oversubscription in cloud native hybrid deployment
For existing node pools, migrate kubelet oversubscription to resource oversubscription in cloud native hybrid deployment for unified management. For details, see Switching kubelet Oversubscription to Resource Oversubscription in Cloud Native Hybrid Deployment.
Earlier than v1.25.4-r0
kubelet oversubscription cannot be migrated to resource oversubscription in cloud native hybrid deployment.
v1.23
v1.23.9-r0 or later
None
Earlier than v.1.23.9-r0 (kubelet oversubscription is used in cluster versions earlier than v.1.23.9-r0. Upgrade the cluster versions to v1.23.9-r0 or later.)
Earlier than v1.23.9-r0, but later than or equal to v1.23.5-r0
v1.21
v1.21.7-r0 or later
None
v1.19
v1.19.16-r4 or later
None
When cloud native hybrid deployment is enabled, resource oversubscription is enabled by default. For details, see Resource Oversubscription in Cloud Native Hybrid Deployment. The cloud native hybrid deployment add-on, volcano-agent, reports oversubscribed resources and evicts service load from nodes. Its core features include CPU/memory suppression, dynamic resource oversubscription, CPU burst, and hierarchical QoS control of egress.
To maintain compatibility with earlier versions, the function of manually setting kubelet parameters to enable resource oversubscription is still available. For details, see Compatible kubelet Oversubscription (Not Recommended). However, this solution only provides basic functions and has not been updated. It does not support new features like CPU burst and hierarchical QoS control of egress.
Specifications
  • Cluster version
    • v1.23: v1.23.9-r0 or later
    • v1.25: v1.25.4-r0 or later
  • Cluster type: CCE standard or Turbo
  • Node OS: Huawei Cloud EulerOS 2.0
  • Node type: ECS on x86
  • Volcano version: 1.10.0 or later
  • Before enabling oversubscription, ensure that the overcommit add-on is not enabled on Volcano.
  • Running pods cannot be converted between online and offline services. To convert services, rebuild pods.
  • If you have configured the cpu-manager-policy to statically pin CPU cores on a node, do not assign the QoS class Guaranteed to offline pods. This is because offline pods may occupy CPU cores intended for online pods, potentially causing online pod startup failures and preventing offline pods from starting even after successful scheduling. To prevent this, switch the offline pods to online pods if CPU pinning is required.
  • If cpu-manager-policy is set to static CPU pinning on a node, do not pin CPU cores to all online pods. This is because doing so can cause online pods to occupy all available CPU or memory resources, leaving only a small number of oversubscribed resources.
  2. In the navigation pane, choose Nodes. On the Node Pools tab, locate the target node pool and choose More > Mixed configuration.
    Ensure that node pool hybrid deployment and resource oversubscription are enabled. For details, see Procedure.
  3. (Optional) Adjust resource oversubscription parameters.
    Table 2 Resource oversubscription parameters
    High CPU Eviction Threshold (%)
    When the CPU usage of a node exceeds the specified value, offline job eviction is triggered and the node becomes unschedulable.
    The default value is 80, indicating that offline job eviction is triggered when the CPU usage of a node exceeds 80%.
    Low CPU Eviction Threshold (%)
    When the CPU usage of a node is higher than the upper limit, offline jobs will be evicted. The node accepts the offline jobs again only when the CPU usage of the node is lower than the lower limit.
    The default value is 30, indicating that offline jobs are accepted again when the CPU usage of a node is lower than 30%.
    High Memory Eviction Threshold (%)
    When the memory usage of a node exceeds the specified value, offline job eviction is triggered and the node becomes unschedulable.
    The default value is 60, indicating that offline job eviction is triggered when the memory usage of a node exceeds 60%.
    Low Memory Eviction Threshold (%)
    When the memory usage of a node is higher than the upper limit, offline jobs will be evicted. The node accepts the offline jobs again only when the memory usage of the node is lower than the lower limit.
    The default value is 30, indicating that offline jobs are accepted again when the memory usage of a node is lower than 30%.
