Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Storage/ SFS Turbo/ Using an Existing SFS Turbo File System Through a Static PV
Updated on 2025-10-28 GMT+08:00
SFS Turbo is a shared file system with high availability and durability. It is suitable for applications that contain massive small files and require low latency, and high IOPS. You can use a manually created SFS Turbo file system to create a PV, which can be bound to a PVC to allow pods to share this PV for persistent data storage. This section describes how to use an existing SFS Turbo file system to statically create PVs and PVCs and implement data persistence and sharing in workloads. You can choose to create new subdirectories when creating a PV.
  • You have created an available SFS Turbo file system that is in the same VPC as the cluster.
  • If you want to create a cluster by running commands, kubectl has been used to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
  • Not all regions support SFS Turbo volumes. View the regions where SFS Turbo volumes are supported on the console.
  • Multiple PVs can use the same SFS Turbo file system with the following restrictions:
    • All PVCs or PVs that use the same SFS Turbo file system cannot be mounted to a pod. This will result in a pod startup failure because not all PVCs can be mounted to the pod due to the same volumeHandle values of these PVs.
    • The persistentVolumeReclaimPolicy parameter in the PVs should be set to Retain. If any other value is used, when a PV is deleted, the associated underlying SFS Turbo file system may be deleted. In this case, other PVs associated with the underlying file system malfunction.
    • When a file system is repeatedly used, enable isolation and protection for ReadWriteMany at the application layer to prevent data overwriting and loss.
  • To create subdirectories for an SFS Turbo volume, the cluster version must be v1.27.9-r0, v1.28.7-r0, or later. If the cluster version does not meet the requirements, you need to upgrade the cluster.
  • For SFS Turbo storage, the yearly/monthly SFS Turbo resources will not be reclaimed when the cluster or PVC is deleted. Reclaim the resources on the SFS Turbo console.
Using the Console
  2. Statically create a PVC and PV.
    1. In the navigation pane, choose Storage. Then click the PVCs tab. In the upper right corner, click Create PVC. In the displayed dialog box, configure the parameters.
      PVC Type
      In this example, select SFS Turbo.
      PVC Name
      Enter the PVC name, which must be unique in the same namespace.
      Namespace
      Namespace of the PVC.
      • In the navigation pane, choose Storage. If Namespace in the upper part of the page is All namespaces or Non-system namespace, you can select an appropriate namespace.
      • If you choose Storage in the navigation pane and a non-system namespace (for example, default) has been specified for Namespace in the upper part of the page, the namespace is displayed here.
      Creation Method
      You can create a storage volume or use an existing storage volume to statically create a PVC based on whether a PV is available.
      In this example, select Create new to create a PV and PVC at the same time on the console.
      PVa
      Select an existing PV in the cluster. Create a PV in advance. For details, see "Creating a storage volume" in Related Operations.
      You do not need to specify this parameter in this example.
      SFS Turbob
      Click Select SFS Turbo. On the displayed page, select the SFS Turbo file system that meets your requirements and click OK.
      Subdirectoryb
      Determine whether to use subdirectories to create PVs.
      If this parameter is set to Yes, enter the absolute path of the subdirectory, for example, /a/b. In this case, the underlying storage associated with the PV is a subdirectory in the selected SFS Turbo file system. Ensure that the subdirectory is available.
      PV Nameb
      Enter the PV name, which must be unique in the same cluster.
      Access Modeb
      SFS Turbo volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple pods in read/write mode. For details, see Volume Access Modes.
      Reclaim Policyb
      Only Retain is available if you do not use subdirectories to create PVs. This indicates that the PV is not deleted when the PVC is deleted. For details, see PV Reclaim Policy. If you choose to create a subdirectory, this parameter can only be set to Delete.
      Subdirectory Reclaim Policyb
      Determine whether to retain subdirectories when a PVC is deleted. This parameter must be used with PV Reclaim Policy and can be configured when PV Reclaim Policy is set to Delete.
      • Retain: If a PVC is deleted, the PV will be deleted, but the subdirectories associated with the PV will be retained.
      • Delete: After a PVC is deleted, the PV and its associated subdirectories will also be deleted.
      Mount Optionsb
      Enter the mounting parameter key-value pairs. For details, see Configuring SFS Turbo Volume Mount Options.
      a: The parameter is available when Creation Method is set to Use existing.
      b: The parameter is available when Creation Method is set to Create new.
    2. Click Create to create a PVC and a PV.
      In the navigation pane, choose Storage. View the created PVC and PV on the PVCs and PVs tabs, respectively.
  3. Create a workload.
    1. In the navigation pane, choose Workloads. Then click the Deployments tab.
    2. In the upper right corner, click Create Workload. On the displayed page, click Data Storage in the Container Settings area and click Add Volume to select PVC.
