Updated on 2026-06-16 GMT+08:00
Workload Overview
A workload is an application running on Kubernetes. No matter how many components are there in your workload, you can run it in a group of Kubernetes pods. A workload is an abstract model of a group of pods in Kubernetes. Workloads in Kubernetes are classified as Deployments, StatefulSets, DaemonSets, jobs, and CronJobs.
CCE provides Kubernetes-native container deployment and management and supports lifecycle management of container workloads, including creation, configuration, monitoring, auto scaling, upgrades, uninstallation, service discovery, and load balancing.
Overview of Pods
Pods are the smallest unit that you can create or deploy in Kubernetes. Each pod comprises one or more containers, shared storage (volumes), a unique IP address, and container runtime policies.
Pods can be used in either of the following ways:
  • A pod runs a single container. This is the most common scenario in Kubernetes. In this case, a pod can be thought of as a container, although Kubernetes manages the pod rather than the container itself.
  • A pod runs multiple tightly coupled containers that need to share resources. In this case, the pod includes a main container and several sidecar containers, as shown in Figure 1. For example, the main container might be a web server providing file services from a fixed directory, while sidecar containers periodically download files to that directory.
    Figure 1 A pod running multiple containers
In Kubernetes, you rarely create pods directly. Instead, controllers like Deployments and jobs create and manage them. These controllers typically use pod templates to create and manage pods, providing features like replica management, rolling upgrades, and self-healing.
Overview of Deployments
A pod is the smallest unit that you create or deploy in Kubernetes. It is evicted when resources are tight and gone if its node fails. Kubernetes provides controllers to manage pods. These controllers create and manage pods, providing features like replica management, rolling upgrades, and self-healing. The most common controller is Deployment.
Figure 2 Relationship between a Deployment and pods
A Deployment runs one or more identical pods. Kubernetes load-balances traffic across them.
A Deployment handles rollout, rolling upgrades, scaling, and automatic replacement of failed pods. This enables zero-touch releases with minimal risk.
Overview of StatefulSets
All pods under a Deployment are identical except for their names and IP addresses. Deployments can create new pods using a pod template and delete any pod when not needed.
However, Deployments are not suitable for distributed scenarios where each pod requires its own status or independent storage, such as in distributed databases.
Distributed stateful applications often involve different roles and responsibilities. For example, databases may operate in active/standby mode, and pods may depend on each other. To deploy stateful applications in Kubernetes, pods must meet the following requirements:
  • Each pod must have a unique, fixed identifier to be recognized by other pods.
  • Each pod should be configured with separate storage resources to ensure data persistence. This allows the original data to be retained and retrieved even after a pod is deleted and recreated. Without dedicated storage, the pod's data will be lost upon deletion, and the new pod will initialize with a different state.
To address these requirements, Kubernetes provides StatefulSets:
  1. StatefulSets provide a fixed name for each pod, followed by a sequential numeric suffix (for example, pod-0, pod-1, ..., pod-N). After a pod is rescheduled, its name and hostname remain unchanged.
  2. StatefulSets use a headless Service to allocate a fixed domain name for each pod.
  3. StatefulSets create PVCs with fixed identifiers. This ensures that pods can access the original persistent data after being rescheduled.
    Figure 3 StatefulSet
Overview of DaemonSet
A DaemonSet runs a pod on each node in a cluster and ensures that there is only one pod. This works well for certain system-level applications such as log collection and resource monitoring since they must run on each node. A good example is kube-proxy.
DaemonSets are closely related to nodes. If a node becomes faulty, the DaemonSet will not migrate the pod on that node to other nodes for re-creation.
Figure 4 DaemonSet
Overview of Jobs and CronJobs
Jobs and CronJobs are Kubernetes resources designed to manage short-lived, one-off tasks that run to completion.
  • A job is a resource object used to control batch tasks. Jobs start and terminate at specific times, unlike long-running services such as Deployments and StatefulSets, which run continuously unless terminated. Pods managed by a job are automatically removed after successfully completing their tasks, based on the specified settings.
  • A CronJob runs a job periodically on a specified schedule. A CronJob object is similar to a line in a crontab file in Linux.
The run-to-completion feature of workloads makes them particularly suitable for one-off tasks, such as continuous integration (CI) pipelines.
Workload Type Comparison
Dimension
Deployment
StatefulSet
DaemonSet
Job
CronJob
Core usage
Stateless applications (such as web services and APIs)
Stateful applications (such as distributed databases and middleware)
Node-level system applications (such as log collection and resource monitoring)
One-off batch tasks (such as data backups and file conversions)
Scheduled batch tasks (such as scheduled report generation and log deletion)
Pod identity
Random suffix and no fixed identifier
Fixed sequence numbers (such as db-0 and db-1)
Random name and auto-deleted after task completion
Network access
Via Services or ingresses
Via headless Services. Each pod has a fixed access domain (such as db-0.service-name.default.svc.cluster.local).
Via node IP addresses and fixed ports. No Service forwarding is required.
No long-term network access. Logic runs inside tasks.
Same as job and no long-term network access needed
Storage association
Storage not associated with pods, and temporary or shared storage typically used
Each pod associated with a separate PVC, and PVC persists after pod rebuild
Local storage (such as hostPath volumes) or shared storage associated with pods and tied to node lifecycle
Temporary storage (such as emptyDir volumes) and cleared after task completion
Same as job and storage cleared after each task period
Replica management policy
1-to-N identical, hot-swappable replicas
Replicas scaled by sequence number, added or removed in order (for example, db-2 to db-1), and no random pod deletion
Number of replicas = Number of cluster nodes (one replica per node by default); pods auto-deployed and removed with node lifecycle
No replicas, and tasks executed based on the number of completions
No replicas, and jobs triggered periodically, with new pods generated each time
Self-healing and rebuilding
Pod rebuilt on a healthy node, with its IP address and name changed
Pod rebuilt on the original or a healthy node, with its name, host name, and PVC unchanged
Pod rebuilt only on the current node and not migrated even if its node fails
Failed tasks retried automatically based on the backoffLimit setting until success or retries exhausted
Failed tasks retried and new tasks triggered in the next period
Lifecycle
Running until manually deleted or scaled to 0
Running until manually deleted, and long-term storage data retained
Associated with the node lifecycle (A pod runs as long as its node exists.)
Pod stopped (retained or deleted) after task completion
Cyclic execution of tasks on schedule, independent tasks per cycle, and stopped after the tasks are complete
Typical applications
Nginx, Spring Boot microservices, and static resource servers
MySQL, Elasticsearch, and ZooKeeper clusters
Fluentd (log collection) and Prometheus Node Exporter (resource monitoring)
Batch data import (for example, Excel-to-database conversion) and one-off scripts
Daily database backups, hourly log compression and cleanup, and weekly report generation
Workload Lifecycle
Table 1 Status description
Status
Running
All pods are running or the number of pods is 0.
Unready
The container malfunctions and the pod under the workload is not working.
Processing
The workload is not running but no error is reported.
Available
For a multi-pod Deployment, some pods are abnormal but at least one pod is available.
Completed
The task is successfully executed. This status is available only for common tasks.
Stopped
The workload is stopped and the number of pods changes to 0.
Deleting
The workload is being deleted.
