Updated on 2026-06-16 GMT+08:00
Permissions Overview
CCE permissions management allows you to assign permissions to IAM users and user groups under your tenant accounts. CCE combines the advantages of Identity and Access Management (IAM) and Kubernetes Role-based Access Control (RBAC) authorization to provide a variety of authorization methods, including IAM fine-grained authorization, IAM token authorization, cluster-scoped authorization, and namespace-wide authorization.
CCE allows you to manage permissions on clusters and related resources at a finer granularity, for example, to control the access of employees in different departments to cloud resources.
This section describes the CCE permissions management mechanism and related concepts. If your account has met your service requirements, you can skip this section.
CCE Permissions Management
CCE permissions are described as follows:
  • Cluster permissions: Cluster permissions management evolves out of the system policy authorization feature of IAM. IAM users in the same user group have the same permissions. On IAM, you can configure system policies to describe which IAM user groups can perform which operations on cluster resources. For example, you can grant user group A to create and delete cluster X, add a node, or install an add-on, while granting user group B to view information about cluster X.
    Cluster permissions involve non-Kubernetes APIs in CCE clusters and support fine-grained IAM policies and enterprise project management.
  • Namespace permissions: You can regulate users' or user groups' access to Kubernetes resources in a single namespace based on their Kubernetes RBAC roles. CCE has also been enhanced based on open-source capabilities. It supports RBAC authorization based on IAM user or user group, and RBAC authentication on access to APIs using IAM tokens.
    Namespace permissions involve CCE Kubernetes APIs and are enhanced based on the Kubernetes RBAC capabilities. Namespace permissions can be granted to IAM users or user groups for authentication and authorization, but are independent of fine-grained IAM policies.
In general, you configure CCE permissions in two scenarios. The first is creating and managing clusters and related resources, such as nodes. The second is creating and using Kubernetes resources in the cluster, such as workloads and Services.
Figure 1 Permission system
These permissions allow you to manage resource users at a finer granularity.
Relationship Between IAM Role/Policy Permissions and Namespace Permissions
Namespace permissions (assigned through Kubernetes RBAC) vary based on IAM role and policy assignments. Table 1 lists the namespace permissions of different users.
Table 1 Differences in namespace permissions
User
IAM user (including account) with the Tenant Administrator permissions
Full namespace access by default. These users can use all Kubernetes resources in the cluster.
IAM user with the CCE Administrator role
IAM user with the CCE FullAccess or CCE ReadOnlyAccess role
Kubernetes resources can be accessed only after Kubernetes RBAC authorization.
If both storage-related fine-grained permissions and the CCE/tenant administrator role are assigned to a user group, the fine-grained storage permissions are ignored. Administrator role permissions take precedence.
kubectl Permissions
You can use kubectl to access Kubernetes resources in a cluster.
When you access a cluster using kubectl, CCE uses the kubeconfig.json file generated on the cluster for authentication. This file contains user information, based on which CCE determines which Kubernetes resources can be accessed via kubectl. The permissions recorded in a kubeconfig.json file vary from user to user. The permissions that a user has are listed in Table 1.
Federated Users
IAM provides the identity provider function to implement federated identity authentication based on Security Assertion Markup Language (SAML) or OpenID Connect. This function allows users in your management system to access the cloud platform through single sign-on (SSO).
Users who log in through federated identity authentication are called federated users. Federated users are equivalent to IAM users.
Pay attention to the following for federated users to use CCE:
  • When a user creates a CCE cluster, the cluster-admin permission is granted to the user by default. The user ID of a federated user changes upon each login and logout. Therefore, the user is displayed as deleted on the Permissions page of the CCE console. Do not manually delete the permission, otherwise, the authentication fails. In this case, you are advised to grant the cluster-admin permission to a user group on CCE and add federated users to the user group.
  • Federated users cannot create permanent access keys (AKs/SKs). In scenarios where AKs/SKs are required (for example, when creating OBS-related PVs/PVCs), only you or an IAM user can create the AK/SK and share them with the federated users. An access key contains the permissions granted to a user, so it is recommended that the federated user request an IAM user in the same group to create an access key.
Supported Actions in IAM
CCE provides system-defined policies that can be directly used in IAM. You can also create custom policies to supplement system-defined policies for more refined access control. Operations supported by policies are specific to APIs. The common concepts related to policies are listed below.