  4. Check the Volcano configuration.
    kubectl edit cm volcano-scheduler-configmap -n kube-system
    Check the oversubscription configuration in volcano-scheduler-configmap. Ensure that the add-on configuration does not contain the overcommit add-on. If - name: overcommit exists, delete this configuration.
    data:
      volcano-scheduler.conf: |
        actions: "allocate, backfill, preempt"   # Configure a preemption action.
        tiers:
        - plugins:
          - name: gang
            enablePreemptable: false
            enableJobStarving: false
          - name: priority
          - name: conformance
          - name: oversubscription
        - plugins:
          - name: drf
          - name: predicates
          - name: nodeorder
          - name: binpack
        - plugins:
          - name: cce-gpu-topology-predicate
          - name: cce-gpu-topology-priority
          - name: cce-gpu
  5. Create resources at a high- and low-priorityClass, respectively.
    cat <<EOF | kubectl apply -f -
    apiVersion: scheduling.k8s.io/v1
    description: Used for high priority pods
    kind: PriorityClass
    preemptionPolicy: PreemptLowerPriority
    value: 999999
    description: Used for low priority pods
    kind: PriorityClass
    value: -90000
    EOF
  6. Deploy online and offline jobs.
    For both online and offline jobs, set schedulerName to volcano to enable Volcano.
    • If you enable low-priority services when creating an offline job workload, the annotation volcano.sh/qos-level: "-1" will be added to it.
      Set priorityClassName to volcano-free.
      kind: Deployment
      apiVersion: apps/v1
        replicas: 4
        template:
            annotations:
              metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]'
              volcano.sh/qos-level: "-1" # Offline job annotation
            schedulerName: volcano             # Volcano is used.
            priorityClassName: volcano-free         # volcano-free priorityClass
    • For online jobs, set priorityClassName to volcano-production.
      kind: Deployment
      apiVersion: apps/v1
        replicas: 4
        template:
            annotations:
            priorityClassName: volcano-production   # volcano-production priorityClass
  7. Run the following command to check the number of oversubscribed resources and the resource usage:
    kubectl describe node <nodeIP>
    # kubectl describe node 192.168.0.0
    Roles:              <none>
    Labels:           ...
                      volcano.sh/oversubscription=true
    Annotations:      ...
                      volcano.sh/oversubscription-cpu: 2335
                      volcano.sh/oversubscription-memory: 341753856
    Allocatable:
      cpu:               3920m
      memory:            6263988Ki
    Allocated resources:
      (Total limits may be over 100 percent, i.e., overcommitted.)
      Resource           Requests      Limits
      cpu                 4950m (126%)  4950m (126%)
      memory             1712Mi (27%)  1712Mi (27%)
Specifications
  • Cluster version
    • v1.19: v1.19.16-r4 or later
    • v1.21: v1.21.7-r0 or later
    • v1.23: v1.23.5-r0 or later
    • v1.25 or later
  • Node OS: EulerOS 2.9 (kernel-4.18.0-147.5.1.6.h729.6.eulerosv2r9.x86_64) or Huawei Cloud EulerOS 2.0
  • Node type: ECS
  • Volcano version: 1.7.0 or later
  • Modifying the label of an oversubscribed node does not affect the running pods.
  • If the label volcano.sh/oversubscription=true is configured for a node in the cluster, the oversubscription configuration must be added to the Volcano add-on. Otherwise, the scheduling of oversold nodes will be abnormal. Ensure that you have correctly configured labels, as the scheduler does not check the add-on and node configurations. For details, see Table 3.
  • To disable oversubscription, perform the following operations:
    • Remove the volcano.sh/oversubscription label from the oversubscribed node.
    • Set over-subscription-resource to false.
    • Modify the configmap of Volcano Scheduler named volcano-scheduler-configmap and remove the oversubscription add-on.
If the label volcano.sh/oversubscription=true is configured for a node in the cluster, the oversubscription configuration must be added to the Volcano add-on. Otherwise, the scheduling of oversold nodes will be abnormal. For details about the related configuration, see Table 3.
