Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Storage/ Scalable File Service/ Using an Existing File System Through a Static PV
Updated on 2025-02-27 GMT+08:00
SFS is a network-attached storage (NAS) that provides shared, scalable, and high-performance file storage. It applies to large-capacity expansion and cost-sensitive services. You can mount the PVs created from general-purpose file systems (formerly SFS 3.0) to pods in CCE Autopilot clusters for file storage. This section describes how to use an existing file system to statically create PVs and PVCs and implement data persistence and sharing in workloads.
  • If you want to create a cluster using commands, kubectl has been used to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
  • You have created a general purpose file system (formerly SFS 3.0) that is in the same VPC as the cluster.
  • You have configured a VPC endpoint required by the general purpose file system (formerly SFS 3.0). For details, see Configuring a VPC Endpoint.
  • Not all regions support volumes created from file systems. View the regions where SFS volumes are supported on the console. You can also view Function Overview to learn about all regions where SFS volumes are supported.
  • Multiple PVs can use the same general purpose file system (formerly SFS 3.0) if the following restrictions are meet:
    • All PVCs or PVs that use the same file system cannot be mounted to a pod. This will result in a pod startup failure because not all PVCs can be mounted to the pod due to the same volumeHandle values of these PVs.
    • The persistentVolumeReclaimPolicy parameter in the PVs should be set to Retain. If any other value is used, when a PV is deleted, the associated underlying SFS file system may be deleted. In this case, other PVs associated with the underlying file system malfunction.
    • When a file system is repeatedly used, enable isolation and protection for ReadWriteMany at the application layer to prevent data overwriting and loss.
  • If a general-purpose file system (formerly SFS 3.0) is used, the owner group and permission of the mount point cannot be modified.
  • If a general-purpose file system (formerly SFS 3.0) is used, there may be a latency when the PVCs or PVs are created or deleted. The billing duration depends on the time when the file systems are created or deleted on the SFS console.
  • If the reclamation policy of the volumes created from general purpose file systems (formerly SFS 3.0) is set to Delete, the volumes cannot be reclaimed automatically. Before deleting a PV or PVC, you are required to delete all files in the file systems manually.
Using the Console
  2. Statically create a PVC and PV.
    1. In the navigation pane on the left, choose Storage. Then click the PVCs tab. In the upper right corner, click Create PVC. In the displayed dialog box, configure the parameters.
      PVC Type
      In this example, select SFS.
      PVC Name
      Enter the PVC name, which must be unique in the same namespace.
      Creation Method
      • If underlying storage is available, create a PV or use an existing PV to statically create a PVC.
      • If no underlying storage is available, select Dynamically provision. For details, see Using an SFS File System Through a Dynamic PV.
      In this example, select Create new to create a PV and PVC at the same time on the console.
      PVa
      Select an existing PV in the cluster. Create a PV in advance. For details, see "Creating a storage volume" in Related Operations.
      You do not need to specify this parameter in this example.
      SFSb
      Click Select SFS. On the displayed page, select the SFS file system that meets your requirements and click OK.
      Only general purpose file systems (formerly SFS 3.0) are supported.
      PV Nameb
      Enter the PV name, which must be unique in the same cluster.
      Access Modeb
      SFS volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple pods in read/write mode. For details, see Volume Access Modes.
      Reclaim Policyb
      You can select Delete or Retain to specify the reclaim policy of the underlying storage when the PVC is deleted. For details, see PV Reclaim Policy.
      If multiple PVs use the same underlying storage volume, use Retain to avoid cascading deletion of underlying volumes.
      Mount Optionsb
      Enter the mounting parameter key-value pairs. For details, see Configuring SFS Volume Mount Options.
      a: The parameter is available when Creation Method is set to Use existing.
      b: The parameter is available when Creation Method is set to Create new.
    2. Click Create to create a PVC and a PV.
      In the navigation pane on the left, choose Storage. View the created PVC and PV on the PVCs and PVs tabs, respectively.
  3. Create a workload.
    1. In the navigation pane on the left, choose Workloads. Then click the Deployments tab.
    2. In the upper right corner, click Create Workload. On the displayed page, click Data Storage in the Container Settings area and click Add Volume to select PVC.
      Mount and use storage volumes, as shown in Table 1. For details about other parameters, see Workloads.
      Table 1 Mounting a storage volume
      PVC
      Select an existing SFS volume.
      Mount Path
      Enter a mount path, for example, /tmp.
