Node Scaling Rules
HPA is designed for pod-level scaling and can dynamically adjust the number of replicas based on workload metrics. However, if cluster resources are insufficient and new replicas cannot run, you can only scale out the cluster.
CCE Cluster Autoscaler is a node scaling component provided by Kubernetes. It automatically scales in or out nodes in a cluster based on the pod scheduling status and resource usage. It supports multiple scaling modes, such as multi-AZ, multi-pod-specifications, metric triggering, and periodic triggering, to meet the requirements of different node scaling scenarios.
Before using the node scaling function, you must install the CCE Cluster Autoscaler add-on of v1.13.8 or later in the cluster.
How Cluster Autoscaler Works
Cluster Autoscaler goes through two processes.
- Scale-out: Autoscaler checks all unscheduled pods every 10 seconds and selects a node pool that meets the requirements for scale-out based on the policy you set.
- Autoscaler simulates pod scheduling using the upstream Kubernetes scheduler algorithm. If you use custom schedulers or non-standard Kubernetes scheduling policies, scale-out may fail or over-provision due to algorithmic mismatch.
- When unscheduled pods have heterogeneous resource requirements, Autoscaler may over-provision nodes due to resource fragmentation. A second scale-out can be triggered while nodes from the first are still being provisioned. The Autoscaler's scale-out simulation does not match the actual scheduler behavior.
- Initial calculation: During the first scale-out, Autoscaler uses a greedy algorithm to compute the theoretical minimum nodes required.
- Node creation: After the first scale-out is triggered, the pending pods remain unschedulable during node creation.
- Recalculation: Autoscaler reevaluates scale-out requirements, simulating pod placement onto pending nodes from the initial scale-out via the integrated scheduler framework.
- Fragmentation: The scheduler's node-selection logic (based on resource utilization, among other factors) may fragment resources across the new nodes. Consequently, the initially provisioned nodes cannot accommodate the full batch of pods, forcing additional scale-out.
- Scale-in: Autoscaler scans all nodes every 10 seconds. If the number of pod requests on a node is less than the custom scale-in threshold (in percentage), Autoscaler will check whether pods on the current node can be migrated to other nodes. If a node's pre-allocated CPUs and memory remain below the scale-in threshold for a sustained period (10 minutes by default), the cluster initiates a scale-in operation, automatically deleting the underutilized node. However, a node cannot be deleted from a cluster if the following pods exist:
- Pods that do not meet specific requirements set in Pod Disruption Budgets (PodDisruptionBudget)
- Pods that cannot be scheduled to other nodes due to constraints such as affinity and anti-affinity policies
- Pods that have the cluster-autoscaler.kubernetes.io/safe-to-evict: 'false' annotation
- Pods (except those created by DaemonSets in the kube-system namespace) that exist in the kube-system namespace
- Pods that are not created by the controllers (such as Deployments, ReplicaSets, jobs, and StatefulSets)
- When a node meets the scale-in conditions, CCE Cluster Autoscaler will add the DeletionCandidateOfClusterAutoscaler taint to the node in advance to prevent pods from being scheduled to the node. After the CCE Cluster Autoscaler add-on is uninstalled, if the taint still exists on the node, manually delete it.
- To ensure system stability and efficient resource utilization, CCE Cluster Autoscaler uses a conservative policy. Nodes that are not entirely idle are drained one at a time. When these nodes host pods configured with graceful termination, the draining process can be prolonged. As a result, the overall scale-in process may take more time to complete.
Cluster Autoscaler Architecture
Figure 1 shows the Cluster Autoscaler architecture and its core modules.
- Estimator: Evaluates the number of nodes to be added to each node pool to host unschedulable pods.
- Simulator: Finds the nodes that meet the scale-in conditions in the scale-in scenario.
- Expander: Selects the best node from the node pool picked out by Estimator based on the custom policies in the scale-out scenario. Table 1 lists the Expander policies.
Table 1 Expander policies supported by CCE Policy
Application Scenario
Example
Random
Randomly selects a schedulable node pool to perform the scale-out.
This policy is typically used as a basic backup for other complex policies. Only use this policy if the other policies cannot be used.
Assume that auto scaling is enabled for node pools 1 and 2 in the cluster and the scale-out upper limit is not reached. The policy for scaling out the number of pods for a workload is as follows:
- Pending pods trigger the Autoscaler to determine the scale-out process.
