Using a ConfigMap
After a ConfigMap is created, it can be used in three workload scenarios: environment variables, command line parameters, and data volumes.
- Configuring Environment Variables of a Workload
- Configuring Command Line Parameters
- Mounting a ConfigMap to a Workload Data Volume
The following example shows how to use a ConfigMap.
apiVersion: v1 kind: ConfigMap metadata: name: cce-configmap data: SPECIAL_LEVEL: Hello SPECIAL_TYPE: CCE
- When a ConfigMap is used in a workload, the workload and ConfigMap must be in the same cluster and namespace.
- When a ConfigMap is mounted as a data volume and the ConfigMap has been updated, Kubernetes periodically and automatically updates the data in the data volume.
For a ConfigMap data volume mounted in subPath mode, Kubernetes cannot automatically update data in the data volume when the ConfigMap is updated.
- When a ConfigMap is used as an environment variable, data is not automatically updated when the ConfigMap is updated. To update the data, restart the pod.
Using the CCE console
- In the navigation pane, choose Workloads. In the right pane, click Create Workload in the upper right corner.
When creating a workload, click Environment Variables in the Container Settings area, and click Add Variable.
- Added from ConfigMap: Select a ConfigMap to import all of its keys as environment variables.
- Added from ConfigMap key: Import a key from a ConfigMap as the value of an environment variable.
- Variable Name: name of an environment variable in the workload. The name can be customized and is set to the key name selected in the ConfigMap by default.
- Variable Value/Reference: Select a ConfigMap and the key to be imported. The corresponding value is imported as a workload environment variable.
For example, after you import the value Hello of SPECIAL_LEVEL in ConfigMap cce-configmap as the value of workload environment variable SPECIAL_LEVEL, an environment variable named SPECIAL_LEVEL with its value Hello exists in the container.
- Configure other workload parameters and click Create Workload.
After the workload runs properly, log in to the container and run the following statement to check whether the ConfigMap has been set as an environment variable of the workload:
printenv SPECIAL_LEVEL
Example output:
Hello
Using kubectl
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a file named nginx-configmap.yaml and edit it.
vi nginx-configmap.yaml
Content of the YAML file:
- Added from ConfigMap: To add all data in a ConfigMap to environment variables, use the envFrom parameter. The keys in the ConfigMap will become names of environment variables in the workload.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-configmap spec: replicas: 1 selector: matchLabels: app: nginx-configmap template: metadata: labels: app: nginx-configmap spec: containers: - name: container-1 image: nginx:latest envFrom: # Use envFrom to specify a ConfigMap to be referenced by environment variables. - configMapRef: name: cce-configmap # Name of the referenced ConfigMap. imagePullSecrets: - name: default-secret - Added from ConfigMap key: When creating a workload, you can use a ConfigMap to set environment variables and use the valueFrom parameter to reference the key-value pair in the ConfigMap separately.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-configmap spec: replicas: 1 selector: matchLabels: app: nginx-configmap template: metadata: labels: app: nginx-configmap spec: containers: - name: container-1 image: nginx:latest env: # Set the environment variable in the workload. - name: SPECIAL_LEVEL # Name of the environment variable in the workload. valueFrom: # Use valueFrom to specify a ConfigMap to be referenced by environment variables. configMapKeyRef: name: cce-configmap # Name of the referenced ConfigMap. key: SPECIAL_LEVEL # Key in the referenced ConfigMap. - name: SPECIAL_TYPE # Add multiple environment variables. valueFrom: configMapKeyRef: name: cce-configmap key: SPECIAL_TYPE imagePullSecrets: - name: default-secret
- Create the workload.
kubectl apply -f nginx-configmap.yaml
- View the environment variables in the pod.
- Run the following command to view the created pod:
kubectl get pod | grep nginx-configmap
Expected output:nginx-configmap-*** 1/1 Running 0 2m18s
- Run the following command to view the environment variables in the pod:
kubectl exec nginx-configmap-*** -- printenv SPECIAL_LEVEL SPECIAL_TYPE
Expected output:
Hello CCE
The ConfigMap has been set as environment variables of the workload.
You can use a ConfigMap as an environment variable to set commands or parameter values for a container by using the environment variable substitution syntax $(VAR_NAME).
When creating a workload, click Environment Variables in the Container Settings area, and click Add Variable. In this example, select Added from ConfigMap.
