Updated on 2026-09-15 GMT+08:00
Cluster Overview
Kubernetes is an open-source container orchestration engine for automating deployment, scaling, and management of containerized applications.
For developers, Kubernetes is a cluster operating system. Kubernetes provides service discovery, scaling, load balancing, self-healing, and even leader election, freeing developers from infrastructure-related configurations.
Cluster Network
A cluster network can be divided into two parts:
  • Container network: assigns IP addresses to containers in each pod of a cluster for communication. Only Cloud Native Network 2.0 is supported.
  • Service network: A Service is a Kubernetes object used to access containers. Each Service has a static IP address.
When you create a cluster, select a proper CIDR block for each network. Ensure that the CIDR blocks do not conflict with each other and have sufficient available IP addresses.
Cluster HA
By default, the control plane of a CCE Autopilot cluster is deployed in high availability (HA) mode. CCE provisions five master nodes across multiple AZs to ensure reliability and disaster recovery. The control plane is fully managed by CCE and runs core Kubernetes components, including kube-apiserver, kube-controller-manager, and etcd.
Cluster Lifecycle
Table 1 Cluster status
Status
Creating
A cluster is being created and requesting cloud resources.
Running
A cluster is running properly.
Upgrading
A cluster is being upgraded.
Unavailable
A cluster is unavailable.
Deleting
A cluster is being deleted.
Frozen
The cluster is frozen due to arrears.
Figure 1 Cluster status transition
CCE Autopilot Cluster Version Release Notes
The Kubernetes community continuously introduces new features and fixes vulnerabilities. CCE Autopilot will periodically release supported Kubernetes versions and provides feature updates and maintenance based on the Kubernetes community versions. For details, see the following sections:
To enable interoperability from one Kubernetes installation to the next, you must upgrade your Kubernetes clusters before the maintenance period ends.