      This parameter indicates the container path that the volume will be mounted to. Do not mount the volume to a system directory such as / or /var/run. This may cause container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. If there are such files, they will be replaced, which will lead to a container startup or workload creation failure.
      NOTICE:
      If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container, or high-risk files on the host may be damaged.
      Subpath
      Enter a subpath, for example, tmp, indicating that data in the mount path of the container is stored in the tmp directory of the storage volume.
      A subpath is used to mount a local volume so that the same volume is used in a single pod. If this parameter is left blank, the root path is used by default.
      Permission
      • Read-only: You can only read the data in the mounted volume.
      • Read-write: You can modify the volume mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
      In this example, the volume is mounted to the /data path of the container. The container data generated in this path is stored in the SFS file system.
    3. Configure other parameters and click Create Workload.
      After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence and Sharing.
Using kubectl
  1. Use kubectl to connect to the cluster.
  2. Create a PV.
    1. Create the pv-sfs.yaml file.
      apiVersion: v1
      kind: PersistentVolume
        annotations:
          pv.kubernetes.io/provisioned-by: everest-csi-provisioner
          everest.io/reclaim-policy: retain-volume-only      # (Optional) The underlying storage is retained when the PV is deleted.
        name: pv-sfs    # PV name.
        accessModes:
        - ReadWriteMany      # Access mode. The value must be ReadWriteMany for SFS.
        capacity:
          storage: 1Gi     # SFS volume capacity.
        csi:
          driver: nas.csi.everest.io    # Dependent storage driver for the mounting
          fsType: nfs
          volumeHandle: <your_volume_id>   # Enter the name of the general purpose file system (formerly SFS 3.0) is used.
          volumeAttributes:
            everest.io/share-export-location: <your_location>  # Shared path of the SFS volume.
            storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
            everest.io/sfs-version: sfs3.0       # A general-purpose file system (formerly SFS 3.0) is used for storage.
        persistentVolumeReclaimPolicy: Retain    # Reclaim policy.
        storageClassName: csi-sfs               # StorageClass name, where csi-sfs indicates general purpose file systems (formerly SFS 3.0).
        mountOptions: []                         # Mount options.
      Table 2 Key parameters
      Mandatory
      No
      Optional.
      Currently, only retain-volume-only is supported.
      This parameter is valid only when the reclaim policy is set to Delete. If the reclaim policy is Delete and the value is retain-volume-only, the associated PV is deleted while the underlying storage volume is retained, when a PVC is deleted.
      volumeHandle
      Yes
      If a general purpose file system (formerly SFS 3.0) is used, enter the name of the file system.
      Yes
      Shared path of the file system.
      A shared path is in the following format:
      {your_sfs30_name}.sfs3.{region}.myhuaweicloud.com:/{your_sfs30_name}
      mountOptions
      Yes
      Mount options.
      If this parameter is not specified, the following configurations are used by default. For details, see Configuring SFS Volume Mount Options.
      mountOptions:
      - vers=3
      - timeo=600
      - nolock
      - hard
      Yes
      The Delete and Retain reclaim policies are supported. For details, see PV Reclaim Policy. If multiple PVs use the same SFS volume, use Retain to prevent the underlying volume from being deleted with a PV.
      Delete:
      • If everest.io/reclaim-policy is not specified, both the PV and SFS file system will be deleted when a PVC is deleted.
      • If everest.io/reclaim-policy is set to retain-volume-only, when a PVC is deleted, the PV will be deleted but the SFS file system will be retained.
      Retain: When a PVC is deleted, both the PV and underlying storage are retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again.
      storage
      Yes
      Requested capacity in the PVC, in Gi.
      For SFS, this field is used only for verification (cannot be empty or 0). Its value is fixed at 1, and any value you set does not take effect for SFS file systems.
    2. Run the following command to create a PV:
      kubectl apply -f pv-sfs.yaml
  3. Create a PVC.
    1. Create the pvc-sfs.yaml file.
      apiVersion: v1
      kind: PersistentVolumeClaim
        namespace: default
        annotations:
          volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner
        accessModes:
        - ReadWriteMany               # The value must be ReadWriteMany for SFS.
        resources:
          requests:
        storageClassName: csi-sfs       # Storage class name, which must be the same as that of the PV.
        volumeName: pv-sfs    # PV name.
      Table 3 Key parameters
      Mandatory
      storage
      Yes
      The value must be the same as the storage size of the existing PV.
      volumeName
      Yes
      PV name, which must be the same as the PV name in 2.a.
