Updated on 2026-09-15 GMT+08:00
Prometheus Agent View
Prometheus Agent is a lightweight version of Prometheus Server. It scrapes the metrics for all hosts and components. The metrics are then reported to and stored on AOM or a third-party monitoring platform. The Prometheus Agent view displays some built-in metrics provided by Prometheus, which can be used to monitor and measure system performance and status.
Metric Description
You can view Prometheus Agent metrics in the following table.
Figure 1 Prometheus Agent metrics
Table 1 Prometheus Agent metrics
Metric
Unit
CPU Usage
Average CPU usage of pods.
Memory Usage
Average memory usage of pods.
Remote Write Rate
byte/s
The number of bytes remotely written per second.
Average Remote Write Duration
second
Average time consumed by remote writes.
Bytes Pending for Remote Write
byte
The number of pending bytes during a remote write.
Packets Discarded for Remote Write per Second
N/A
The number of packets discarded per second during a remote write.
Failed Remote Write Requests per Second
N/A
The number of failed remote write requests per second.
Percentage of Failed Remote Write Requests
Percentage of failed remote write requests.
Remote Write Retries per Second
N/A
The number of retries of the remote write per second.
Scrapers
N/A
The number of scrapers.
Collections per Second
N/A
Collections per second.
Average Collection Duration
second
Average collection duration.
Failed Reads During Collection per Second
N/A
The number of read errors during scrapes per second.
Failed Writes During Collection per Second
N/A
The number of write errors during scrapes per second.
Collections with Size Exceeding the Threshold per Second
N/A
Collections with size exceeding the threshold per second.
Read Rate of Sending Queue
byte/s
The number of bytes read by a sending queue per second.
Write Rate of Sending Queue
byte/s
The number of bytes written to a sending queue per second.
Pending Size of Sending Queue
byte
The number of bytes suspended in a sending queue.
Blocks Read per Second
N/A
The number of blocks read by a sending queue per second.
Blocks Written per Second
N/A
The number of blocks written to a sending queue per second.
Discarded Blocks per Second
N/A
The number of dropped blocks in a sending queue per second.
Metric List
The following is the metric list of the Prometheus Agent view.
Table 2 Metric description
Metric
Type
container_cpu_usage_seconds_total
Gauge
Cumulative CPU time consumed in seconds.
container_memory_working_set_bytes
Gauge
Current working set in bytes.
vmagent_remotewrite_bytes_sent_total
Counter
Total number of bytes remotely written by Prometheus Agent.
vmagent_remotewrite_duration_seconds_sum
Summary
Time consumed by a Prometheus Agent remote write.
vmagent_remotewrite_pending_data_bytes
Gauge
The number of pending bytes during a Prometheus Agent remote write.
vmagent_remotewrite_packets_dropped_total
Counter
Total number of dropped packets during a Prometheus Agent remote write.
vmagent_remotewrite_requests_total
Counter
Total number of Prometheus Agent remote write requests.
vmagent_remotewrite_retries_count_total
Counter
Total number of remote write retries of Prometheus Agent.
vm_promscrape_active_scrapers
Gauge
The number of collected shards.
vm_promscrape_scrapes_total
Counter
The number of scrapes.
vm_promscrape_scrape_duration_seconds_sum
Summary
Time required for the vmagent to collect metrics.
vm_promscrape_conn_read_errors_total
Counter
The number of read errors during scrapes.
vm_promscrape_conn_write_errors_total
Counter
The number of write errors during scrapes.
vm_promscrape_max_scrape_size_exceeded_errors_total
Counter
The number of failed scrapes due to the exceeded response size.
vm_persistentqueue_bytes_read_total
Counter
The number of bytes read by a send queue.
vm_persistentqueue_bytes_written_total
Counter
The number of bytes written to a send queue.
vm_persistentqueue_bytes_pending
Gauge
The number of pending bytes in a send queue.
vm_persistentqueue_blocks_read_total
Counter
The number of blocks read by a send queue.
vm_persistentqueue_blocks_written_total
Counter
The number of blocks written to a send queue.
vm_persistentqueue_blocks_dropped_total
Counter
The number of dropped blocks in a send queue.