- Autoscaler simulates the scheduling phase and evaluates that some pending pods can be scheduled to the added nodes in both node pools 1 and 2.
- Autoscaler randomly selects node pool 1 or node pool 2 for scale-out.
most-pods
A combined policy. It takes precedence over the random policy.
Preferentially selects the node pool that can schedule the most pods after scale-out. If multiple node pools meet the condition, the random policy is used for further decision-making.
This policy is based on the maximum number of pods that can be scheduled.
- Autoscaler evaluates that node pool 1 can schedule 20 new pods and node pool 2 can schedule only 10 new pods after scale-out. Therefore, Autoscaler selects node pool 1 for scale-out.
least-waste
Autoscaler evaluates the overall CPU and memory allocation rate of the node pools and selects the node pool with the minimum CPU and memory waste. If multiple node pools meet the condition, the random policy is used for further decision-making.
This policy uses the minimum waste score of CPUs and memory as the selection criteria.
The formula for calculating the minimum waste score (wastedScore) is as follows:
- wastedCPU = (Total number of CPUs of the nodes to be scaled out – Total number of CPUs of the pods to be scheduled)/Total number of CPUs of the nodes to be scaled out
- wastedMemory = (Total memory of the nodes to be scaled out – Total memory of the pods to be scheduled)/Total memory of the nodes to be scaled out
- wastedScore = wastedCPU + wastedMemory
- Autoscaler evaluates that the minimum waste score of node pool 1 after scale-out is smaller than that of node pool 2. Therefore, Autoscaler selects node pool 1 for scale-out.
priority
A combined policy. The priorities for the policies are as follows: priority > least-waste > topology-balance > random.
It is an enhanced least-waste policy configured based on the node pool or scaling group priority. If multiple node pools meet the condition, the least-waste policy is used for further decision-making.
Based on the least-waste policy, the topology-balance policy balances the number of nodes in different AZs. The AZ with fewer nodes is preferentially selected for a scale-out to ensure that the number of nodes in each AZ is balanced. This policy is available in the add-on of version 1.23.122, 1.25.117, 1.27.85, 1.28.52, 1.29.14, or later.
This policy allows you to configure the priorities of node pools or scaling groups through the console or API, while the least-waste policy can effectively minimize resource waste in various scenarios. The topology-balance policy ensures that the number of nodes in each AZ is balanced. The priority policy is used as the default preferred policy thanks to its good universality.
- Autoscaler evaluates that node pool 1 has a higher priority than node pool 2. Therefore, Autoscaler selects node pool 1 for scale-out.
priority-ratio
A combined policy. The priorities for the policies are as follows: priority > priority-ratio > least-waste > random.
When multiple node pools share the same priority, the Autoscaler prefers the nodes whose CPU-to-memory ratio of allocatable resources after scale-out more closely matches the aggregate CPU-to-memory ratio requested by all scheduled pods.
This policy is used for rescheduling global resources for pods or nodes (instead of only adding nodes) to reduce the overall resource fragmentation rate of the cluster. Use this policy only in rescheduling scenarios.
- Autoscaler determines a preferentially selected node pool and evaluates that the CPU/memory ratio of pods is 1:4. The node flavor in node pool 1 is 2 vCPUs and 8 GiB of memory (the CPU/memory ratio is 1:4), and the node flavor in node pool 2 is 2 vCPUs and 4 GiB of memory (the CPU/memory ratio is 1:2). Therefore, node pool 1 is preferred for this scale-out.
topology-balance
A combined policy. The priorities for the policies are as follows: topology-balance > least-waste > random.
Load is balanced based on the number of nodes in different AZs. The AZ with a small number of nodes is preferentially selected for a scale-out to ensure a balanced number of nodes in each AZ.
When the topology-balance policy is used, the node pool priority does not take effect.
When a node scale-out is triggered, multiple nodes may be added at a time. This policy cannot evenly distribute these nodes to each AZ. It only ensures that the number of nodes in each AZ is balanced after multiple scale-outs.
- During the simulated scheduling, the Autoscaler checks the number of nodes in each AZ of the node pool with auto scaling enabled.
- The Autoscaler determines a preferentially selected node pool and selects the AZ with the minimum number of nodes for the scale-out. If there are two AZs with the same number of nodes, the AZs are sorted using the next-priority policy (least-waste).