Table 3 Configuring oversubscription labels for scheduling
Oversubscription in Add-on
Oversubscription Label on Node
Scheduling
Yes
Yes
Triggered by oversubscription
Yes
No
Triggered
No
No
Triggered
No
Yes
Not triggered or failed. Avoid this configuration.
  1. Use kubectl to access the cluster.
  2. Check the Volcano configuration.
    data:
        tiers:
        - plugins:
          - name: gang
          - name: priority
          - name: conformance
        - plugins:
          - name: drf
          - name: predicates
          - name: nodeorder
          - name: binpack
        - plugins:
          - name: cce-gpu
  3. Enable node oversubscription.
    A label can be configured to use oversubscribed resources only after the oversubscription feature is enabled for a node. Related nodes can be created only in a node pool. To enable the oversubscription feature, perform the following steps:
    1. Create a node pool.
    2. Choose More > Manage in the Operation column of the created node pool.
    3. On the Manage Components page, enable Node oversubscription feature (over-subscription-resource) and click OK.
  4. Set the node oversubscription label.
    The volcano.sh/oversubscription label needs to be configured for an oversubscribed node. If this label is set for a node and the value is true, the node is an oversubscribed node. Otherwise, the node is not an oversubscribed node.
    kubectl label node 192.168.0.0 volcano.sh/oversubscription=true
    An oversubscribed node also supports the oversubscription thresholds, as listed in Table 4. For example:
    kubectl annotate node 192.168.0.0 volcano.sh/evicting-cpu-high-watermark=70
    Querying the node information
    Roles:              <none>
    Labels:           ...
    Annotations:      ...
                      volcano.sh/evicting-cpu-high-watermark: 70
    Table 4 Node oversubscription annotations
    Upper limit for CPU usage. When the CPU usage of a node exceeds the specified value, offline job eviction is triggered and the node becomes unschedulable.
    volcano.sh/evicting-cpu-low-watermark
    Lower limit for CPU usage. When the CPU usage of a node is higher than the upper limit, offline jobs will be evicted. The node accepts the offline jobs again only when the CPU usage of the node is lower than the lower limit.
    volcano.sh/evicting-memory-high-watermark
    Upper limit for memory usage. When the memory usage of a node exceeds the specified value, offline job eviction is triggered and the node becomes unschedulable.
    volcano.sh/evicting-memory-low-watermark
    Lower limit for memory usage. When the memory usage of a node is higher than the upper limit, offline jobs will be evicted. The node accepts the offline jobs again only when the memory usage of the node is lower than the lower limit.
    volcano.sh/oversubscription-types
    Oversubscribed resource type. Options:
    • cpu: oversubscribed CPU
    • memory: oversubscribed memory
    • cpu,memory: oversubscribed CPU and memory
    The default value is cpu,memory.
    kind: PriorityClass
    value: 999999
    kind: PriorityClass
    value: -90000
    EOF
  6. Deploy online and offline jobs and configure PriorityClasses for these jobs.
    The volcano.sh/qos-level annotation needs to be added to distinguish offline jobs. The value is an integer ranging from -7 to 7. If the value is less than 0, the job is an offline job. If the value is greater than or equal to 0, the job is an online job. You do not need to set this annotation for online jobs. For both online and offline jobs, set schedulerName to volcano to enable Volcano.
    The priorities between online jobs and between offline jobs are not differentiated, and the value validity is not verified. If the value of volcano.sh/qos-level of an offline job is not a negative integer ranging from -7 to 0, the job is processed as an online job.
    For an offline job:
    kind: Deployment
    apiVersion: apps/v1
      replicas: 4
      template:
          annotations:
    For an online job:
    kind: Deployment
    apiVersion: apps/v1
      replicas: 4
      template:
          annotations:
    Roles:              <none>
    Labels:           ...
    Annotations:      ...
    Allocatable:
      cpu:               3920m
      memory:            6263988Ki
    In the preceding command, CPU and memory are in the unit of m CPU cores and bytes, respectively.