      Table 1 describes the parameters for mounting the volume. For details about other parameters, see Workloads.
      Table 1 Mounting a storage volume
      PVC
      Select an existing SFS Turbo volume.
      Mount Path
      Enter a mount path, for example, /tmp.
      This parameter indicates the container path that the volume will be mounted to. Do not mount the volume to a system directory such as / or /var/run. This may cause container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. If there are such files, they will be replaced, which will lead to a container startup or workload creation failure.
      NOTICE:
      If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container, or high-risk files on the host may be damaged.
      Subpath
      Enter a subdirectory of the PV. This subdirectory will be mounted to a specified path of a container. In this way, different subdirectories of the same PV can be used in a single pod. Enter a subpath, for example, tmp, indicating that data in the mount path of the container is stored in the tmp directory of the storage volume. If this parameter is left blank, the root path is used by default.
      Permission
      • Read-only: You can only read the data in the mounted volume.
      • Read-write: You can modify the volume mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
      In this example, the volume is mounted to the /data path of the container. The container data generated in this path is stored in the SFS Turbo file system.
      Figure 1 Mounting a PV
    3. Configure other parameters and click Create Workload.
      After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence and Sharing.
Using kubectl
You can determine whether to use subdirectories based on your service requirements.
An entire SFS Turbo file system is used, and there are no subdirectories.
  1. Use kubectl to connect to the cluster.
  2. Create a PV.
    1. Create the pv-sfsturbo.yaml file.
      apiVersion: v1
      kind: PersistentVolume
        annotations:
          pv.kubernetes.io/provisioned-by: everest-csi-provisioner
        name: pv-sfsturbo    # PV name.
        accessModes:
        - ReadWriteMany      # Access mode. The value must be ReadWriteMany for SFS Turbo.
        capacity:
          storage: 500Gi       # SFS Turbo volume capacity.
        csi:
          driver: sfsturbo.csi.everest.io    # Dependent storage driver for the mounting.
          fsType: nfs
          volumeHandle: <your_volume_id>   # SFS Turbo volume ID.
          volumeAttributes:
            everest.io/share-export-location: <your_location>   # Shared path of the SFS Turbo volume.
            everest.io/enterprise-project-id: <your_project_id>  # Project ID of the SFS Turbo volume.
            storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
        persistentVolumeReclaimPolicy: Retain    # Reclaim policy.
        storageClassName: csi-sfsturbo          # Storage class name of the SFS Turbo volume.
        mountOptions: []                         # Mount options.
      Table 2 Key parameters
      Mandatory
      volumeHandle
      Yes
      How to obtain: Log in to the SFS console, choose SFS Turbo > File Systems in the navigation pane, and copy the ID of the SFS Turbo file system.
      Yes
      How to obtain: Log in to the SFS console, choose SFS Turbo > File Systems in the navigation pane, and copy the shared path of the SFS Turbo file system.
      No
      ID of the enterprise project for the SFS Turbo file system. It is only applicable to enterprise accounts with enterprise projects enabled. For more information, see Enterprise Management.
      If you use the default enterprise project, set this field to 0.
      How to obtain: On the SFS console, choose SFS Turbo in the navigation pane. Click the name of the target SFS Turbo file system. On the Basic Info tab, find and click the enterprise project to go to the EPS console, and copy the enterprise project ID.
      mountOptions
      No
      Mount options.
      If this parameter is not specified, the following configurations are used by default. For details, see Configuring SFS Turbo Volume Mount Options.
      mountOptions:
      - vers=3
      - timeo=600
      - nolock
      - hard
      Yes
      Only Retain is supported. For details, see PV Reclaim Policy.
      Retain: When a PVC is deleted, both the PV and underlying storage are retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again. To continue to use the underlying storage resources, delete the PV first. Then create another PV and PVC and associate the underlying storage resources with the PV and PVC.
      storage
      Yes
      Requested capacity in the PVC, in Gi.
      storageClassName
      Yes
      The storage class name of SFS Turbo volumes is csi-sfsturbo.
    2. Run the following command to create a PV:
      kubectl apply -f pv-sfsturbo.yaml
  3. Create a PVC.
    1. Create the pvc-sfsturbo.yaml file.
      apiVersion: v1
      kind: PersistentVolumeClaim
        namespace: default
        annotations:
          volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner
        accessModes:
        - ReadWriteMany                  # The value must be ReadWriteMany for SFS Turbo.
        resources:
          requests:
        storageClassName: csi-sfsturbo       # Storage class name of the SFS Turbo volume. It must be the same as that of the PV.
        volumeName: pv-sfsturbo    # PV name.
