Updated on 2026-01-28 GMT+08:00
FlexVolume Overview
Container storage provides persistent storage for container workloads and supports multiple storage types. Each workload (pod) can consume as much storage as it requires.
In CCE, container storage is backed both by Kubernetes-native objects, such as emptyDir, hostPath, secret, and ConfigMap, and by cloud storage services.
CCE clusters of 1.13 and earlier versions use the storage-driver add-on to connect to cloud storage services to support Kubernetes FlexVolume driver for container storage. The FlexVolume driver has been deprecated in favor of the Container Storage Interface (CSI). The CSI add-on Everest is installed in CCE clusters of 1.15 and later versions by default. For details, see Storage Overview.
  • In CCE clusters earlier than Kubernetes 1.13, end-to-end capacity expansion of container storage is not supported, and the PVC capacity is inconsistent with the storage capacity.
  • In a cluster of v1.13 or earlier, when an upgrade or bug fix is available for storage functionalities, you only need to install or upgrade the storage-driver add-on. Upgrading the cluster or creating a cluster is not required.
Notes and Constraints
  • For clusters created in CCE, Kubernetes v1.15.11 is a transitional version in which the FlexVolume plugin (storage-driver) is compatible with the CSI plugin (Everest). Clusters of v1.17 and later versions do not support FlexVolume anymore. Use the Everest add-on.
  • The FlexVolume plugin storage-driver will be maintained by Kubernetes developers, but new functionality will only be added to CSI CCE Container Storage (Everest). Do not create storage that accesses the FlexVolume storage-driver in CCE anymore. Otherwise, the storage resources may not function properly.
Checking Storage Add-ons
  1. Log in to the CCE console.
  2. In the navigation tree on the left, click Add-ons.
  3. Click the Add-on Instance tab.
  4. Select a cluster in the upper right corner. The default storage add-on installed during cluster creation is displayed.
Differences Between CSI and FlexVolume Plugins
Table 1 CSI and FlexVolume
Kubernetes Solution
CCE Add-on
Feature
Recommendation
CSI
everest
CSI was developed as a standard for exposing arbitrary block and file storage systems to containerized workloads. Using CSI, third-party storage providers can deploy plugins exposing new storage systems in Kubernetes without having to touch the core Kubernetes code. In CCE, the Everest add-on is installed by default in clusters of Kubernetes v1.15 or later to access storage services such as EVS, SFS, OBS, and SFS Turbo.
The Everest add-on consists of:
  • everest-csi-controller for storage volume creation, deletion, capacity expansion, and cloud disk snapshots
  • everest-csi-driver for mounting, unmounting, and formatting storage volumes on nodes
For details, see Everest.
The Everest add-on is installed by default in clusters of v1.15 or later. CCE will mirror the Kubernetes community by providing continuous support for updated CSI capabilities.
FlexVolume
storage-driver
FlexVolume is an out-of-tree plugin interface that has existed in Kubernetes since version 1.2 (before CSI). CCE provided FlexVolume volumes through the storage-driver add-on installed in clusters of Kubernetes v1.13 and earlier versions. This add-on connects clusters to storage services such as EVS, SFS, OBS, and SFS Turbo.
For details, see storage-driver.
For the created clusters of v1.13 or earlier, the installed FlexVolume plugin (CCE add-on storage-driver) can still be used. CCE has stopped providing update support for this add-on. Upgrade these clusters.
  • Either CSI or FlexVolume can be used in one cluster.
  • The FlexVolume plugin cannot be replaced by the CSI plugin in clusters of v1.13 or earlier. To change the FlexVolume plugin to CSI, you can only upgrade these clusters. For details, see Cluster Upgrade Path.