Deployment Example
The following uses an example to describe how to deploy online and offline jobs in hybrid mode.
  1. Configure a cluster with two nodes, one oversubscribed and the other non-oversubscribed.
    # kubectl get node
    NAME           STATUS   ROLES    AGE    VERSION
    192.168.0.173   Ready    <none>   4h58m   v1.19.16-r2-CCE22.5.1
    192.168.0.3     Ready    <none>   148m    v1.19.16-r2-CCE22.5.1
    • 192.168.0.173 is an oversubscribed node (with the volcano.sh/oversubscription=true label).
    • 192.168.0.3 is a non-oversubscribed node (without the volcano.sh/oversubscription=true label).
    # kubectl describe node 192.168.0.173
    Roles:              <none>
    Labels:             beta.kubernetes.io/arch=amd64
  2. Submit offline job creation requests. If resources are sufficient, all offline jobs will be scheduled to the oversubscribed node.
    The offline job template is as follows:
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: offline
      template:
          labels:
            app: offline
          annotations:
            volcano.sh/qos-level: "-1"       # Offline job label
          containers:
            - name: container-1
              image: nginx:latest
              imagePullPolicy: IfNotPresent
              resources:
                requests:
                  cpu: 500m
                  memory: 512Mi
                limits:
                  cpu: "1"
                  memory: 512Mi
          imagePullSecrets:
            - name: default-secret
    Offline jobs are scheduled to the oversubscribed node.
    # kubectl get pod -o wide
    NAME                      READY   STATUS   RESTARTS  AGE     IP             NODE
    offline-69cdd49bf4-pmjp8   1/1    Running   0         5s    192.168.10.178   192.168.0.173
    offline-69cdd49bf4-z8kxh   1/1    Running   0         5s    192.168.10.131   192.168.0.173
  3. Submit online job creation requests. If resources are sufficient, the online jobs will be scheduled to the non-oversubscribed node.
    The online job template is as follows:
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: online
      template:
          labels:
            app: online
          containers:
            - name: container-1
              image: resource_consumer:latest
              resources:
                requests:
                  cpu: 1400m
                  memory: 512Mi
                limits:
                  cpu: "2"
                  memory: 512Mi
          imagePullSecrets:
    Online jobs are scheduled to the non-oversubscribed node.
    online-ffb46f656-4mwr6  1/1    Running   0         5s    192.168.10.146   192.168.0.3
    online-ffb46f656-dqdv2   1/1    Running   0         5s    192.168.10.67   192.168.0.3
  4. Improve the resource usage of the oversubscribed node and observe whether offline job eviction is triggered.
    Deploy online jobs to the oversubscribed node (192.168.0.173).
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: online
      template:
          labels:
            app: online
           affinity:                             # Submit an online job to an oversubscribed node.
            nodeAffinity:
              requiredDuringSchedulingIgnoredDuringExecution:
                nodeSelectorTerms:
                - matchExpressions:
                  - key: kubernetes.io/hostname
                    operator: In
                    values:
                    - 192.168.0.173
          containers:
            - name: container-1
              resources:
                requests:
                  cpu: 700m
                  memory: 512Mi
                limits:
                  cpu: 700m
                  memory: 512Mi
          imagePullSecrets:
    Submit the online or offline jobs to the oversubscribed node (192.168.0.173) at the same time.
    offline-69cdd49bf4-pmjp8  1/1     Running    0      13m   192.168.10.178   192.168.0.173
    offline-69cdd49bf4-z8kxh  1/1     Running     0      13m   192.168.10.131   192.168.0.173
    online-6f44bb68bd-b8z9p  1/1     Running     0     3m4s   192.168.10.18   192.168.0.173
    online-6f44bb68bd-g6xk8  1/1     Running     0     3m12s   192.168.10.69   192.168.0.173
    Check the oversubscribed node with IP address 192.168.0.173. It is found that resources are oversubscribed, where there are 2343m CPU cores and 3073653200 bytes of memory. Additionally, the CPU allocation rate exceeded 100%.
