Updated on 2026-06-16 GMT+08:00
Enabling ICMP Security Group Rules
When using a UDP load balancer, health checks also use UDP. Since UDP is connectionless, ICMP is required to verify network connectivity. Therefore, ICMP security group rules must be enabled for backend servers. For details, see How Does ELB Perform UDP Health Checks? What Are the Precautions for UDP Health Checks?
  1. Log in to the VPC console and choose Access Control > Security Groups.
  2. In the security group list, locate the security group of the cluster. Click Manage Rules in the Operation column. On the page displayed, click Add Rule to add the inbound rules below.
    Cluster Type
    Load Balancer Type
    Security Group
    Protocol & Port
    Allowed Source CIDR Block
    CCE Standard
    Shared
    Node security group, which is named in the format of "{Cluster name}-cce-node-{Random ID}".
    If a custom node security group is bound to the cluster, select the target security group.
    All ICMP ports
    100.125.0.0/16 for the shared load balancer
    Dedicated
    All ICMP ports
    Backend subnet of the load balancer
    To obtain subnet CIDR blocks, log in to the ELB console, choose Load Balancers, and click the name of the target load balancer. On the Summary tab, click the link following the backend subnet.
    CCE Turbo
    Shared
    All ICMP ports
    Dedicated
    ENI security group, which is named in the format of "{Cluster name}-cce-eni-{Random ID}".
    If a custom security group is bound to the cluster, select the target security group.
    All ICMP ports
    Figure 1 Adding a security group rule
  3. Click OK.
