Configuring the Container Lifecycle
Container lifecycle hooks are core mechanisms provided by Kubernetes. They enable you to insert custom logic at key phases throughout the container lifecycle. These hooks provide refined process controls over containerized applications, enabling applications to better adapt to the dynamic characteristics of the cloud native environment. CCE provides the following container lifecycle hooks. For more information, see Container Lifecycle Hooks.
- Startup Command: the command executed when a container starts. It is used to define the main process of a container. The main process is the default entry after the container starts, and its status determines the container lifecycle. This kind of hook is applicable to initialization scenarios where the application entry, environment variables, mount points, or port mapping needs to be specified.
- PostStart Hook: used to execute initialization tasks, such as service registration and dynamic configuration generation, immediately after the main process of a container starts. Such a hook is asynchronously triggered by kubelet and runs in parallel with the main process, preventing the container startup process from being blocked and accelerating the container readiness. This kind of hook is applicable to the scenario where the environment needs to be configured or the initialization logic needs to be executed immediately after the application process starts.
- PreStop Hook: used to execute predefined cleanup logic before a container is terminated. When a pod is deleted or updated, kubelet triggers this hook to perform operations (such as deregistering services and refreshing status), and then sends the SIGTERM signal to the main process of a container for the application to shut down gracefully. This kind of hook is applicable to the scenario where safe shutdown is required to avoid data loss or there are service exceptions.
Startup Command
A startup command is executed when a container starts. It is used to define the main process of a container. The main process status determines the container lifecycle. If the command fails to be executed and no restart policy is configured, the container will be terminated.
By default, the default command is executed during image start. To run a specific command or rewrite the default image setting, you must perform specific operations. By default, the container executes the startup command preset in the image. Docker images contain a set of metadata fields for defining the startup behavior, including ENTRYPOINT and CMD. If the commands and arguments (specified by Command and Args) are not configured in the container specifications, the default values during image build are used.
If the commands and arguments used to run a container are configured during workload creation, the default commands ENTRYPOINT and CMD are overwritten during image build. The rules are as follows:
| Image ENTRYPOINT | Image CMD | Command to Run a Container | Argument to Run a Container | Command Executed |
| [touch] | [/root/test] | Not set | Not set | [touch /root/test] |
| [touch] | [/root/test] | [mkdir] | Not set | [mkdir] |
| [touch] | [/root/test] | Not set | [/opt/test] | [touch /opt/test] |
| [touch] | [/root/test] | [mkdir] | [/opt/test] | [mkdir /opt/test] |
- Log in to the CCE console.
- Click the cluster name to go to the cluster console, choose Workloads in the navigation pane, and click Create Workload in the upper right corner.
- In Container Settings, choose Container Information > Lifecycle > Startup Command and enter the command and arguments. Figure 1 Configuring a startup command
Table 2 Container startup command Parameter
Example Value
Example YAML
Command
- /bin/sh
Enter one or more executable commands. If you need multiple commands, separate them on different lines.
NOTE:In the case of multiple commands, you are advised to run /bin/sh or other shell commands. Other commands are used as parameters.
... spec: containers: - image: nginx:latest command: - /bin/sh args: - '-c' - sleep 10 ...Args
- -c
- sleep 10
Enter one or more arguments. If you need multiple arguments, separate them on different lines.
- Configure other parameters and click Create Workload in the lower right corner. If the workload is in the Running state, the startup command is successfully executed.
PostStart Hook
A PostStart hook, a container lifecycle hook provided by Kubernetes, is used to execute initialization tasks, such as service registration and dynamic configuration generation, immediately after the main process of a container starts. This hook is asynchronously triggered by kubelet and runs in parallel with the main process. Although the PostStart hook is executed asynchronously with the main process of the container, if the PostStart hook takes too long or is suspended, the container may not change to the Running state. If the PostStart hook fails to be executed, the container may fail to start and be terminated.
- In Container Settings, choose Container Information > Lifecycle > Post-Start and configure parameters. based on the service requirements. For example:
- If initialization logic (such as running scripts and configuring the environment) needs to be executed in the container, select CLI.