- Click Lifecycle in the Container Settings area, click the Post-Start tab on the right, and configure parameters.
- Processing Method: CLI
- Command: Enter the three command lines below. SPECIAL_LEVEL and SPECIAL_TYPE are the environment variable names in the workload, which are key names in the cce-configmap ConfigMap.
/bin/bash -c echo $SPECIAL_LEVEL $SPECIAL_TYPE > /usr/share/nginx/html/index.html
cat /usr/share/nginx/html/index.html
Example output:
Hello CCE
Using kubectl
In the following example, the cce-configmap ConfigMap is imported to the workload. SPECIAL_LEVEL and SPECIAL_TYPE are the environment variable names in the workload, which are key names in the cce-configmap ConfigMap.apiVersion: apps/v1 kind: Deployment metadata: name: nginx-configmap spec: replicas: 1 selector: matchLabels: app: nginx-configmap template: metadata: labels: app: nginx-configmap spec: containers: - name: container-1 image: nginx:latest lifecycle: postStart: exec: command: [ "/bin/sh", "-c", "echo $SPECIAL_LEVEL $SPECIAL_TYPE > /usr/share/nginx/html/index.html" ] envFrom: # Use envFrom to specify a ConfigMap to be referenced by environment variables. - configMapRef: name: cce-configmap # Name of the referenced ConfigMap. imagePullSecrets: - name: default-secret - Create the workload.
- Wait until the workload runs properly. Then, the content below will be added to the /usr/share/nginx/html/index.html file in the container.
kubectl exec nginx-configmap-*** -- cat /usr/share/nginx/html/index.htmlExpected output:
Hello CCE
The data stored in a ConfigMap can be referenced in a volume of type ConfigMap. You can mount such a volume to a specified container path. The platform supports the separation of workload codes and configuration files. ConfigMap volumes are used to store workload configuration parameters. Create ConfigMaps beforehand. For details, see Creating a ConfigMap.
When creating a workload, click Data Storage in the Container Settings area. Click Add Volume and choose ConfigMap from the drop-down list.
- Select parameters for mounting a ConfigMap, as shown in Table 1.
Table 1 Mounting a ConfigMap Parameter
ConfigMap
Select the desired ConfigMap.
A ConfigMap must be created beforehand. For details, see Creating a ConfigMap.
Mount Path
Enter a mount path. After the ConfigMap is mounted, a configuration file with the key as the file name and value as the file content is generated in the mount path of the container.
This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run, or there will be an error. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.NOTICE:If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host machine may be damaged.
Subpath
Enter a subpath of the mount path.- A subpath is used to mount a local volume so that the same data volume is used in a single pod. If this parameter is left blank, the root path will be used by default.
- The subpath can be the key and value of a ConfigMap. If the subpath is a key-value pair that does not exist, the data import does not take effect.
- The data imported by specifying a subpath will not be updated along with the ConfigMap updates.
Permission
Read-only, indicating that data volume in the path is read-only.
Figure 1 Mounting a ConfigMap to a workload data volume
- After the configuration, click Create Workload.
After the workload runs properly, the SPECIAL_LEVEL and SPECIAL_TYPE files will be generated in the /etc/config directory in this example. The contents of the files are Hello and CCE, respectively.
Access the container and run the following statement to view the SPECIAL_LEVEL or SPECIAL_TYPE file in the container:
cat /etc/config/SPECIAL_LEVELExpected output:
Hello
Using kubectl
As shown in the following example, after the ConfigMap is mounted, a configuration file with the key as the file name and value as the file content is generated in the /etc/config directory of the container.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-configmap spec: replicas: 1 selector: matchLabels: app: nginx-configmap template: metadata: labels: app: nginx-configmap spec: containers: - name: container-1 image: nginx:latest volumeMounts: - name: config-volume mountPath: /etc/config # Mount to the /etc/config directory. readOnly: true volumes: - name: config-volume configMap: name: cce-configmap # Name of the referenced ConfigMap. - Create a workload.
- Wait until the workload runs properly. The SPECIAL_LEVEL and SPECIAL_TYPE files will be generated in the /etc/config directory. The contents of the files are Hello and CCE, respectively.
- Run the following command to view the SPECIAL_LEVEL or SPECIAL_TYPE file in the pod:
kubectl exec nginx-configmap-*** -- cat /etc/config/SPECIAL_LEVEL
Expected output:
Hello