      Table 3 Key parameters
      Mandatory
      No
      How to obtain: On the SFS console, choose SFS Turbo in the navigation pane. Click the name of the target SFS Turbo file system. On the Basic Info tab, find and click the enterprise project to go to the console, and copy the ID.
      storage
      Yes
      The value must be the same as the storage size of the existing PV.
      storageClassName
      Yes
      Storage class name, which must be the same as the storage class of the PV in 2.a.
      volumeName
      Yes
      PV name, which must be the same as the PV name in 2.a.
    2. Run the following command to create a PVC:
      kubectl apply -f pvc-sfsturbo.yaml
  4. Create a workload.
    1. Create a file named web-demo.yaml. In this example, the SFS Turbo volume is mounted to the /data path.
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 2
        selector:
          matchLabels:
            app: web-demo
        template:
            labels:
              app: web-demo
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
              - name: pvc-sfsturbo-volume    #Volume name, which must be the same as the volume name in the volumes field.
                mountPath: /data  #Location where the storage volume is mounted.
            imagePullSecrets:
              - name: default-secret
            volumes:
              - name: pvc-sfsturbo-volume    #Volume name, which can be changed as needed.
                persistentVolumeClaim:
                  claimName: pvc-sfsturbo    #Name of the created PVC.
    2. Run the following command to create a workload that the SFS Turbo volume is mounted to:
      kubectl apply -f web-demo.yaml
      After the workload is created, you can try Verifying Data Persistence and Sharing.
  2. Create a PV.
      Example:
      apiVersion: v1
        annotations:
         everest.io/reclaim-policy: retain-volume-only    # When a PVC is deleted, the PV will be deleted but the subdirectories associated with the PV will be retained. This parameter is only available when subdirectories are used and the reclaim policy is Delete.
        accessModes:
        capacity:
          storage: 500Gi # When a subdirectory is used, this parameter is meaningless and used only for verification. (The value cannot be empty or 0.)
        csi:
          fsType: nfs
          volumeHandle: pv-sfsturbo   # PV name when subdirectories are used.
          volumeAttributes:
            everest.io/enterprise-project-id: <your_project_id> # (Optional) Project ID of the SFS Turbo file system
            everest.io/volume-as: absolute-path   # An SFS Turbo subdirectory is used.
            everest.io/share-export-location: <sfsturbo_path>:/<absolute_path> # The value consists of the shared path of SFS Turbo file system and the absolute path of the subdirectory.
            everest.io/sfsturbo-share-id: <sfsturbo_id>    #  SFS Turbo file system ID
        persistentVolumeReclaimPolicy: Retain  # PV reclaim policy
      Table 4 Key parameters
      Mandatory
      No
      Whether to retain the subdirectory when deleting the PVC. This parameter is used in conjunction with PV Reclamation Policy. This parameter is only available when the PV reclaim policy is Delete.
      • retain-volume-only: If a PVC is deleted, the PV will be deleted, but the subdirectories associated with the PV will be retained.
      • delete: After a PVC is deleted, the PV and its associated subdirectories will also be deleted.
        When a subdirectory is deleted, only the absolute path of the subdirectory configured in the PVC will be deleted. The upper-layer directory will not be deleted.
      storage
      Yes
      Requested capacity in the PVC, in Gi. If a subdirectory is used, this parameter serves no purpose other than for verification and must have a non-empty, non-zero value.
      volumeHandle
      Yes
      PV name when an SFS Turbo subdirectory is used to create the PV.
      No
      Yes
      The value is fixed at absolute-path, indicating that the current PV uses a subdirectory of the SFS Turbo file system.
      Yes
      Shared path of the SFS Turbo file system subdirectory. The value consists of the shared path of the SFS Turbo file system and the absolute path of the subdirectory. The absolute path of the subdirectory needs to be specified, for example, /a/b. Ensure that the subdirectory exists and is available.
      The format is as follows:
      {sfsturbo_path}:/{absolute_path}
      How to obtain: Log in to the CCE console, choose Service List > Storage > Scalable File Service, and then select SFS Turbo. You can obtain the shared path of the file system.
      Yes
      ID of an SFS Turbo file system.
      How to obtain: On the CCE console, choose Service List > Storage > Scalable File Service. In the navigation pane, choose SFS Turbo > File Systems. Copy the file system ID under the file system name on the right.
      Yes
      PV reclaim policy. For details, see PV Reclaim Policy.
      • Retain: When a PVC is deleted, both the PV and underlying storage are retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again.
