Updated on 2026-08-13 GMT+08:00
Permission Dependency of the CCE Console
Some CCE permissions policies depend on the policies of other cloud services. To view or use other cloud resources on the CCE console, enable the access control feature of IAM and assign dependency policies for the other cloud services.
  • Dependency policies are assigned based on the CCE FullAccess or CCE ReadOnlyAccess policy you configure. For details, see Cluster Permissions (IAM-based Authorization).
  • Only users and user groups with namespace permissions can gain the view access to resources in clusters.
    • If a user is granted the view access to all namespaces of a cluster, the user can view all namespace resources (except secrets) in the cluster. To view secrets in the cluster, the user must gain the admin or edit role in all namespaces of the cluster.
    • The view role within a single namespace allows users to view resources only in the specified namespace.
Dependency Policy Configuration
To grant an IAM user the permissions to view or use resources of other cloud services on the CCE console, you must first grant the CCE Administrator, CCE FullAccess, or CCE ReadOnlyAccess policy to the user group to which the user belongs and then grant the dependency policies listed in Table 1 to the user. These dependency policies will allow the IAM user to access resources of other cloud services.
Enterprise projects enable cross-project resource grouping and management within an enterprise, ensuring resource isolation. IAM supports fine-grained authorization for these resources. Use IAM for permission management.
If you use an enterprise project to set permissions for IAM users, the following restrictions apply:
  • On the CCE console, enterprise projects cannot call the API used to obtain AOM monitoring data for cluster monitoring. Therefore, IAM users in these enterprise projects cannot query monitoring data.
  • On the CCE console, enterprise projects cannot call the API to query the key pair created during node creation. Therefore, IAM users in these enterprise projects cannot use the key pair login mode. Only the password login mode is supported.
  • On the CCE console, enterprise projects are not supported during template creation. Therefore, enterprise project sub-users cannot use template management.
CCE supports fine-grained permissions configuration, but has the following restrictions:
  • AOM does not support resource-level monitoring. After IAM fine-grained permissions are configured for specific cluster resources, users can view cluster monitoring information on the Overview page of the CCE console. However, they cannot view resource-specific metrics. What they see remains the monitoring data for all clusters in the project, not just the authorized resources.
Table 1 Dependency policies
Console Function
Dependent Service
Role or Policy Required
Overview
Application Operations Management (AOM)
  • An IAM user with the CCE Administrator permission assigned can access the data in Overview only after the AOM FullAccess permission is assigned.
  • IAM users with IAM ReadOnlyAccess, CCE FullAccess, or CCE ReadOnlyAccess assigned can directly access the data in Overview.
Workload management
Elastic Load Balance (ELB)
Application Performance Management (APM)
Object Storage Service (OBS)
Scalable File Service (SFS)
Except in the following cases, the user does not require any additional role to create workloads.
  • To create a LoadBalancer Service, you must have Elastic Load Balancer Operation And Maintenance Administrator and VPC Administrator permissions.
  • To use a Java probe, you must have the AOM FullAccess and APM FullAccess permissions assigned.
  • To create a Service using NAT Gateway, you must have the NAT Gateway Administrator permission assigned.
  • To use OBS, you must have the OBS Administrator permission globally assigned.
    Because of the cache, it takes about 13 minutes for the RBAC policy to take effect after being granted to users, enterprise projects, and user groups. It also takes about 5 minutes for an OBS-related system policy to take effect after being granted.
  • To use SFS, you must have the SFS FullAccess permission assigned.
Cluster management
Billing Center (BSS)
  • Auto scale-out or scale-up requires the AOM FullAccess policy.
  • Changing the billing mode to yearly/monthly requires the BSS Administrator role.
Node management
ECS
If an IAM user has the CCE Administrator role, creating or deleting a node additionally requires ECS FullAccess and VPC Administrator permissions.
Service
Except in the following cases, the user does not require any additional role to create a Service.
  • To create a DNAT Service, you must have NAT Gateway Administrator permissions.
  • To use SFS Turbo, you must have the SFS Turbo FullAccess permission.
The CCE Administrator role is required for importing storage devices.
Namespace management
N/A
N/A
Chart management
N/A
Cloud accounts and the IAM users with CCE Administrator assigned can use this function.
Add-ons
N/A
Cloud accounts and the IAM users with CCE Administrator, CCE FullAccess, or CCE ReadOnlyAccess assigned can use this function.
Permissions management
N/A
  • For cloud accounts, no additional policy/role is required.
  • IAM users with the CCE Administrator or global Security Administrator permission assigned can use this function.
  • IAM users with the CCE FullAccess or CCE ReadOnlyAccess permission can use this function. In addition, the IAM users must have the administrator permissions (cluster-admin) on the namespace.
ConfigMaps and Secrets
N/A
  • Creating ConfigMaps does not require any additional policy.
  • Viewing secrets requires that the cluster-admin, admin, or edit permissions be configured for the namespace. The DEW KeypairFullAccess or DEW KeypairReadOnlyAccess policy must be assigned for dependent services.
Help center
N/A
N/A
Switching to other related services
Software Repository for Container (SWR)
Log Tank Service (LTS)
Multi-Cloud Container Platform (MCP)
The CCE console provides links to other related services. To view or use these services, an IAM user must be assigned required permissions for the services.