- When external systems or services require notification, for example, registering a service or calling a Settings API, select HTTP request.
Figure 2 CLI
Table 3 Post-start processing Processing Method
Example Value
Example YAML
CLI
Run the following commands to write the message file to the container's /usr/share directory:
- /bin/sh
- -c
- echo Hello from the postStart handler > /usr/share/message
Used for running the commands in the container. You need to configure Command.
The command format is Command Arg[1] Arg[2]..., where Command indicates a system command or a user-defined executable program. If no path is specified, the system searches for the command in the default path. If multiple commands needed to be executed, write them into a script in the container image in advance and invoke the script using this command. The executable command must be executed synchronously or in the frontend. If it is executed asynchronously or in the backend, the lifecycle hook may fail to be executed.
CAUTION:Ensure that the postStart script runs to completion and exits properly. Otherwise, subsequent pod status updates and pod deletion will be affected.
... lifecycle: postStart: exec: command: - /bin/sh - '-c' - echo Hello from the postStart handler > /usr/share/message ...HTTP request
- Path: /nginx
- Port: 80
- Host: 127.0.0.1
Used for initiating an HTTP request. The related parameters are described as follows:
- Path: (optional) request URL.
- Port: (mandatory) requested port.
- Host: (optional) requested host IP address. The default value is the IP address of the pod.
lifecycle: postStart: httpGet: path: /nginx port: 80 host: 127.0.0.1 scheme: HTTP ... - Configure other parameters and click Create Workload in the lower right corner. After a period of time, the workload status changes to Running.
PreStop Hook
If a container crashes or exits abnormally, the PreStop hook will not be triggered. The pod's termination grace period starts to count down before the PreStop hook is executed. Regardless of the outcome of the hook handler, the container will be terminated within the pod's termination grace period unless the finalizer delays the termination process. Other management operations on the container are blocked until the PreStop hook is complete or the termination grace period is reached.
- In Container Settings, choose Container Information > Lifecycle > Pre-Stop and configure parameters. Figure 3 Pre-stop processing
Table 4 Pre-stop processing parameters Parameter
Example Value
Example YAML
CLI
Enter the following commands to gracefully stop the Nginx service:
- /bin/sh
- -c
- nginx -s quit; while killall -0 nginx; do sleep 1; done
... lifecycle: preStop: exec: command: - /bin/sh - '-c' - nginx -s quit; while killall -0 nginx; do sleep 1; done ...HTTP request
- Path: /nginx
- Port: 80
- Host: 127.0.0.1
lifecycle: preStop: httpGet: path: /nginx port: 80 host: 127.0.0.1 scheme: HTTP ... - Configure other parameters and click Create Workload in the lower right corner. After a period of time, the workload status changes to Running.
Example YAML
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file for configuring a workload. In this example, the file name is lifecycle.yaml. You can change it as needed.
vim lifecycle.yamlExample file content:apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 1 selector: matchLabels: app: nginx template: metadata: labels: app: nginx spec: containers: - image: nginx command: # Startup command: Pause the current process for 10 seconds. - /bin/sh args: - '-c' - sleep 10 imagePullPolicy: Always lifecycle: postStart: # Post-start command: Write the message file to the container's /usr/share directory. exec: command: - /bin/sh - '-c' - echo Hello from the postStart handler > /usr/share/message preStop: # Pre-stop command: Gracefully stop the Nginx service. exec: command: - /bin/sh - '-c' - nginx -s quit; while killall -0 nginx; do sleep 1; done name: nginx imagePullSecrets: - name: default-secret - Create the workload.
kubectl create -f lifecycle.yamlIf information similar to the following is displayed, the workload is being created:
deployment.apps/nginx created
- Check the workload status.
kubectl get deployment
If all the pods of the workload are available, the workload has been created.
NAME READY UP-TO-DATE AVAILABLE AGE nginx 1/1 1 1 4m59s
Helpful Links
- Learn more about workload parameters. For details, see Creating a Workload.
- After a workload is created, you can upgrade it, edit its YAML file, and view its logs. For details, see Managing Workloads.
- If a workload fails to be created, rectify the fault by referring to Workload Exception Troubleshooting.