      • Delete: This parameter can be configured when subdirectories are automatically created, indicating that the PV is deleted when a PVC is deleted.
      storageClassName
      Yes
      The storage class name of SFS Turbo is csi-sfsturbo.
      mountOptions
      No
      Mount options.
      mountOptions:
      - vers=3
      - timeo=600
      - nolock
      - hard
  3. Create a PVC.
      apiVersion: v1
        namespace: default
        annotations:
        accessModes:
        resources:
          requests:
      Table 5 Key parameters
      Mandatory
      No
      storage
      Yes
      storageClassName
      Yes
      volumeName
      Yes
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 2
        selector:
          matchLabels:
            app: web-demo
        template:
            labels:
              app: web-demo
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
            imagePullSecrets:
            volumes:
              - name: pvc-sfsturbo-volume    # Volume name, which can be changed as needed.
  1. View the deployed application and files.
    1. Run the following command to view the created pod:
      kubectl get pod -n <namespace> | grep web-demo
      Expected output:
      web-demo-846b489584-mjhm9   1/1     Running   0             46s
      web-demo-846b489584-wvv5s   1/1     Running   0             46s
    2. Run the following commands in sequence to check the files in the /data path of the pods:
      kubectl exec -n <namespace> web-demo-846b489584-mjhm9 -- ls /data
      kubectl exec -n <namespace> web-demo-846b489584-wvv5s -- ls /data
      If no result is returned for both pods, no file exists in the /data path.
  2. Run the following command to create a file named static in the /data path:
    kubectl exec -n <namespace> web-demo-846b489584-mjhm9 --  touch /data/static
  3. Run the following command to check the files in the /data path:
    Expected output:
    static
  4. Verify data persistence.
    1. Run the following command to delete the pod named web-demo-846b489584-mjhm9:
      kubectl delete pod -n <namespace> web-demo-846b489584-mjhm9
      Expected output:
      pod "web-demo-846b489584-mjhm9" deleted
      After the deletion, the Deployment controller automatically creates a replica.
    2. Run the following command to view the created pod:
      The expected output is as follows, in which web-demo-846b489584-d4d4j is the newly created pod:
      web-demo-846b489584-d4d4j   1/1     Running   0             110s
      web-demo-846b489584-wvv5s    1/1     Running   0             7m50s
    3. Run the following command to check whether the files in the /data path of the new pod have been modified:
      kubectl exec -n <namespace> web-demo-846b489584-d4d4j -- ls /data
      Expected output:
      static
      The static file is retained, indicating that the data in the file system can be stored persistently.
  5. Verify data sharing.
      Expected output:
      web-demo-846b489584-d4d4j   1/1     Running   0             7m
      web-demo-846b489584-wvv5s   1/1     Running   0             13m
    2. Run the following command to create a file named share in the /data path of either pod: In this example, select the pod named web-demo-846b489584-d4d4j.
      kubectl exec -n <namespace> web-demo-846b489584-d4d4j --  touch /data/share
      Check the files in the /data path of the pod.
      Expected output:
      share
      static
    3. Check whether the share file exists in the /data path of another pod (web-demo-846b489584-wvv5s) as well to verify data sharing.
      Expected output:
      share
      static
      After you create a file in the /data path of a pod, if the file is also created in the /data path of the other pod, the two pods share the same volume.
Related Operations
You can also perform the operations described in Table 6.
Table 6 Related operations
Operation
Creating a storage volume (PV)
Create a PV on the CCE console.
  1. In the navigation pane, choose Storage. Then click the PVs tab. In the upper right corner, click Create PersistentVolume. In the displayed dialog box, configure the parameters.
    • Volume Type: Select SFS Turbo.
    • SFS Turbo: Click Select SFS Turbo. On the displayed page, select the SFS Turbo file system that meets your requirements and click OK.
    • Subdirectory: Determine whether to use subdirectories to create PVs. Enter the absolute path of a subdirectory, for example, /a/b. Ensure that the subdirectory is available.
    • PV Name: Enter the PV name, which must be unique in the same cluster.
    • Access Mode: SFS volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple pods in read/write mode. For details, see Volume Access Modes.
    • Reclaim Policy: Only Retain is supported if you do not use subdirectories. For details, see PV Reclaim Policy. If you choose to create a subdirectory, this parameter can only be set to Delete.
    • Mount Options: Enter the mounting parameter key-value pairs. For details, see Configuring SFS Turbo Volume Mount Options.
  2. Click Create.
Expanding the capacity of an SFS Turbo volume
Quickly expand the capacity of a mounted SFS Turbo volume on the CCE console.
  1. In the navigation pane, choose Storage. Then click the PVCs tab. Locate the target PVC and click More > Scale-out in the Operation column.
  2. Enter the capacity to be added and click OK.
Viewing events
You can view event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. In the navigation pane, choose Storage. Then click the PVCs or PVs tab.
  2. Locate the target PVC or PV, click View Events in the Operation column to view events generated within one hour (events are retained for one hour).
Viewing a YAML file
You can view, copy, and download the YAML files of a PVC or PV.
  2. Locate the target PVC or PV, click View YAML in the Operation column to view or download the YAML.