    2. Run the following command to create a PVC:
      kubectl apply -f pvc-sfs.yaml
  4. Create a workload.
    1. Create a file named web-demo.yaml. In this example, the SFS volume is mounted to the /data path.
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 2
        selector:
          matchLabels:
            app: web-demo
        template:
            labels:
              app: web-demo
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
              - name: pvc-sfs-volume    # Volume name, which must be the same as the volume name in the volumes field.
                mountPath: /data  # Location where the storage volume is mounted.
            imagePullSecrets:
              - name: default-secret
            volumes:
              - name: pvc-sfs-volume    # Volume name, which can be changed as needed.
                persistentVolumeClaim:
                  claimName: pvc-sfs    # PVC name.
    2. Run the following command to create a workload that the SFS volume is mounted to:
      kubectl apply -f web-demo.yaml
  1. View the deployed application and files.
    1. Run the following command to view the pod:
      kubectl get pod | grep web-demo
      Expected output:
      web-demo-846b489584-mjhm9   1/1     Running   0             46s
      web-demo-846b489584-wvv5s   1/1     Running   0             46s
    2. Run the following commands in sequence to view the files in the /data path of the pods:
      kubectl exec web-demo-846b489584-mjhm9 -- ls /data
      kubectl exec web-demo-846b489584-wvv5s -- ls /data
      If no result is returned for both pods, no file exists in the /data path.
  2. Run the following command to create a file named static in the /data path:
    kubectl exec web-demo-846b489584-mjhm9 --  touch /data/static
  3. Run the following command to view the created file in the /data path:
    Expected output:
    static
  4. Verify data persistence.
    1. Run the following command to delete the pod named web-demo-846b489584-mjhm9:
      kubectl delete pod web-demo-846b489584-mjhm9
      Expected output:
      pod "web-demo-846b489584-mjhm9" deleted
      After the deletion, the Deployment controller automatically creates a replica.
    2. Run the following command to view the pod:
      The expected output is as follows, in which web-demo-846b489584-d4d4j is the newly created pod:
      web-demo-846b489584-d4d4j   1/1     Running   0             110s
      web-demo-846b489584-wvv5s    1/1     Running   0             7m50s
    3. Run the following command to check whether the file in the /data path of the new pod has been modified:
      kubectl exec web-demo-846b489584-d4d4j -- ls /data
      Expected output:
      static
      The static file is retained, indicating that the data can be stored persistently.
  5. Verify data sharing.
      Expected output:
      web-demo-846b489584-d4d4j   1/1     Running   0             7m
      web-demo-846b489584-wvv5s   1/1     Running   0             13m
    2. Run the following command to create a file named share in the /data path of either pod: In this example, select the pod named web-demo-846b489584-d4d4j.
      kubectl exec web-demo-846b489584-d4d4j --  touch /data/share
      Check the files in the /data path of the pod.
      Expected output:
      share
      static
    3. Check whether the share file exists in the /data path of another pod (web-demo-846b489584-wvv5s) as well to verify data sharing.
      Expected output:
      share
      static
      After you create a file in the /data path of a pod, if the file is also created in the /data path of the other pod, the two pods share the same volume.
Related Operations
You can also perform the operations described in Table 4.
Table 4 Related operations
Operation
Creating a storage volume (PV)
Create a PV on the CCE console.
  1. In the navigation pane on the left, choose Storage. Then click the PVs tab. In the upper right corner, click Create PersistentVolume. In the displayed dialog box, configure the parameters.
    • Volume Type: Select SFS.
    • SFS: Click Select SFS. On the displayed page, select the SFS file system that meets your requirements and click OK.
    • PV Name: Enter the PV name, which must be unique in the same cluster.
    • Access Mode: Only ReadWriteMany is available. A storage volume can be mounted to multiple pods in read/write mode. For details, see Volume Access Modes.
    • Reclaim Policy: There are two options: Retain and Delete. For details, see PV Reclaim Policy
      If multiple PVs use the same underlying storage volume, use Retain to prevent the underlying volume from being deleted with a PV.
    • Mount Options: Enter the mounting parameter key-value pairs. For details, see Configuring SFS Volume Mount Options.
  2. Click Create.
Viewing events
You can view event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. In the navigation pane on the left, choose Storage. Then click the PVCs or PVs tab.
  2. Locate the target PVC or PV, click View Events in the Operation column to view events generated within one hour (events are retained for one hour).
Viewing a YAML file
You can view, copy, and download the YAML files of a PVC or PV.
  2. Locate the target PVC or PV, click View YAML in the Operation column to view or download the YAML.