    Roles:              <none>
    Labels:              …
    Annotations:         …
                        volcano.sh/oversubscription-cpu: 2343
                        volcano.sh/oversubscription-memory: 3073653200
      cpu                    4750m (121%)  7350m (187%)
      memory                 3760Mi (61%)  4660Mi (76%)
    Increase the CPU usage of online jobs on the node. Offline job eviction is triggered.
    offline-69cdd49bf4-bwdm7  1/1    Running   0       11m   192.168.10.208  192.168.0.3
    offline-69cdd49bf4-pmjp8   0/1    Evicted    0       26m   <none>         192.168.0.173
    offline-69cdd49bf4-qpdss   1/1     Running   0       11m   192.168.10.174  192.168.0.3
    offline-69cdd49bf4-z8kxh   0/1     Evicted    0       26m   <none>        192.168.0.173
    online-6f44bb68bd-b8z9p   1/1     Running   0       24m   192.168.10.18  192.168.0.173
    online-6f44bb68bd-g6xk8   1/1     Running   0       24m   192.168.10.69  192.168.0.173
Handling Suggestions
  • After kubelet of the oversubscribed node is restarted, the resource view of Volcano Scheduler is not synchronized with that of kubelet. As a result, OutOfCPU occurs in some newly scheduled jobs, which is normal. After a period of time, Volcano Scheduler can properly schedule online and offline jobs.
  • After online and offline jobs are submitted, you are not advised to dynamically change the job type (adding or deleting annotation volcano.sh/qos-level: "-1") because the current kernel does not support the change of an offline job to an online job.
  • CCE collects the resource usage (CPU/memory) of all pods running on a node based on the status information in the cgroups system. The resource usage may be different from the monitored resource usage, for example, the resource statistics displayed by running the top command.
  • You can add oversubscribed resources (such as CPU and memory) at any time.
    You can reduce the oversubscribed resource types only when the resource allocation rate does not exceed 100%.
  • If an offline job is deployed on a node ahead of an online job and the online job cannot be scheduled due to insufficient resources, configure a higher priorityClass for the online job than that for the offline job.
  • If there are only online jobs on a node and the eviction threshold is reached, the offline jobs that are scheduled to the current node will be evicted soon. This is normal.
If your cluster meets the migration requirements described in Table 1, migrate oversubscription based on node pools.
Migration for Non-Default Node Pools
  1. On the Node Pools tab page of Nodes, locate the target node pool and choose More > Hybrid Deployment. Ensure Resource Pool Hybrid Deployment and Resource Oversubscription are enabled. For details, see Procedure.
  2. If kubelet hybrid deployment and oversubscription are enabled for the node pool, CCE automatically disables the kubelet settings and smoothly migrates to cloud native hybrid deployment and oversubscription.
    • During migration, kubelet temporarily stops reporting resource oversubscription through node annotations and evicts offline pods until the node's resource allocation rate drops below 100%. This is expected behavior. volcano-agent then takes over oversubscription, and the function is restored immediately.
    • Cloud-native hybrid deployment and oversubscription support only Huawei Cloud EulerOS 2.0. If the node OS does not meet this requirement, reset the node OS to Huawei Cloud EulerOS 2.0.
Migration for Default Node Pools
  1. On the Node Pools tab page of Nodes, click View Node in the DefaultPool pane. Select any node with kubelet hybrid deployment and oversubscription enabled, and choose More > Copy Node Configurations to Create Node Pool.
  2. Locate the newly created node pool, click Update, and add the supported node flavors so that more nodes can be migrated at a time.
  3. For the new node pool, choose More > Migrate Node. Select all available nodes with kubelet hybrid deployment and oversubscription enabled, and migrate them to the new node pool.
  4. After all target nodes are migrated to the new node pool, perform the migration operation described in Migration for Non-Default Node Pools for the new node pool. CCE will automatically switch from kubelet hybrid deployment and oversubscription to cloud native hybrid deployment and oversubscription.
  5. Repeat steps 1 to 4 until no nodes with kubelet hybrid deployment and oversubscription enabled remain in the DefaultPool node pool.
