DNAT
A DNAT Service provides Network Address Translation (NAT) for all nodes in a cluster so that multiple nodes can share an EIP. The access address of a DNAT Service is in the format of <EIP-of-the-NAT-gateway>:<access-port>, for example, 10.117.117.117:80.
If pods require temporary or low-volume access from the Internet, you can create a DNAT Service. DNAT Services provide higher reliability than NodePort Services. With a DNAT Service, there is no need to bind an EIP to a single node, and requests can still be distributed to the workload even any of the nodes inside is down.
Notes and Constraints
Observe the following constraints when using the NAT Gateway service:
- DNAT rules do not support enterprise project authorization.
- Containers in the cluster cannot access the DNAT Service whose externalTrafficPolicy is Local.
- Multiple rules for one NAT gateway can use the same EIP, but the rules for different NAT gateways must use different EIPs.
- Each VPC can have only one NAT gateway.
- Users cannot manually add the default route in a VPC.
- Only one SNAT rule can be added to a subnet in a VPC.
- SNAT and DNAT rules are designed for different functions. If SNAT and DNAT rules use the same EIP, resource preemption will occur. An SNAT rule cannot share an EIP with a DNAT rule with Port Type set to All ports.
- DNAT rules do not support binding an EIP to a virtual IP address.
- When both the EIP and NAT Gateway services are configured for a server, data will be forwarded through the EIP.
- If an SNAT rule is added for a VPC, the custom CIDR block must be a subset of the NAT gateway's VPC subnets.
- If an SNAT rule is added for a Direct Connect connection, the custom CIDR block must be the CIDR block of a Direct Connect connection and cannot overlap with that of the NAT gateway's VPC.
- When you perform operations on underlying resources of an ECS, for example, changing its specifications, the configured NAT gateway rules become invalid. Delete the rules and reconfigure them.
- After a Service is created, if the affinity setting is switched from the cluster level to the node level, the connection tracing table will not be cleared. Do not modify the Service affinity setting after the Service is created. To modify it, create a Service again.
- To use a DNAT Service, ensure that the route table contains the NAT route. If the node subnet is associated with a custom route table, add the NAT route to the custom route table.
Preparations: Creating a NAT Gateway and an EIP
You have purchased a NAT gateway and an EIP. The specific procedure is as follows:
- Log in to the NAT Gateway console and click Buy Public NAT Gateway in the upper right corner. Configure parameters based on service requirements.
After purchasing a NAT gateway, you do not need to add SNAT or DNAT rules.
When purchasing a NAT gateway, ensure that the NAT gateway belongs to the same VPC and subnet as the CCE cluster where the workload is running.
Figure 2 Purchasing a NAT gateway
- Log in to the EIP console and click Buy EIP in the upper right corner. Configure parameters based on service requirements. Figure 3 Purchasing an EIP
Creating a DNAT Service
Use one of the following methods.
- In the navigation pane, choose Services & Ingresses. In the upper right corner, click Create Service.
- Configure basic settings.
Service Type
Select DNAT.
Service Name
Enter a name, which can be the same as the workload name.
Namespace
Select the namespace that the workload belongs to.
Selector
Add the key and value of a pod label. The Service will be associated with the workload pods based on the label and direct traffic to the pods with this label.
You can also click Reference Workload Label to use the label of an existing workload. In the dialog box displayed, select a workload and click OK.
- Configure access parameters.
Service Affinity
Whether to route external traffic to a local node or a cluster-wide endpoint. For details, see Service Affinity (externalTrafficPolicy).- Cluster-level: The IP addresses and ports of all nodes in a cluster can access the workload associated with the Service. However, accessing the Service may result in a performance deterioration due to route redirection, and the client's source IP address may not be obtainable.
- Node-level: Only the IP address and port of the node where the workload is located can access the workload associated with the Service. Accessing the Service will not result in a performance deterioration due to route redirection, and the client's source IP address can be obtained.
DNAT
Select the DNAT gateway and EIP purchased in Preparations: Creating a NAT Gateway and an EIP.
Port
- Protocol: the protocol supported by the Service.
- Container Port: the listening port of the service containers. The port ranges from 1 to 65535. You need to determine the port based on the container image. For example, the default port of Nginx is 80, and the default port of MySQL is 3306.
- Service Port: the port used to access the DNAT Service. You can customize the port as required. The port ranges from 1 to 65535.
- Click Create.
- Configure DNAT gateway parameters.
Service Name
Service Type
Select DNAT.
Namespace
Service Affinity
Selector
You can add a key and value for the pod label and click Confirm.
DNAT
Port
- Click OK.
You can configure Service access when creating a workload using kubectl. This section uses an Nginx workload as an example to describe how to implement intra-cluster access using kubectl.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create and edit the nginx-deployment.yaml file to configure the sample workload. For details, see Creating a Deployment. nginx-deployment.yaml is an example file name. You can change the file name if you want to.
vi nginx-deployment.yaml
File content:apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 1 selector: matchLabels: app: nginx template: metadata: labels: app: nginx spec: containers: - image: nginx:latest name: nginx imagePullSecrets: - name: default-secret - Create and edit the nginx-nat-svc.yaml file to configure Service parameters. nginx-nat-svc.yaml is an example file name. You can change the file name if you want to.
vi nginx-nodeport-svc.yaml
File content:
apiVersion: v1 kind: Service metadata: name: nginx-nat annotations: kubernetes.io/elb.class: dnat kubernetes.io/natgateway.id: e4a1cfcf-29df-4ab8-a4ea-c05dc860f554 spec: loadBalancerIP: 10.78.42.242 ports: - name: service0 port: 80 protocol: TCP targetPort: 80 selector: app: nginx type: LoadBalancerTable 1 Key parameters Parameter
Mandatory
Type
Yes
String
This parameter is set to dnat, which is used to access the NAT Gateway service and add DNAT rules. This parameter cannot be modified after the Service is created.
Yes
String
ID of a NAT gateway. This parameter cannot be modified after the Service is created.
How to obtain:
On the management console, click Service List and choose Networking > NAT Gateway. Click the name of the target NAT gateway to access its details page. On the Basic Information tab, find and copy the ID.
loadBalancerIP
Yes
String
Enter the EIP associated with the NAT gateway.
port
Yes
Integer
The port used to access the DNAT Service. You can customize the port as required. The port ranges from 1 to 65535.
targetPort
Yes
String
The listening port of the service containers. The port ranges from 1 to 65535. You need to determine the port based on the container image. For example, the default port of Nginx is 80, and the default port of MySQL is 3306.
type
Yes
String
NAT gateway service type must be set to LoadBalancer.
- Create a workload.
kubectl create -f nginx-deployment.yaml
If information similar to the following is displayed, the workload has been created:
deployment/nginx created
Check the created workload.
kubectl get pod
If information similar to the following is displayed, the workload is running:
NAME READY STATUS RESTARTS AGE nginx-2601814895-znhbr 1/1 Running 0 15s
- Create a Service.
kubectl create -f nginx-nat-svc.yaml
If information similar to the following is displayed, the Service is being created:
service/nginx-nat created
Check the created Service.
kubectl get svc
If information similar to the following is displayed, the Service has been created:
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE kubernetes ClusterIP 10.247.0.1 <none> 443/TCP 3d nginx-nat LoadBalancer 10.247.226.2 **.**.**.** 80:30589/TCP 5s
- Enter the URL, which is in the format of <EIP>:<port>, in the address bar of a browser.