  • Permissions: statements that allow or deny certain operations in a policy
  • APIs: APIs that can be called in a custom policy
  • Actions: specific operations that are allowed or denied in a custom policy
  • Dependencies: actions which a specific action depends on. When allowing an action for a user, you also need to allow any existing action dependencies for that user.
  • IAM projects/Enterprise projects: the authorization scope of a custom policy. A custom policy can be applied to IAM projects or enterprise projects or both. Policies that contain actions for both IAM and enterprise projects can be used and applied to both IAM and Enterprise Management. Policies that contain actions only for IAM projects can be assigned to user groups and be applied only within IAM. They cannot be applied within Enterprise Management. For details about the differences between IAM and enterprise management, see What Are the Differences Between IAM and Enterprise Management?
The check mark (√) and cross symbol (×) respectively indicate that an action takes effect or does not take effect for the corresponding type of projects.
CCE supports the following actions in custom policies.
Table 2 Cluster
Permission
API
Action
IAM Project
Enterprise Project
Obtaining clusters in a project
GET /api/v3/projects/{project_id}/clusters
cce:cluster:list
Yes
Yes
Obtaining a cluster
GET /api/v3/projects/{project_id}/clusters/{cluster_id}
cce:cluster:get
Yes
Yes
Creating a cluster
POST /api/v3/projects/{project_id}/clusters
cce:cluster:create
Yes
Yes
Updating a cluster
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}
cce:cluster:update
Yes
Yes
Deleting a cluster
DELETE /api/v3/projects/{project_id}/clusters/{cluster_id}
cce:cluster:delete
Yes
Yes
Upgrading a cluster
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgrade
cce:cluster:upgrade
Yes
Yes
Waking up a cluster
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/awake
cce:cluster:start
Yes
Yes
Hibernating a cluster
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/hibernate
cce:cluster:stop
Yes
Yes
Resizing a cluster
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/resize
cce:cluster:resize
Yes
Yes
Obtaining a cluster certificate
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/clustercert
cce:cluster:get
Yes
Yes
Obtaining the global OBS access secret configuration
GET /api/v3/projects/{project_id}/longaksk/config
cce:longaksk:getConfig
Yes
Yes
Updating the global OBS access secret configuration
PUT /api/v3/projects/{project_id}/longaksk/config
cce:longaksk:updateConfig
Yes
Yes
Updating the global OBS access secret configuration of a cluster
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/longaksk/config
cce:cluster:updateLongAKSKConfig
Yes
Yes
Obtaining the global OBS access secret configuration of a cluster
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/longaksk/config
cce:cluster:getLongAKSKConfig
Yes
Yes
Revoking a cluster certificate
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/clustercertrevoke
cce:cluster:revokeClientCredential
Yes
Yes
Updating a partition
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/partitions/{partition_name}
cce:partition:update
Yes
Yes
Creating a partition
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/partitions
cce:partition:create
Yes
Yes
Obtaining partition information
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/partitions/{partition_name}
cce:partition:get
Yes
Yes
Listing all partitions
cce:partition:list
Yes
Yes
Table 3 Node
Permission
API
Action
IAM Project
Enterprise Project
Obtaining all nodes in a cluster
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes
cce:node:list
Yes
Yes
Obtaining a node
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/{node_id}
cce:node:get
Yes
Yes
Creating a node
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes
cce:node:create
Yes
Yes
If you use enterprise project authorization to create a node, you need to add the global permission of evs:quotas:get and evs:types:get.
