Logging In to a Container
If you encounter unexpected problems when using a container, you can log in to the container to debug it.
Notes and Constraints
- When kubectl is used in CloudShell, permissions are determined by the logged-in user.
- CloudShell does not support an account or sub-project agency.
- When using CloudShell to access a CCE cluster or container, you can open up to 15 instances concurrently.
- The kubectl certificate in CloudShell is valid for one day. You can reset its validity period by accessing CloudShell through the CCE console.
- Using CloudShell to access containers is available only in the following regions: CN North-Beijing1, CN North-Beijing4, CN North-Ulanqab1, CN East-Shanghai1, CN East-Shanghai2, CN South-Guangzhou, CN Southwest-Guiyang1, and AP-Singapore. For details, see the console.
Using CloudShell
CloudShell is implemented based on VPC Endpoint (VPCEP). To use kubectl to access a cluster, configure the security group (Cluster name-cce-control-Random number) on the master node of the cluster to allow access to port 5443. By default, port 5443 allows access from all CIDR blocks. If you have hardened security groups and any cluster cannot be accessed in CloudShell, check whether port 5443 allows access from 198.19.0.0/16.
- Choose Workloads in the navigation pane. In the right pane, click the name of the target workload to view its pods.
- Locate the target pod and choose More > Remote Login in the Operation column.
Figure 1 Accessing a container
- In the displayed dialog box, select the container you want to access and the command, and click OK.
Figure 2 Selecting a container and login command
- You are automatically redirected to CloudShell. Then, the system initializes kubectl and runs the kubectl exec command to log in to the container.
Wait for 5 to 10 seconds until the kubectl exec command is automatically executed.
Figure 3 CloudShell page
Using kubectl
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Run the following command to view the created pod:
kubectl get pod
The example output is as follows:NAME READY STATUS RESTARTS AGE nginx-59d89cb66f-mhljr 1/1 Running 0 11m
- Query the container name in the pod.
kubectl get po nginx-59d89cb66f-mhljr -o jsonpath='{range .spec.containers[*]}{.name}{end}{"\n"}'
The example output is as follows:container-1
- Run the following command to log in to the container-1 container in the nginx-59d89cb66f-mhljr pod:
kubectl exec -it nginx-59d89cb66f-mhljr -c container-1 -- /bin/sh
- To exit the container, run the exit command.
Helpful Links
- To learn more about workload parameters, see Creating a Workload.
- After a workload is created, you can upgrade it, edit its YAML file, view its logs, and perform other operations on it. For details, see Managing Workloads.
- If a workload fails to be created, rectify the fault by referring to Workload Exception Troubleshooting.
- Access an external network from a pod.
