Updated on 2026-04-28 GMT+08:00
Dashboard
The Dashboard tab provides basic cluster configuration information, including Cluster Information, Cluster Settings, and Installed Add-ons.
Navigation Path
- In the navigation pane, choose Cluster > Settings. Then click the Dashboard tab.
Cluster Information
It includes:
- Cluster ID: uniquely identifies a cluster resource. It is automatically generated after a cluster is created and can be used in scenarios such as API calling.
- Current Name: After a cluster is created, you can click
to change its name. - Original Name: specifies a cluster's original name after its current name is changed. The current name of a cluster must be unique.
- Status: specifies the status of the cluster. For details, see Cluster Lifecycle.
- Type: This is a CCE Autopilot cluster.
- Created On: specifies the time when a cluster was created. You will be billed based on the creation time of clusters.
Cluster Settings
After a cluster is created, you can view the following information:
- Cluster Version | Patch Version: specifies the Kubernetes version and CCE patch version of the cluster.
- Network Model: Only cloud native network 2.0 is supported.
- Billing Mode: Only pay-per-use is supported.
- Enterprise Project: specifies the enterprise project to which a cluster belongs. For details, see Enterprise Center Overview.
- Operation Protection: If operation protection is enabled, you need to confirm the operation through the virtual MFA device, SMS messages, or emails. You can go to the IAM console, choose Security Settings > Critical Operations, and enable operation protection.
- Resource Tag: You can add resource tags to classify resources.
- Cluster Description: specifies the description that you entered for a cluster. A maximum of 200 characters is allowed.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
