Updated on 2026-06-16 GMT+08:00
Snapshots and Backups
CCE works with EVS to support snapshots. A snapshot is a complete copy or image of EVS disk data at a specific time, which can be used for data DR.
  • Creating a Snapshot: You can create a snapshot to save the disk data at a specific point in time and restore the data if needed.
  • Using a Snapshot to Create a PVC: If data in a PV is lost or damaged due to misoperations, system exceptions, or upgrade and migration, you can create a PVC using an existing snapshot to quickly restore the data to the state when the snapshot was created, ensuring service continuity.
Precautions
  • The snapshot function is available only for clusters v1.15 or later and requires the CSI-based Everest add-on.
  • The subtype (common I/O, high I/O, or ultra-high I/O), disk mode (VBD or SCSI), data encryption, sharing status, and capacity of an EVS disk created from a snapshot must be the same as those of the disk associated with the snapshot. These attributes cannot be modified after being checked or configured.
  • Snapshots can be created only for EVS disks that are available or in use, and a maximum of seven snapshots can be created for a single EVS disk.
  • Snapshots can be created only for PVCs created using the storage class (whose name starts with csi) provided by the Everest add-on. Snapshots cannot be created for PVCs created using the FlexVolume storage class whose name is ssd, sas, or sata.
  • Snapshot data of encrypted disks is stored encrypted, and that of non-encrypted disks is stored non-encrypted.
  • When creating a PVC from a snapshot, avoid deleting the snapshot while the PVC is pending. Doing so may cause the snapshot deletion to fail.
Application Scenarios
The snapshot feature helps address your following needs:
  • Routine data backup
    You can create snapshots for EVS disks regularly and use snapshots to recover your data in case that data loss or data inconsistency occurred due to misoperations, viruses, or attacks.
  • Rapid data restoration
    You can create a snapshot or multiple snapshots before an OS change, application software upgrade, or a service data migration. If an exception occurs during the upgrade or migration, service data can be rapidly restored to the time point when the snapshot was created.
    For example, a fault occurred on system disk A of ECS A, and therefore ECS A cannot be started. Because system disk A is already faulty, the data on system disk A cannot be restored by rolling back snapshots. In this case, you can use an existing snapshot of system disk A to create EVS disk B and attach it to ECS B that is running properly. Then, ECS B can read data from system disk A using EVS disk B.
    The snapshot capability provided by CCE is the same as the CSI snapshot function provided by the Kubernetes community. EVS disks can be created only based on snapshots, and snapshots cannot be rolled back to source EVS disks.
  • Rapid deployment of multiple services
    You can use a snapshot to create multiple EVS disks containing the same initial data, and these disks can be used as data resources for various services, for example, data mining, report query, and development and testing. This method protects the initial data and creates disks rapidly, meeting the diversified service data requirements.
Creating a Snapshot
You can create a snapshot through the console or using kubectl.
  2. Choose Storage in the navigation pane. In the right pane, click the Snapshots and Backups tab.
  3. Click Create Snapshot in the upper right corner. In the dialog box displayed, configure parameters.
    • Snapshot Name: Enter a snapshot name.
    • Storage: Select a PVC. Only the EVS type is available.
      Figure 1 Create Snapshot
  4. Click Create.
  1. Use kubectl to access the cluster.
  2. Create snapshot.yaml for a snapshot. The file name is customizable.
    vim snapshot.yaml
    The file content is as follows:
    kind: VolumeSnapshot
    apiVersion: snapshot.storage.k8s.io/v1
      name: cce-disksnap-test   # The snapshot name, which is customizable
      namespace: default
      source:
        persistentVolumeClaimName: pvc-evs-test     # The PVC name. Only EVS PVCs can be selected.
      volumeSnapshotClassName: csi-disk-snapclass
  3. Create the snapshot. Parameter -n indicates the namespace. You can replace default with the target namespace.
    kubectl apply -f snapshot.yaml -n default
    Information similar to the following is displayed:
    volumesnapshot.snapshot.storage.k8s.io/cce-disksnap-test created
  4. Check whether the snapshot has been created.
    kubectl describe volumesnapshot {snapshot-name}
    If Ready To Use: true is displayed under the Status field in the command output, the snapshot has been created.
    Status:
    Bound Volume Snapshot Content Name: snapcontent-4fef9fdc-2c0c-4d57-a5b4-2654****
    Creation Time: 2026-04-11T07:32:38
    Ready To Use: true
    Restore Size: 10Gi
Ensure the disk type, encryption setting, and disk mode of the created EVS PVC are consistent with those of the snapshot's source EVS disk. You can create a PVC through the console or using kubectl.
  3. Locate the snapshot that you want to use for creating a PVC, click Create PVC, and configure PVC parameters in the displayed dialog box.
    Figure 2 Create PVC
    Table 1 PVC parameters
    Example Value
    PVC Name
    pvc-test
    The PVC name.
    Enter 1 to 63 characters. Use only lowercase letters, digits, and hyphens (-). Do not start or end with a hyphen.
    Billing Mode
    Pay-per-use
    The billing mode of the underlying storage, which can be pay-per-use or yearly/monthly.
    (Optional) Storage Volume Name Prefix
    N/A
    The name prefix for the underlying storage that is automatically created. The actual underlying storage name is in the format of "Storage volume name prefix + PVC UID". If this parameter is left blank, the default prefix pvc will be used. For example, if the storage volume name prefix is set to test, the actual underlying storage name is test-{UID}.
    Available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest v2.4.15 or later is installed in the cluster.
    Resource Tag
    N/A
    You can add resource tags to classify resources. This function is supported only when the Everest version in the cluster is 2.1.39 or later.
    You can create predefined tags on the TMS console. These tags are available to all resources that support tags. You can use these tags to improve the tag creation and resource migration efficiency. For details, see Creating Predefined Tags.
    CCE automatically creates system tags CCE-Cluster-ID=<cluster-ID>, CCE-Cluster-Name=<cluster-name>, and CCE-Namespace=<namespace-name>. These tags cannot be modified.
  4. Click Create.
  2. Create pvc-test.yaml and use a snapshot to create a PVC. The file name is customizable.
    vim pvc-test.yaml
    The file content is as follows (For details about PVCs, see Using kubectl):
    apiVersion: v1
    kind: PersistentVolumeClaim
      namespace: default
      annotations:
        everest.io/disk-volume-type: SSD     # EVS disk type, which must be the same as that of the snapshot's source EVS disk.
        everest.io/disk-volume-tags: '{"key1":"value1","key2":"value2"}' # (Optional) Custom resource tags
      labels:
        failure-domain.beta.kubernetes.io/region: <your_region>   # Region where the EVS disk is located
        failure-domain.beta.kubernetes.io/zone: <your_zone>       # AZ where the EVS disk is located
      accessModes:
      - ReadWriteOnce
      resources:
        requests:
          storage: 10Gi
      storageClassName: csi-disk
      dataSource:
        apiGroup: snapshot.storage.k8s.io
  3. Create the PVC. Parameter -n indicates the namespace. You can replace default with the target namespace.
    kubectl apply -f pvc-test.yaml -n default
    persistentvolumeclaim/pvc-test created
  4. Check whether the PVC has been created.
    kubectl get pvc pvc-test
    If STATUS is Bound, the PVC has been created.
    NAME      STATUS   VOLUME                     CAPACITY   ACCESS MODES   STORAGECLASS   AGE
    pvc-test   Bound    pvc-7b9f4c8d-1a2b-3c4d-5e6f-7g8h9i0jkl   10Gi     RWO         csi-disk     1m