Updating a node
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/{node_id}
cce:node:update
Yes
Yes
Deleting a node
DELETE /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/{node_id}
cce:node:delete
Yes
Yes
Removing a node
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/operation/remove
cce:node:remove
Yes
Yes
Migrating a node
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/operation/migrateto/{target_cluster_id}
cce:node:migrate
Yes
Yes
Table 4 Job
Permission
API
Action
IAM Project
Enterprise Project
Obtaining information about a job
GET /api/v3/projects/{project_id}/jobs/{job_id}
cce:job:get
Yes
Yes
Listing all jobs
GET /api/v2/projects/{project_id}/jobs
cce:job:list
Yes
Yes
Deleting one or all jobs
DELETE /api/v2/projects/{project_id}/jobs
DELETE /api/v2/projects/{project_id}/jobs/{job_id}
cce:job:delete
Yes
Yes
Table 5 Nodepool
Permission
API
Action
IAM Project
Enterprise Project
Listing all node pools in a cluster
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools
cce:nodepool:list
Yes
Yes
Obtaining a node pool
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools/{nodepool_id}
cce:nodepool:get
Yes
Yes
Creating a node pool
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools
cce:nodepool:create
Yes
Yes
Updating a node pool
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools/{nodepool_id}
cce:nodepool:update
Yes
Yes
Deleting a node pool
DELETE /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools/{nodepool_id}
cce:nodepool:delete
Yes
Yes
Scaling a node pool
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools/{nodepool_id}/operation/scale
cce:nodepool:scale
Yes
Yes
Table 6 Chart
Permission
API
Action
IAM Project
Enterprise Project
Updating a chart
PUT /v2/charts/{id}
cce:chart:update
Yes
Not supported
Uploading a chart
POST /v2/charts
cce:chart:upload
Yes
Not supported
Listing all charts
GET /v2/charts
cce:chart:list
Yes
Not supported
Obtaining a chart
GET /v2/charts/{id}
cce:chart:get
Yes
Not supported
Deleting a chart
DELETE /v2/charts/{id}
cce:chart:delete
Yes
Not supported
Table 7 Release
Permission
API
Action
IAM Project
Enterprise Project
Updating a release
PUT /v2/releases/{name}
cce:release:update
Yes
Yes
Listing all releases
GET /v2/releases
cce:release:list
Yes
Yes
Creating a release
POST /v2/releases
cce:release:create
Yes
Yes
Obtaining a release
GET /v2/releases/{name}
cce:release:get
Yes
Yes
Deleting a release
DELETE /v2/releases/{name}
cce:release:delete
Yes
Yes
Table 8 Storage
Permission
API
Action
IAM Project
Enterprise Project
Creating a PVC
POST /api/v1/namespaces/{namespace}/cloudpersistentvolumeclaims
cce:storage:create
Yes
Yes
Deleting a PVC
DELETE /api/v1/namespaces/{namespace}/cloudpersistentvolumeclaims/{name}
cce:storage:delete
Yes
Yes
Listing all volumes
GET /storage/api/v1/namespaces/{namespace}/listvolumes
cce:storage:list
Yes
Yes
Table 9 Addon
Permission
API
Action
IAM Project
Enterprise Project
Creating an add-on pod
POST /api/v3/addons
cce:addonInstance:create
Yes
Yes
Obtaining an add-on pod
GET /api/v3/addons/{id}?cluster_id={cluster_id}
cce:addonInstance:get
Yes
Yes
Listing all add-on pods
GET /api/v3/addons?cluster_id={cluster_id}
cce:addonInstance:list
Yes
Yes
Deleting an add-on pod
DELETE /api/v3/addons/{id}?cluster_id={cluster_id}
cce:addonInstance:delete
Yes
Yes
Updating an add-on pod
PUT /api/v3/addons/{id}
cce:addonInstance:update
Yes
Yes
Rolling back an add-on pod
POST /api/v3/addons/{id}/operation/rollback
cce:addonInstance:rollback
Yes
Yes
Listing all add-on templates
GET /api/v3/addontemplates
cce:addonTemplate:list
Yes
Not supported
Table 10 Quota
Permission
API
Action
IAM Project
Enterprise Project
Obtaining quota details
GET /api/v3/projects/{project_id}/quotas
cce:quota:get
Yes
Yes
Table 11 Resource tags
Permission
API
Action
IAM Project
Enterprise Project
Adding resource tags to a cluster
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/tags/create
cce:tag:operate
Yes
Yes
Deleting resource tags from a cluster
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/tags/delete
cce:tag:operate
Yes
Yes
Table 12 Access policies
Permission
API
Action
IAM Project
Enterprise Project
Creating an access policy
POST /api/v3/access-policies
cce:accessPolicy:post
Yes
Not supported
Obtaining the access policy list
GET /api/v3/access-policies
cce:accessPolicy:list
Yes
Not supported
Obtaining an access policy
GET /api/v3/access-policies/{policy_id}
cce:accessPolicy:get
Yes
Not supported
Deleting an access policy
DELETE /api/v3/access-policies/{policy_id}
cce:accessPolicy:delete
Yes
Not supported
Updating an access policy
PUT /api/v3/access-policies/{policy_id}
cce:accessPolicy:put
Yes
Not supported
